Changing rear wiper insert on RX330
Old Apr 19, 2007 | 12:26 AM
Nept_Mica's Avatar
Nept_Mica
Default Changing rear wiper insert on RX330
How do you replace the rear wiper insert on the RX330? I couldn't fnd an easy way to remove the wiper blade from the arm. Does anyone have any tips or suggestions?
Old Apr 19, 2007 | 05:48 PM
Nept_Mica's Avatar
Nept_Mica
No one has replaced their rear wiper insert?
Old Apr 20, 2007 | 06:17 AM
bob2200's Avatar
bob2200
It it's like the RX300 (even my 1972 Mercedes was identical), you need to first slide out the stainless steel long, thin pieces on each side of the insert. I usually grab them with pliers. Then, the insert is easily removed from the prongs. Assembly is just the reverse. It only takes a mechanic about a minute each.
Old Apr 20, 2007 | 03:41 PM
Nept_Mica's Avatar
Nept_Mica
The rear wiper is different from the front wiper. How do you remove the REAR wiper blade from the arm?
Old Apr 20, 2007 | 03:51 PM
VVT-i's Avatar
VVT-i
Remove the plastic cap at the base of the wiper arm first this cap covered up the bolt that hold the wiper arm to rear hatch). Then you just lift up the wiper arm and slide out the wiper blade.
Old Apr 20, 2007 | 05:50 PM
Nept_Mica's Avatar
Nept_Mica
Thank you for the reply VVT-i!
I was able to remove the plastic cover that covers the bolt and lift the wiper arm away from the glass. Now this is where I'm confused... just pull the insert out from the wiper blade? or how do you slide the wiper blade out?
Please help me understand.
Old Apr 26, 2007 | 09:47 PM
Nept_Mica's Avatar
Nept_Mica
No one has any info on the rear wiper?
spacecraft
May 31, 2013 05:51 AM
ak11
Apr 12, 2013 09:42 PM
rfcbuf
Dec 29, 2012 02:28 PM
jeff618
Hybrid Technology
Jan 25, 2012 12:17 PM
wilnis
Sep 15, 2006 06:47 PM
