View Full Version : Suspension and Brakes
- JIC coil overs, rear shocks busted.
- LS400 BBK conversion on 99' 2GS..
- Replacing Front Caliper Lower Guide Pin
- Question about Rear sway install...
- Front suspension advice?
- Rear suspension upgrade / modifications
- any one rocking bc er series coilover ?
- Ugo Ukyo Carbon Fiber Upper Strut Bar Install with Engine Cover
- Brake job info needed
- after balljoint replacement does it need alignment?NEED TO KNOW ASAP PLEASE!!
- ABS Sensor
- Megan EZ coilover install on 2001 GS300
- To all the peeps with a LS400 Brake conversion..
- GS400 Tom's advoxs coilovers installed Pics
- Rattling Noise
- Coilover Spring Squeak?
- vsc abs light...need help
- Some advice please
- Has anyone tryed D2 coilovers
- Which sway bar first?
- bushings need help!!!!
- Will LS400 Calipers fit inside my winter wheels?
- Alignment stretched tires
- Installed K-Sports Coilover..... and snapped some pics
- Cover me, I'm goin' in! UCA and LBJ DIY
- NEED HELP ASAP GS300 with 20' setup.
- Need Help Deciding !! Megan eZ's or Espelir kyb Combo
- Part # for 2001 + GS430 caliper rebuild kit?
- VSC Reprogam
- rear rotors
- Seized brake Caliper 3rd time
- Need a smooth suspension setup< need help
- Broken Daizen Caster Bushin ?!?!?
- Weird Sound coming from the Rear
- Here is what I went with. Whatcha think??
- DIY instruction for throttle control motor w/magnetic clutch
- Anyone interested in an AP rear brake kit?
- OEM front lower Ball joints, caster arms and outer tie rods installed tomorrow
- Rear Carrier Polyurethane Bushing
- Wobbly suspension, please help!
- VSC issues . . .
- LCA's and UCA's from ebay...
- GS Freshly lowered!
- Caliper Bolt
- Daizen Sport RCA kit?
- Steering issue-need help finding reason
- RCA's
- new springs/ shocks=bump stops blowing out
- GS Terrible suspension problem...
- caster arm bushing where to get ?
- Wagner ceramic pad; help!!
- Steering problem after changing lower ball joints
- looking for coil over setup on stock rims
- URAS sub-frame poly, traction-on/off???
- Camber experts please reply! (I'm NOT on coilovers)
- Guidance on Coilovers
- Question about my tein flex..
- one more LS400 brake swap question.
- Having issue with Jic Magic coilovers
- '01 GS300 Rear Struts
- Best brakes
- coilover question
- 98 GS Brake Upgrade
- Pic Request - Megan LP / Megan EZ Street coilovers on 18/19 in wheels
- Strut/Shock mount part number
- Spacers
- Are coilovers for 1st gen gs the same???
- OEM VS KYB struts?
- GS350 brake to fit either gs400 or sc300
- Did anyone ever HAVE to replace their struts?
- Rear sits lower than other owners of espelier/ltuned combo
- Ball Joints Done at 94k
- MY hub on my rim is a little bigger then my hub on the car affect driving?
- 1998 GS 300 170k Miles Front Axle (Lower Ball Joint?) separates w/ PICS
- Lowering
- Brake Fluid?
- 2001 GS 430 struts
- front brake caliper dosent have bleeder fitting?
- blown LBJ...after 10k miles?!?!?!?
- Normal or no?
- GS SHAKE FIXED FOR $10 bucks…..
- Do IS300 sway bars fit GS?
- air suspension DIY
- please help. need reviews from h&R coilover users
- New Springs Installed
- Does anyone here track their 2GS regularly?
- Camber correction solutions. Front ? and Rear Mega Arms?
- Suspension Problems
- My GS on 370z wheels,LS400 Brakes, Teins & SAGE RCA
- 99 GS300-Rear calipers are leaking while bleeding front?
- BC Racing coilover adjustment
- Anyone know where i can get Bremo Grand turismo brake rotor
- FIGS Adjustable tie rod ends...renderings
- Anyone experienced blown megan coilovers???
- Question with picture - seeking a bushing :-)
- SHAKES _ YES I have read numerous threads...(diff type question tho)
- Just a lil concerned...
- Decision For Spring
- Looking for New brake pads and rotors??
- Coilovers
- GS300: Spring Comparison
- nice day out/bc extreme installed
- Need help with rear bushing!
- You Zealand Super Stroke Up Kit ??
- how long to install caster arm (lower control arm?)
- Check your ball joints!!! Pics of the carnage.
- clearing the caliper
- question for those with rca
- brake fluid leaking
- LS400 brake caliper swap !!caution!!
- Returning to Stock
- Brake lights on dash!! WTF
- im on air now...
- Creaking steering noise (Video)
- 2 lowering questions??
- airrunner / uas question
- brake/rotor question!
- Anybodyusing megan or Ksport lowering springs?
- bc coilovers
- i need front caster arms bushing repair kit
- Stock ride height 2gs?
- Mechanic says left front strut is blown and worried that a fleecing is forthcoming
- Tein Flex Coilovers question
- Changing Brake Fluid
- noise coming from front brakes
- Springs...yes i said Springs!
- sring rate switch on D2
- Shaking Steering Wheel 60-70mph
- Clunking noise? help PLEASE!
- finally got my daizens installed
- spring rates for dumped guys
- NEWBIE<---- in need of some serious help ...buzzing sound coming from my brake pedal
- Rotora / Stoptech
- LS400 Calipers are finally on!
- Anyone know if tanabe sustec pro go as low as megans??
- Tire cupping
- S.O.S.! How do i fix toe wear?
- Stop the SQUEAL
- GS3/GS4 98-05 same suspension?
- Question about strut bars
- HELP!! Stripped Threads on Caliper!!!
- Flush Set Up wth Stock Wheels
- Are the rear springs harder to install than the front springs?
- Megan LP or BC Raing coilover
- 2001 + brake master cyl
- I need some advice.
- please need help fining parts
- Where can i buy RCA now dayz ?
- Daizen Install
- quick question of coilovers
- Suspension Adjustability
- want to drop my gs
- BBK Question
- Brake install
- Megan EZ street coilovers
- Need help install BC racing Coilovers on 2GS..
- Stock Springs Sagging?
- Please recommend height setting BC Rcing Coilovers....
- suspension question
- Rear Bar
- Brake fluid flush?
- Lowering the gs 400 without buying coilovers?
- DIY - Replace Brake Master Cylinder Booster
- Questions regarding Megan Coilovers :LP Series
- Do work, son. Custom rear shock mounts.
- Difference between 02 to 03 Suspension (SHOCKS)
- Question regarding rear suspension removal.
- Link assy.
- Can someone please help measure front sway bar!
- New Rotors...
- Road Force Balancing w/ new tires+rims
- Wierd Noise From Rear Axle
- Tanabe NF210 Springs or Tein High Tech Springs?
- Outer Tie rod frozen - help?
- best set up for megan coilovers
- Some suspension ???'s about my new GS300.
- Replacing Ball Joints - what is this?
- Anyone got a real clear picture of the Brake Booster Line?
- Brake fluid level
- Ksport AirTech ADVISE
- i need some advice on how to make my wheels fit
- Tom's 6- Link broke. Need help to contact them.
- Confused about caster arm bushings vs control arm bushings!
- Supra TT Brake Questions
- Help...Lost caliper bolt
- GS350 wheels on a GS300 with LS400 Brakes
- Bushings and suspension question.
- GS 300 OEM Suspension Installed on GS 400
- Feedback from a member with aftermarket Upper Control Arms
- New to CL & Lexus
- (((squeking noise ? ? ? HELP!!!! )))
- Should front rotors spin freely? Mine dont..
- Front end clunk, ball joints, end links, and suspension please advise!
- 1IS vs 2GS OEM shocks.
- Warning lights on
- Coilover install questions...corners balanced?
- 3rd Gen Brakes?
- Need help on a part number...
- differences in 2nd and 3rd gen brakes?
- ABS lights
- Brakes
- Coilovers that work with UAS
- 2 Questions : Garage door opener + Brakes
- All this-and still the shake???
- Coilovers
- Tein Lowering Spring???
- suspension help
- Thinking of upgrading brakes...
- coilover suggestions!!
- BAD Rear Suspension SQUEAK!
- Ksport Springs
- Knocking noise when backing out of driveway
- Over-torqued sway bar bracket bolt
- Do you think these wheels will clear my Rotora's?
- First time in 3yrs/82k no squeak
- Thinking of going from DF210 to NF210
- Beck/Arnley Front sway bushings
- Brake Bleeding - Motive Bleeder attachment
- Suspension package??
- Need advice on buying new shocks !
- Brake Bias
- Brakes makes noise early in the morning when backing up.
- Euro brake pads??
- Slight shaking/vibration over 65 mph . . .
- Tip: Upper Control Arm DIY
- bcr coilovers drop with pics
- Sadly, I have to Agree
- changed brake master still soft pedal
- Electronic Dampening
- Would like your opinion's
- Sway bars TRD Blue & Diazen
- Anybody tried to swap Daizens from one UCA to another
- new brakes and wheels installed......
- Megan Suspension bottoming out...
- I'm lost! Coilovers or Bags?
- New UCA's and Caster Arms today
- Who makes rca's for gs300
- Greasing LCA Bushing
- Shine/tein ss/ profounds 2gs sacramento!
- LS400 BBK questions on ebay auction
- S-Techs and RCA's, which camber setting?
- Some supsension work ?
- Stock suspension and when I hit a bump small/big back slams on my passenger tire.WHY?
- -4 camber with front RCA..
- Best deal on Upper control arms
- What's the best deal Right now on UCA
- just got my wheels refinished and brake upgrade
- Master Brake Cylinder\Booster ... What years are the same?
