- TCM Covered by Powertrain Warranty
- Disappointing dyno day FBO tune ISF
- Club Lexus Members Show off Their IS F
- Think the stealership is trying to screw me..
- 1st Lexus ISF on BAT
- Adding parking sensor holes to front bumper
- Transmission in auto mode
- Iphone not connecting to Bluetooth Audio
- KW Coilovers Uneven adjustment
- lexus rx making unwanted phone calls
- Best front tyre size to match 285/30
- Lexus IS-F: Suspension Walkaround
- PPE EL Headers + Mid-Pipe + HKS SSM
- Lexus leather material
- Can I go from Royal Purple to Mobil 1??
- Rr-racing USRS autocross test
- Another custom Magnaflow muffler option 11366 or 14363
- Rear tyre just died....RIP
- Please help! Looking for EU spec ISF mirrors
- EU spec headunit in US spec ISF
- Should I sell
- DFW ISF Owners: Request to Meet
- LED turn signal bulbs on 08 isf?
- Its a HELLCAT in a Lexus body THE 2008 LEXUS ISF review
- FYI 11MM Adaptive Spacer will not work with OEM 12+ Wheels
- Enkei PF01 with CUP2 tyres - impressions
- Track Day at Auto Club Speedway Oct. 15th
- Alignment Advice
- RCF Motor swap?
- Car died at the track, P0162D and P0162E codes
- ISF - Cayman S lap @ track day
- Logging software
- Brake Caliper Torque Specs (Front & Rear)
- Burnt metal smell after header install common?
- isf - M2.
- Did any one consider purchasing the CTS-V before buying the ISF??
- Where did this cap go that i found on engine under cover?
- Check Headlight System
- OEM Touch screen partially unresponsive
- Installing Cat to Greddy Titanium Exhaust
- Need advice
- Techstream 10.30.29 Registration Key Needed
- Bangin Gears at the track new PB.
- Lexus isf to camaro zl1....a farewell
- Spark plugs genuine ????
- Thoughts on the 2UR-GSE cast pistons and longevity with boost??
- Need a shop to install lowering springs near Chino Hills CA
- Wheel Advice Please - Wedsport RN-05M
- Poor idle after spark plug change
- Colorado IS-F cruise (Bishop's Castle)
- Will these wheels fit?
- Drop (leak) down test (nitrous user)
- Going to get back into the ISF world... advice
- Newbie Wheel Question
- Another winter tire/rim question and TPMS
- Where are the the tire deals?
- What do you guys think of this price on 08 ISF? Thinking about purchasing.
- OEM IS F Accessories
- I hate potholes
- Buying OEM bodywork
- Leaking Timing Chain cover
- sound systems
- high mileage IS F, should I be scared? need input
- Anyone going to the WannaGoFast event in GA this Sat/Sun?!
- Does this look right? (Front Suspension)
- Ebay CF trunks?
- Gorgeous 2012 in TX
- ISF from Nola to SoCal
- Newbie question!! How reliable on isf engine?
- HPFP seal?
- What do ISF owners think of RCF?
- Brembo alternative brake pads at autozone relatively cheap
- Am/sat won't switch to sat
- 275/35/19 on rear
- Step by step DIY pics RR Racing Tuned intake install
- coilover comparsion
- HPS Intake Elbow + aFe Oiled Filter Dyno Results
- Best Model Years for ISF with V8
- Fuel Panic in SA
- Please help 2008 isf check ac connection
- More 1/8 mile dig action
- 275/30/19F 9in rim with 295/30/19R 10in rim would this work?
- Anything I should know before purchasing an is250?
- Has anyone thought of E9X M3 before getting the F? Or any previous owners of the M?
- ISF to Type R
- Valve seals
- Fuel Gauge not Responding to Full
- ISF Cracked Radiator...
- 2010 ISF Borla Exhaust
- Lexus IS F vs C63 amg and other
- Looking for a ISF help?
- Still have inner tire wear even with the USRS!
- RCF rotors on ISF
- Airbag and Cooling Fan Recall Service
- 2018-08-12 - Pocono South and Southeast Configurations with NASA DE3
- My IS F search has begun!
- Clicking noise turning wheel? *video*
- Help! Windows won't go down - trunk won't open
- ISF under water?
- Recommendations for shops in Atlanta to get coilovers adjusted
- If the Valet Trunk Lock is activated, can you stilill unlock it with the keyfob?
- New tires kick Ass
- 05' Lexus LS 430cruise control won't stay set!
- Enkei RPF1 18s on ISF
- Enkei Draco
- Shifting issue... normal?
- 3 lug bolts have failed in the past 2 weeks...
- Headlight Bulb Replacements
- Replacement Rear Bumper Cover - OEM vs. Aftermarket
- Anyone running the Textar branded OEM brake pad instead of "Lexus" brake pad?
- Novel headers bung question
- New To Me - 2008 MRM
- New To Me - MRM
- FYI: JDM Window Visors Part Number
- Lexus IS F ecu tune dynorun
- Should I buy this 2008 ISF?
- Bulb SIzes in 2008 IS-F
- CEL after installing PPE headers RR tuned intake and exhaust.
- Normal for OEM header?
- The right price for IS-F
- New LEMs diffuser?
- Rear tires - Tread differential tolerance
- Road noise
- Radiator replacement DIY?
- Looking for recommendations on 2008 ISF aftermarket replacement headlights
- Lexus F Exclusive Meet 2017 @ Lexus Escondido pictures thread
- The Worlds First 360 Degree Lexus IS-F Track Day Video !!!!!!!
- Glad to be back on IS-F again...
- Slow Track/1/4 Mile Time
- Exhaust setups under 90db (Circuit sound restriction)
- Opinions on this 2008 ISF?
- Rear tires
- Any tips on shifting the subframe to correct uneven camber/caster?
- power steering issue
- 2012 ISF for $39k, any issues?
- Lumbar support intermittent
- Rear AC Console vents
- Spare Wheel Lexus RCF Carbon
- SO. CALI ISF with ppe EL headers?
- RCF meets ISF video - what do you guys think?
- Need help choosing tires
- Obsession or Passion
- Anybody replace the front strut dust boot/insulator with a universal one?
- ISF's in Colorado?
- VSC Off Yaw Rate Sensor Malfunction ISF 2009
- New episode of Project Lexus ISF!!!
- First time Lexus owner
- My dyno w/ new SIKKY V2 headers
- For those scared of RR Racing USRS... and a Shout Out!
- Rear view mirror loose
- MRM Lexus IS-F with HRE wheels and Tom's Kit
- Transmission Fluid Question
- Ohlins Road and Track FIGS ISF Specific
- A/C drain tube?
- Sikky sway bar install guide
- Found this on 2011 ISF service history. Concern?
- ISS Forged Exhaust
- is300 2012
- RR spark plugs
- Allow me to reintroduce myself... (also, a WTB thread)
- F Exclusive Meet August 20th
- First Supercharged RR Racing GSF
- Those with PPE dual mode exhaust please help.
- Lets play: What's That Horrible Sound! (Video)
- Is anyone running the TTFS tune...?
- Top mount orientation
- Brake light goes on and off ? On my dash
- WannaGoFast today Hot springs, VA!
- New Wheels and Tag on my Supercharged ISF
- Brake grooves/warping problem?
- RR-Racing Carbon Fiber Intake vs HPS
- Racing Line Video...GSF/RCF/LC 500 Race Randy Pobst vs Justin Bell
- What do you guys think of my ISF video?
- Ikon Motorsports Front Lip Quality/Fitment
- The most angry lexus isf review
- Rrracing carbon intake elbow quality
- Life After ISF
- Clunking NS400 pads part III: conclusion
- Bad MAF?
- If you downgraded what would you get?
- Advice on Wider Tire Setup
- Display screen not working
- New SoCal ISF Owner
- Oil change before track?
- ISF... with 333,000 miles
- FS threads go only in the classifieds, not here
- Need Advice - Carwash Employee damaged my wheels
- Anyone add shock sensor to OEM alarm?
- 150k Mile Maintenance
- Headlight trouble need suggestions
- Question about JoeZ PTS exhaust
- Long Crank (like more than 7 seconds) and random misfire
- best coilovers and suspension mods.
- 2012+ ISF Swift Lowering Spring anyone?
- RR Racing - USRS - Squeaky as a rusty gate!!
- My melting door panels.
- gas mileage with Borla
- What to look out for in 08-09 F's?
- Performance tires for the track and such
- Transmission Fluid Temp High at Cold Startup
- Mark Levinson... sounds strange?
- 2017 Lexus Performance Driving School - Daytona int'l Speedway!
- Would you upgrade to a 4.0L Twin Turbo V8?
- Help with RR Racing Air and Oil separator
- Diode Dynamics LED Fog Lights Quick Review and Install Experience
- Plugging in my phone and playing music
- Shark Fin Question
- Exhaust issue with ISS DES and stock headers
- all weather mats for 2012 ISF?
- Cold Air Intake mod
- Mark Levinson Subwoofer Issues
- Front parking sensor wire harness
- Key hole cap
- Baby Car Seat Protector advice for ISF
- I have an isf with boltons and i need a help (more power)
- Carbon fiber
- Will 08-10 eibach kit fit a 2011 car?
- Brake pad question
- Clicking driver's seat
- 2010 IS350C F SPORT Fr Bumper Cover
- Trying to gauge interest in having Bilstein build B8 for ISF also RCF&GSF
- Lower Ball Joint Boot Cracked/Leaking
- airbag light on after airbag recall
- Oil Level Low Light Came On, but Oil Level is Okay
- Ever drop the "ice cold ac" line?
- RR Racing USRS Install
- Niche Invert 20's
- Regina ISF's
- limp mode?
- IS-F Motor Subframe Torque Specs
- Flocked Dashboard? Couple of questions if I may??
- 2008 isf wont start!!!
- Lexus Meet
- My new show offs
- Front Fender Liner: What do yours look like?
- engine bay part?
- Kicker Hideaway or similar powered sub installs?
- Clear coat on hood peeling
- A Quick Remark on the F Community
- Amplifier repair (ML amp)
- Steering Wheel Emblem
- Coolant level question
- Can someone explain this solid or hydraulic
- Upgrading Shocks from 2010 (Bilstein or 2013 OE)
- Speed through the gears
- for those of you with engine ticking
- 78works tail light install
- My IS-F from Germany
- Stock air intake
- Rear tyre size
