Old 01-07-15, 12:33 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Steering and Suspension
Print Wikipost
Steering problem after changing lower ball joints
Old 02-05-11, 02:45 PM
colombianc
colombianc's Avatar
Default Steering problem after changing lower ball joints
Hello all, I just recently took my gs430 for the replacement of the lower ball joints. After picking up the car, I notice that the steering feels loose....and the it feels like the power steering jerks the steering wheel. I've research but did not find similar problems. Any ideas or suggestions? Thanks CL.
Old 02-05-11, 04:28 PM
Arcadian
Arcadian's Avatar
Could be 'stiction' in the new ball joints, which I've had on other cars. It goes away in time. Or they screwed up the alignment.
Sounds like something worth calling them on to fix on their dime.
Old 02-05-11, 06:05 PM
Sixdown
Sixdown's Avatar
My car does the exact same thing, although it got a little worse after I changed the lower ball joints. I even changed the tie rod ends and that did nothing. The car wanders all over the road and I have to constantly correct the steering. I've gone over all my suspension components and I've come to the conclusion that my steering rack is crap.
Old 02-05-11, 06:08 PM
5t341th
5t341th's Avatar
was an alignment done after the balljoints were replaced?
Old 02-05-11, 08:25 PM
porn-adkt
porn-adkt's Avatar
Did you get an alignment?
Old 02-05-11, 11:47 PM
YviE
YviE's Avatar
I thought an alignment wasn't necessary after a LBJ replacement? For tie-rod ends it would be.
Old 02-06-11, 04:33 AM
diamondmit
diamondmit's Avatar
Default Check the steering rack bushings....there are 3 bushings to replace.
If these are worn, the newly replaced ball joints will be "stiff" and have little play. All the play in the steering will then come from other worn components. The steering rack bushings **may** be the culprits. I'd also check the control arm bushings. This is something that the tech doing the ball joints should have pointed out.
Old 02-06-11, 06:19 AM
colombianc
colombianc's Avatar
Aligment wasn't done
Old 02-06-11, 07:04 AM
SorrGwa
SorrGwa's Avatar
get the alignment done.
my steering was screwed after i changed my lower ball joints.
the alignment fixed it right up...
Old 02-06-11, 07:28 AM
GSteg
GSteg's Avatar
Most of the time the alignment will be off if you change your lower ball joint. If it's worn, then your alignment is already out of spec. Your toe is probably screwy, and that changes the steering quite a bit.
Old 02-06-11, 11:08 AM
fasted1953
fasted1953's Avatar
When I had my lbj's replaced as a precaution, the mechanic said that the camber arm bushings were totally shot. Replacing the camber arms made the car handle like new again.
Old 02-08-11, 06:05 AM
goodbuds
goodbuds's Avatar
alignment needs to be done
Old 02-08-11, 09:10 AM
porn-adkt
porn-adkt's Avatar
General rule is when ever you do suspension work, alignment should follow to check for OEM specs. whether or not you notice it is a draw of the straws. a few MM may change how your car feels some of us are more keen to feel prior to and after work has been done.
Alignments only go for $70 which is not much considering all the work and effort put to replace/maintain 11 year old parts.
So the answer is Yes, alignments should be done after suspension work. since the eye wont pick up on 3mm +/- differences resulting from part replacement or modifications including wheel and tire change
Old 02-08-11, 03:17 PM
colombianc
colombianc's Avatar
Thanks for all the input, I have a friend who's brother works for Lexus, he will be looking at my car tomorrow. I want to see what he thinks and an aligment will follow.
Old 02-08-11, 04:57 PM
Ceezo
Ceezo's Avatar
I did my Ball joints and my steering was drastacally better...id say check bushings and get an alignment
Quick Reply: Steering problem after changing lower ball joints
