Flush Trans Or Not
Old Jan 18, 2007 | 02:45 PM
rg_gibson's Avatar
rg_gibson
Default Flush Trans Or Not
Hi Everyone I Just Got My Transmission Flushed At 133,000 Miles And I Have Been Hearing That Sometimes Its Not Good To Flush Out Your Transmission When You Havent Done It Before Because The Loose Particles Floating Inside The Trans Can Save It But I Havent Had The Car Very Long So Was It A Wise Choice For Me To Flush At 133,000 Miles Or Was It A Bad Choice?
Old Jan 18, 2007 | 03:10 PM
Lexmex's Avatar
Lexmex
Well, how does your vehicle feel now, how does it shift?
Old Jan 23, 2007 | 02:40 PM
mikeloc24's Avatar
mikeloc24
only time will tell...
Old Jan 31, 2007 | 03:23 PM
narfy's Avatar
narfy
flushing your transmission doesn't really do much in terms of bad for the transmission... at our shop, we do flushes on new and old cars alike.. and we have never seen a transmission fail or leak as a result of doing a flush...
Old Feb 1, 2007 | 11:19 PM
GSteg's Avatar
GSteg
If your transmission if fine now, just do a normal drain and refill procedure. I dont see the point of flushing right now if your tranny is working find. Dont fix what's not broken
Old Feb 4, 2007 | 12:13 PM
tech169's Avatar
tech169
I would do a transmission flush every 30k miles.It flushes out all of the fluid unlike a drain and refill.A drain and refill only takes out 2 to 4 qts of fluid.Where a flush takes out all of it.The flush machine I use uses 17 qts of fluid.
zran22
Feb 27, 2018 09:18 AM
gmann
RX - 1st Gen (1999-2003)
57
Feb 16, 2010 01:51 PM
ontoy
Apr 16, 2009 09:27 PM
surflife5
Maintenance
24
May 26, 2007 07:30 PM
