Dimming headlights with other control use?
Old Mar 10, 2007 | 07:05 AM
fallabel's Avatar
fallabel
Default Dimming headlights with other control use?
1995 ES300, 130,000 miles:
I've noticed that when I've got my headlights on and I press the brake pedal, my headlights dim. The same thing happens when I use the window controls. Once in awhile, the airflow out of the vents slows down somewhat under the same conditions (the airflow part might be shoddy memory on my part, but I'm pretty sure that I recall that happening).
Is this a battery or alternator issue, something else, or just to be expected?
Old Mar 10, 2007 | 06:37 PM
CUMan's Avatar
CUMan
I've owned my 94 ES for almost 13 years now, and it is on its fourth battery.
With each different battery, the headlights have dimmed when the brakes are applied.
I have checked the voltage numerous times when the car is running at various RPM's, and it has always been around 14.4 volts. Obviously, there is no problem with the alternator.
I think this is a common condition in these cars.
Old Mar 10, 2007 | 09:29 PM
92ES5sp's Avatar
92ES5sp
Smile
This behavior is normal with any car, however you can reduce the dimming by cleaning all of your grounds. There is some kind of grounding kit available for the ES (do a search). There is really nothing else you can do.. But make sure grounds are good as Toyotas typically have corrosion problems... My rear defogger really sucks the amps...
Do.Man
16
May 23, 2020 08:04 PM
nicks88
26
Feb 7, 2011 10:09 PM
spxChrome
Jul 7, 2006 09:07 AM
JenzLEX
Lighting
Mar 28, 2004 10:06 PM
Din
Aug 27, 2002 04:10 AM
