I replace the refills every 6 months. $11 CAD for both. Here's the part#
85214-50100
85214-30310
Replace is easy. Pull the old blade out, remove the metal strips, install the metal strips on the new blades, slide the new blade into the wiper. Sounds easy? It is easy.
The rubber compound is very important. This plays a big role in how long it takes for them to wear out as well.
Silicon wiper blades are the best for sweeping water off of glass. BOSCH makes great wiper blades for these applications. (Speaking of which I better go get some.)
Hope this helps
Use BOSCH if you go with a replacement blade because they work better than the other replacements
Have you ever noticed that factory replacement Lexus blades have a gray sort of graphite coating on them? I've never seen
any other blade with that slick gray coating. What is it?
Originally posted by gebo Have you ever noticed that factory replacement Lexus blades have a gray sort of graphite coating on them? I've never seen
my bosche blades came like that also... i think it's the compound in the rubber that makes it like that. ..
I remember the same Consumer Reports article referenced above mentioning that Toyota OEM wiper blade refills were excellent and performed very well.
Maybe you can get the same refills from a Toyota dealer and not have to pay the Lexus markup? My local Lexus dealer charges quite a bit over list price on parts. The Toyota dealer next to it charges just a bit over list. And a Toyota dealer further away is 40% cheaper on a lot of things.
