oil
Old Oct 30, 2002 | 05:18 PM
fierce gs's Avatar
fierce gs
Default oil
just took my car in for 15k service and gave em some 10w30 mobile 1 oil....they used it, but when i got back the service rep told me to use 5w30 next time.
but, when i took it in for my previous oil change, the tech told me to use 10w30...what are the pros and cons? ive been using 10w30 ever since i switched to synthetic (7k miles)
thanks.
Old Oct 30, 2002 | 06:16 PM
BananaGS's Avatar
BananaGS
Tech Guru
mostly depend on where you live (ie the weather temp...)
but they are pretty much the same, 10W or 5w, do a search. no pros or cons between using one or another. I would stick with 5W, because it's the recomended one.
Anh
Old Oct 30, 2002 | 06:20 PM
Daddy-O's Avatar
Daddy-O
10w30 is a little thicker...Good for warm weather. Not for cold starts.
Banana's right 5w30 is recommended. Can't go wrong there.
Old Nov 2, 2002 | 06:36 AM
kreativ's Avatar
kreativ
The techs know a heck of a lot more than the service reps., that's for sure.
In a warm weather climate, if you were to stick with dino oils, 10w30 is the preferred choice.
5w30: more VI improvers (not a good thing), thins out quicker (some have found to a 20 weight after only a couple K)
10w30: more stable, better NOACk value, less prone to breaking down.
For synthetic, it's less of a concern. "A synthetic 10w30 flows better than a dino 5w30, so anytime a car calls for 5w30 you can substitute 10w30 synthetic in it's place."
Old Nov 3, 2002 | 02:27 PM
fierce gs's Avatar
fierce gs
oops..lemme make a revision..service rep said 10w30, and the service tech said 5w30.
but anyways...that explanation makes me feel better =p
thanks for the responses.
Thunderwuf
Jan 17, 2015 06:15 PM
jkeifer3
Feb 15, 2013 05:55 PM
peeon
Apr 19, 2010 12:55 PM
ByoungWoo
Sep 23, 2007 02:43 AM
isam250
May 19, 2007 10:50 AM
