'96 LS400 Maint. questions
Old Nov 27, 2006 | 05:46 PM
Banshee365's Avatar
Banshee365
Default '96 LS400 Maint. questions
Hey guy's. Mother has a '96 LS400 with 162k miles running strong. it's idling a tad rough, my thought it plugs and wires, since they are probably original. I do not think the timing belt has ever been changed. Since it is an interference engine (I think) in this year and model a timing belt failure is not desirable. Being mechanically inclined I'm thinking about doing alot of maintanance on the car over the next few weeks including possibly:
*Brakes need some work
*Timing belt
*plugs and wires
*possible transmissiong flush, although it was changed at around 100k I think
Does this look like a good start, doing the plugs, wires, and timing belt at the same time would be a must. What else would you guy's recommend. The car just got repainted and we would like it to run a while longer. I don't hear really any odd engine noises and it drives like a new car. I'm changin the engine oil today and want to catch this stuff before a major failure occurs. Does the water pump have to be replaced with the timing belt or is it just a good idea to do so? Thanks guys.
-Kelly
Old Nov 28, 2006 | 09:23 AM
damon's Avatar
damon
By all means change the water pump. You would hate to have to tear it all down again when it does it fail.
Old Nov 28, 2006 | 09:46 AM
GRAND_LS 4's Avatar
GRAND_LS 4
3UZ-FEEEE
I would also change the PCV valve of course, clean the Throttle body, and MAF (optional), and reset the ECU fuse (you need to do that if you clean the MAF.)
I would at least do one or two drain and refills to the transmission. Then check power steering, and brake fluid.
Moving to the maintenance forum...
vindell
Mar 23, 2013 12:42 AM
dspete
13
Sep 5, 2011 12:09 PM
1killerls
46
Aug 15, 2011 12:25 PM
rosieski
15
Jan 28, 2011 09:20 PM
umair55
Aug 24, 2008 10:23 AM
