PDA
View Full Version : Maintenance
Pages : 1 2 3 4 5 6 7 8 9 10 [11] 12 13 14 15 16 17 18 19 20 21 22 23 24 25
  1. Replacing puddle light bulb on 99 LS400
  2. Synthetic Oil Once & For All???
  3. Alternator Buzz Under Load
  4. 99' GS300 diff plug size?
  5. What maintenace service for 00 Rx300
  6. Mph gauge isnt working. need help!
  7. Brake pads for LS400
  8. Not in gear, clutch issues or ????
  9. $900 later....
  10. wiring diagram(seats)
  11. O2 Sensor Error
  12. GS oil change
  13. $17.99 5qt Valvoline FULL SYNTHETIC at AUTOZONE
  14. Long oil write-up
  15. A replacement or option for T-IV ATF
  16. lexus sc400 help
  17. Maintenance time for my SC430... HELP PLEASE!!!
  18. How to change a serpentine belt for 2001 IS300
  19. What coolant are we suppose to use?
  20. 2001 LS430-Check engine light and Check VSC codes on, can anyone give me some advice
  21. transmission drain and fill question
  22. Vendor Feedback: Careless Packaging
  23. Problems on 99" ES300
  24. Recommend a vendor that I can order this part from
  25. Rear Diff. GS400
  26. RxP gas kicker - whole case (24 bottles)
  27. transmission fluid replacement
  28. oil deposit on sparkplug
  29. Leaking Coolant-New Radiator Needed?
  30. Change Spark Plugs
  31. TSB question?
  32. Engine Oil Message
  33. 1990 ls400 main TPS?
  34. E-Brake light stays on SC400
  35. Really bad issue.
  36. Electronic rust-proofing
  37. Body shop recommendation in York/Harrisburg/Lancaster PA area
  38. How many pounds does it take to fill A/C
  39. Question about changing frt. brake pads
  40. help where can i purchase this
  41. Broken Light
  42. Lexus change to engine oil specification
  43. 1993 ES 300 Engine Exploded view...
  44. anyone know where I can find a DIY for a 98-00 LS400 Oil Change???
  45. TSB, technial service bulletins
  46. Motor Mounts ...
  47. Transmission Oil
  48. Ac Foam evaporator
  49. caster alignment problem
  50. Oil Light stays on
  51. Burned smell to steering fluid
  52. V8 Owners- Post your 1UZ-FE emissions results here
  53. Noise after Water Pump, Timing Belt, Starter install
  54. Valve Cover Replacement
  55. Independant mechanic in San Diego County
  56. oxygen sensors - where to buy?
  57. Dealer's charge for 10K service?
  58. 1998 - 2000 Lexus Ls400 Car Service/ Repair Manual
  59. check engine light is on
  60. Repair Manuals Q
  61. Remove Oil Pan 2003 GS300
  62. Cabin Filter - ultimate replacement?!
  63. How to read a production change effective VIN #
  64. mr2 question
  65. 45k service- Dealer or Independent Shop
  66. es300 wiring diagram
  67. 30k Service for my LS430. at Dealer
  68. Changing rear wiper insert on RX330
  69. If u chg water pump, do u chg Timing Belt?
  70. 1996 LS400 intermintent rattle issue from motor
  71. Parts numbers
  72. NO power steering at low rpms
  73. Is 1 qt. per 1200 miles cause for concern?
  74. Torque specification for brake caliper bolt
  75. I had an accident and now my car won't start
  76. RockAuto discount code, if you need one.
  77. Need Help !!! Check Engine Light
  78. Climate Contol LCD out
  79. New Radiator needed
  80. Need Help
  81. Where to get 1jz automatic trans filter?
  82. How many qts. of oil does 2005 LS 430 take
  83. Should I flush my transmission at 250,000 miles?
  84. sc300 engine coolant fill ?
  85. Oil Analysis for Supercharged Engine
  86. Encountering a new noise.
  87. tune up for a 170,000 miles
  88. Rattling sound, maybe valves?
  89. How to properly bleed 92 sc400 brakes?
  90. Public disclosure of TSB-Technical Bulletins
  91. Question about maintenance for 307K SC400?
  92. Passenger seat belt light Question
  93. SC300 refuses to stop cranking!
  94. cheap cone air filters
  95. Tuneup for 95 GS300 any good place other than dealer?
  96. Noobie, What gas do you pump??
  97. Driver side door lock problem..
  98. K&N Air Filter Cleaning
  99. Age, might mean you need new tires
  100. Recommended Service for 95 LS
  101. Can't get it up (into overdrive)... Please help
  102. Can I wax panorama roof?
  103. Do you follow the 3 month/3k mile oil change?
  104. Control Arm Bushings
  105. 1jzgte tuneup...where to get cap/rotor spark plug wires?
  106. vin #
  107. SC400 differential fluid volume and type question
  108. Wheel Bearing Servicing
  109. 1st gen question......
  110. Loss Of Power
  111. Shelf Life ?
  112. Need to vent - parts issue (resolved)
  113. Who Else Uses Type IV Transmission Fluid in their SC300
  114. Just had trans flushed with amsoil synthetic
  115. Replace shims on LS430 when replacing brakes?
  116. 90K service
  117. Dimming headlights with other control use?
  118. Leaky Fuel Pressure Regulator?
  119. How much you guys pay for maintanance
  120. My brother got into a “fender-bender” with a 1998 Lexus ES 300…need help
  121. Sparks coming from my A/C compressor
  122. vsc and check engine light
  123. Deployed airbag...Steering wheel repair?
  124. gs300 im from indonesia and i need help
  125. Clutch Replacement Question
  126. What does everybody keep their used motor oil in?
  127. Axxis Ultimate vs Hawk HPS Street brake pads
  128. SoCal toyota dealers refuse oil changes on Lexus cars.... ?!@#$
  129. LS 430 Drifts right and moves right to left at 70+
  130. NGK Iridium spark plugs on sale $1.99!
  131. transmission oil
  132. My dealership maintainance history sheets
  133. Aftermarket Cone air filter. Replace at what milage intervals?
  134. Loose noise on front wheel
  135. Is There A Molding/Bondo/Carbon Fiber shop in Seattle area?
  136. anyone knows a Lexus shop in Charlotte
  137. have anyone heard of....
  138. Mileage Vs. Date?
  139. Nashville mechanic to replace control arm bushings
  140. 2006 GS300 DIY oil change question
  141. New SC300 owner here: Whats the best oil/filter?
  142. Know of any independent Lexus Mechanics/Shops in Kansas City area?
  143. Aftermarket Air And Oil Filters
  144. What is included in a 100k mile service/Tune-up
  145. Spark Plugs Covered With Oil!?!
  146. Code 13 - RPM Signal?
  147. Wheel balancing
  148. gs400/GS430 timing belt
  149. Vsc Off Indicator
  150. sludge??
  151. techinfo.lexus.com. repair manuals online?
  152. Opinions on WIX Oil Filters?
  153. Brake experts?
  154. Anyone know a good shop in SF
  155. Battery for 01 GS300, please recommend
  156. synthetic ATF
  157. DIY timing belt? vvti 2jz
  158. synthetic oils/lubricants
  159. Making a spare key
  160. LS430 Alignment Spec
  161. Pink Engine Coolant?
  162. 51 unaccounted miles on car while in shop
  163. Possible Tranny problem...question for mechanics or knowledgeable owners
  164. ??? on Power Steering
  165. EFI Relay Clicking
  166. Is it important to clean the engine bay?
  167. Portable hydraulic lifts?
  168. Cabin Filter
  169. AC diagnostic?
  170. OBD II Scanner
  171. spark plug question yet again
  172. Fast check engine blink
  173. ** Call Carson Toyota/Lexus for your Discounted OEM Lexus Parts **
  174. Seafoam in GS400?
  175. Torn Steering Rack Boot Q
  176. Replacement Right hand side Mirror for 05 LS 430
  177. Las Vegas independent Lexus shop/mechanic
  178. Help!!!!! Fast
  179. Flush Trans Or Not
  180. Engine stalls when decelerating
  181. someone please help !!!
  182. fabulous wiper blades
  183. 2 Qs about Bumper
  184. HELP NEEDED "2JZGTE VVT-i Compatibale ECU's"
  185. Lucas Transmission Additive
  186. problems with defrosting
  187. Emissions help. Failed sniffer test...
  188. engine sounds like intake
  189. suspension question
  190. knocking under the hood
  191. Oil Change at Toyota Dealer
  192. any good Lexus independent shops in DFW area?
  193. Need Labor Times? or help from Mitchell Repair???
  194. Is This A Door Actuator Problem?
  195. This might be a newb question but....
  196. O2 sensor brands make a diff?
  197. ball joints
  198. spark plug question!!!!!!!! help
  199. how many times do I need to change the transmission fluid
  200. Check Your Spark Plugs!!! Hesitation Fixed
  201. Need Opinions on "Check Engine" Problem
  202. Castrol Oil vs. Mobil 1
  203. Headlight Tilt
  204. Tilt/Telescopic Steering Column Problem
  205. Issues w/ my '94 GS 300
  206. K&N Recharge kit question
  207. Shift Lock
  208. AMSOIL ATF Universal
  209. oil filter study?
  210. Wheel torque spec? '96 LS400
  211. Engine oil leak
  212. GS400 going to go to the doctor soon!
  213. Oil&Filter Change on ES350
  214. Do our wipers have single motor/transmission?
  215. What kind of prep do you do for a long drive?
  216. changing the sleeves and other things
  217. Phantom check engine light on SC3
  218. Compression #'s for a 1994 LS400
  219. blue smoke/white smoke what gives???
  220. Red Coolant Question
  221. engine starts after 2 or 3 tries
  222. GS cabin air filter replacement
  223. DIY Oil Change and Warranty
  224. Parts Pricing
  225. Hood cable replacement
  226. Repair List on My GS!?!? Help?
  227. Do quick X-minute oil places use OEM filters??
  228. what synthetic oil do you use??
  229. Dealer Service ......... How Often? Is it worth it?
  230. GS300 won't start - low compression
  231. replacing valve cover gaskets
  232. LS400 tunup parts prices?
  233. Oil change
  234. Best place for an oil change in SoCal?
  235. NGK Spark plugs
  236. 2000 GS300 Engine Coolant Drain Plug
  237. '96 LS400 Maint. questions
  238. 94 sc engine cuts off
  239. Alternator Wet
  240. Car won't start
  241. Maintenance parts for 01 GS300?
  242. Servicing a Lexus GS at a Toyota dealer???
  243. Smelly Engine?
  244. wheel HUB maintenance
  245. 2000 GS400 automatic climate control problem...please help!
  246. OMG what did they do! brake pad thread.
  247. some kind of beeping alert sound
  248. Bad Vibrations, '98 GS300
  249. Please help. Can't rid vibration on 98 LS400
  250. Bleed Brakes On Ls 400
