Wierd Noise From Rear Axle
Hello guys,
I put in the front and rear brake fit kits and shims, and as I turned the left or right rear wheels. I noticed that there was a wierd noise coming from the axle left and right while turning the left or right wheels. What could this be? Are the bearings, or any components on the axle where it joints with the other components gone bad? I have not taken the car to the dealer to find out whether this is a normal noise from the axle or something need to be replaced. Any suggestionns guys? Appreciate all the inputs you guys provide, and I will report back whether it is a normal noise or not. By the way, have you guys come across this kind of noise while turning the rear wheels? I took off the rear wheels a lots to time, but I did not notice until today I tried to spend the wheels to check the brake after I installed them. I am greatly appreciate any inputs from your experties, guys. Sorry guys, I don't know how to upload the sound file onto the forum only the zip.
As long as it is quite when you drive it, it should be fine.
You have a open diff. if the other wheel is not turning it will ratchet, normally the diff turns the wheel not the other way around.
...someone else may chime in with a better examination.
Hi guys,
I just have it check by the dealer and it is normal. It should makes some noise as the axle gears turn. However, they found another small issue which the both rear wheel bearings is with a little play when they rock the wheels up and down. I ask them how much they will charge for replacing the bearings, they say about $800. That is a stealer, alright. I ask the parts dept. and they quote for me for $90 a piece. If any of us hear some noises coming out from the axle gear box, it should be normal as stated per stealer. Thank you for looking out and your inputs, guys. Now I have to save money either to have them fix it or tackle this job myself which I have never replace any bearing before. Hope the DIY sections cover this one.
Hi guys,
90$ per bearing its kinda of expensive. Shop around.
Did they show u personally that the wheels move around...maybe its just a suspension part..... WHEN BEARINGS ARE GONE u will know it due to a very loud noise when u drive
Get a second opinion before you do anything...
No, they have not shown me for the bad bearings. they just told me when they rock the wheels up and down, and they noticed there was a little of free play on both wheels. When I put the brake kits on, I did not hear any rattle
noise coming from both wheels while I was turning them excepted the noise generated from the axle gears which was normal. I am definitely seeking anther opinions. I might go with the Exact Motor in Mipitas which about 1 HR or so of driving. I also check the DIY section and I could not find any procedure for changing the rear wheels bearings. Do any of you guys know what kind of special tools that I need to buy to tackle the task? Pl, keep the ideas coming...! Thank you so much, guys.
I believe the hub needs to be removed and the spindle needs to be pressed out separating the hub bearing.
IF - there was play when they checked, I would check the suspension, like alexdan mentions.
Rare that a wheel bearing go out on its own without a impact or something and extremly rare that both go at the same time.
What is the mileage on the car?
if u search and look around the website u will find a workshop manual ....look in there
http://bahamutcars.free.fr/workshop/...nts/index.html
Bumping this thread to see if this may be my problem as well using the pictures with the circled area above. I installed new wheel bearings with no help. 4 sets of tires with no change. Changed rear diff fluids to Royal Purple with no change. Noise is constant, but gets a little more quite at hwy speeds. I am thinking it may be the bearing that connects the axle to the differential as in the picture above since wheel bearing did not solve my problem. Car only has 77k miles on it and noise seems to only come from the right side rear.
