View Poll Results: what to you want?
I want endlinks
19
38.78%
I want tie rod ends.
30
61.22%
Voters: 49. You may not vote on this poll
FIGS Adjustable tie rod ends...renderings
Here you go guys, are you interested in these to eliminate bump steer on slammed cars?
Just finished up the design today. Three spacers to stack or more if you are really low....along with adjustable front endlinks.
front sway endlinks
trying to gauge how many to order.
front sway endlinks
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
I want both, but I prefer getting rid of my bump steer first. I'm not that low but damn I hate bump steer. I especially hate it when it's due to bad alignment grrrrr!
I'll pick tie rods and will buy the end links too when they are available.
Lowering a car can induce bump steer as the geometry of the tie rod in relation to the control arms is now off at ride height. So to compensate for bump steer problems common methods are to space the tie rod ends to change the angle of the tie rod, sometimes the tie rod is flipped over to the other side of the spindle mount, and sometimes the steering rack can be raised.
My bagged Ranger had serious bump steer, I used a Mustang bumpsteer kit which was just a pair of longer tierod ends with spacers on it, and I also made some spacers to raise the steering rack up 1".. The combination helped get the tie rods the be parallel with the control arms (at typical ride hieght) and it made a drastic difference in both steering control and tire wear.
I'm in for both tie rod ends and endlinks but could only vote for one, it looks like my future Fig's order is gonna be bigger than I thought..
Here a pic of the Steeda Mustang bumpsteer rod ends I used on my truck, and an installed pic on a mustang for you guys to visualize what this part is and where it installs.
It's a tierod end replacement with a machined pin that allows spacers to be used between the spindle mounting hole and the tierod end. So you can adjust the angle of the tierod to become closer to parallel with the angle of the control arm.
perfect explanation!
Also sorry I forgot to allow multiple answers on the poll. So qty noted.
__________________
Wait, what if you have RCA... doesn't that also help lower the car by the height without affecting bumpsteer? So for example, if you have a 1" RCA, you can lower the car by 1" and still be at oem spec.
But I'm sure ppl here are lowered way more than 1" so this would still help alot.
__________________
An rca may lower the shock mount by lowering the lower arm, and may take some stress/angle off the ball joint which is good, but it is indeed changing the geometry of the front suspension because the upper and lower control arms are no longer at the same horizontal positions in relation to each other. You are opening up the angle wider which can change handling characteristics, steering, and caster.
A 1" rca is likely to have no noticeable change, but is typically coupled with large drops which can cause issues.
Bumpsteer kits usually come with a few different sizes of spacers, allowing to add a combination of sizes together to achieve the proper adjustment for different suspension installs/heights.
The other positive of an aftermarket bumpsteer kit can offer is more travel range using a heim joint instead of a typical limited range ball joint style rod end. This can take some stress off your tierod ends due to being extremely low and the joints hitting thier max angle during suspension travel and you may not even realize it, which could be shortening the life or tear the boots.
And as far as the car being in-oem-spec with just rca's, realize that getting the camber/caster/toe into oem specs sitting at ride height does not guarantee no drivability difference's or accelerated/abnormal tire wear. What the travel range does to camber/caster/toe during travel on a modified suspension can be way outside of how it would change in a oem height / oem aligned suspension. Especially if the horizontal relationships of the tie rod/controls arms/caster(radius) arm have been altered. Sway bar relation to the control arms can induce handling differences as well.
All these adjustable products that I see Figs bringing us for the 2GS is great, as ideally if you replace all the suspension parts on the car with adjustable parts or parts with larger/corrected range of motion, then you are able to dial in a very good riding car that is extremely low but can have good tire wear and not be stressing the mounting points at the max of thier usable range.
