HPFP seal?
Old Sep 9, 2017 | 07:22 PM
Sanman20l's Avatar
Sanman20l
Default HPFP seal?
Curious if one of you guys has a guide to remove and check a high pressure fuel pump?
My car is not throwing any codes but I have what looks like a very small leak coming from the seal of the pump. I figured if I was going to change the seal might as well check if the pump is properly working at the same time.
any help or a point to the right direction would be appreciated. Hopefully, not in the direction of the stealer ship.
Thank you for your time,
Carlos
Old Sep 10, 2017 | 10:53 PM
lobuxracer's Avatar
lobuxracer
Tech Resource
Remove and check? How would you propose to do that? If you connect Techstream to the car, you can see anything and everything you want to see from a fuel pump performance perspective. Maybe you don't trust the dealer to give you the straight story, but Techstream will not lie to you.
RamAirRckt
May 8, 2025 01:20 PM
dishon22
Oct 15, 2020 10:23 PM
gtsfire
Jan 25, 2016 07:15 PM
kuyayan
Feb 6, 2011 09:25 AM
epicaudio
Sep 1, 2010 07:18 PM
