2000 LX470 Tranny Fill Location
Old Dec 22, 2005 | 10:04 PM
dcruse@per's Avatar
dcruse@per
Default 2000 LX470 Tranny Fill Location
I want to change the tranimssion fluid on my 2000 LX470 w/ 80K miles. I see the drain plug, but for the life of me, I can't find where you refill the fluid! I can't find a tranny dipstick either. Any pointers would be greatly appreciated. Thanks!
Old Dec 23, 2005 | 07:22 AM
Tammy's Avatar
Tammy
Check your owners manual for the type of transmission fluid your LX takes... You may not have a dip stick !
Old Dec 23, 2005 | 08:18 AM
dcruse@per's Avatar
dcruse@per
Found it! Hidden at the rear of the engine compartment. Thanks.
Old Dec 23, 2005 | 08:31 PM
koolaidman's Avatar
koolaidman
lol i find this funny
Old Dec 24, 2005 | 11:06 AM
csaxon's Avatar
csaxon
Tammy is correct Koolaide man. It depends on your system.
AUTOMATIC TRANSMISSION FLUID (From August, 2003)
ADJUSTMENT
1. BEFORE TRANSMISSION FILL
 This transmission requires Toyota Genuine ATF WS.
 It is necessary to refill the transmission with the correct
amount of fluid.
 The vehicle must remain level while adjusting the transmission
fluid level.
 On vehicles equipped with active suspension, turn the
suspension control switch OFF if it is necessary to jack up
the vehicle with the engine running.
2. TRANSMISSION PAN FILL
(a) Remove the refill plug and overflow plug.
(b) Fill the transmission through the refill hole until fluid begins
to trickle out of the overflow tube
(c) Reinstall the overflow plug.
No dipstick on some models!
https://www.clublexus.com/forums/sho...d.php?t=192431
Old Jan 2, 2006 | 04:32 PM
koolaidman's Avatar
koolaidman
ADJUSTMENT
amount of fluid.
fluid level.
ya but its only on 2004 and up u dont have dipsticks he said 2000
and tammy said this in the thread u mentioned
The LS 430, GX 470 and LX 470 (Land Cruiser) started using the World Standard transmision fluid in 2004, and using it since. The fluid cannot be mixed with any other fluid types (Type-IV or Dexron III).
silver250
Aug 13, 2021 02:32 PM
Scuba420
IS - 1st Gen (2001-2005)
Aug 18, 2014 07:13 PM
fantastic1
Aug 22, 2011 05:40 PM
primetime2
GX - 1st Gen (2003-2009)
Jun 19, 2007 04:22 PM
Bobk528
RX - 1st Gen (1999-2003)
16
Sep 26, 2005 07:34 PM
