Long Crank (like more than 7 seconds) and random misfire
Anyone ever encounter this? Once in a blue moon, ill have random misfire when coming to a stop. The whole car shakes like 2 cylinders are dead. And then it goes away.
The other issue is long cranks. On a rare occasion, the car will crank for about 7 seconds before it hesitates to fire up. I never really cared much, but today, I decided to care and ask you guys. Normally, it fires up after about a second.
I have changed the plugs 5k miles ago, new battery recently, new rear O2 sensors about 5k miles ago, new air filter, and changed fuel brands to see if it was a bad batch of fuel. 52K miles on my 2012 ISF. No codes.
my guess is try that or some BG 44K.
i had the slow start issue for awhile my brother recommended the red line fuel cleaner https://www.amazon.com/Red-Line-Comp...system+cleaner
yeah ive tried fuel system cleaner. Maybe I'll try bg44. Thanks.
If not, I'll just pull the injectors and get them flow tested and cleaned.
