Oil&Filter Change on ES350
I had a dealer tell me that to change or access the oil filter on the new ES350 that the car has to be jacked up or on a lift. This would be a major pia to a diy. Does anyone know if this is true?
You just have to jack the car up high enough to get to the filter housing. The ES350 uses the metal housing that you have to remove to change the filter element.
First, you NEVER want to be under a car while its on a jack, its just not safe! The Ramps will be more than high enough to do anything under the car you want to, from tranny fluid to diff changes.
I just completed my first DIY oil change on my ES350 and didn't need to elevate the car at all. Both the drain plug and the oil filter canister are easily reached from in front of the passenger tire and my oil drain pan fit underneath with enough arm room to maneuver.
Kudos to Lexus for the placement of the necessary parts. I've worked on some pretty inaccessible filters in the past, but this was easy.
I have ramps and jackstands, but that seems like a pia and too much work to just change the oil. Am also concerned about not getting a complete oil drain with the frond end up on ramps and not being level.
Is there any way of draining the oil from the filter canister before opening it up to remove the canister?
Thanks again,
All in all it's much cleaner than the conventional spin on oil filters.
Here's the oil change procedure for the Avalon which is identical to the oil change procedure on the ES350. Like I said before, elevating the car is not necessary.
Avalon Oil Change
fetv
19
Jul 1, 2016 12:06 PM
tmag
May 13, 2008 09:00 AM
