Will these wheels fit?
Old Sep 24, 2017 | 09:59 AM
twinpuller's Avatar
twinpuller
Default Will these wheels fit?
I'm looking for a decent 18" wheel that will fit the ISF for my winter tires. I came across these Katana RC10's that are reasonably priced and look half decent. Can you wheel experts tell me if these will fit?
http://katanawheels.com/wheels/?ID=RC10-7701GBR
18x8
40 offset
5x114.3
73.1 CB
Thanks!
Old Sep 24, 2017 | 01:22 PM
kzlflash's Avatar
kzlflash
I have 18x9.5 +40 on stock suspension and I have no issues with rubbing, etc.
The big question would probably be brake caliper clearance.
You should check out the aftermarket wheel thread, and search in there. I'm sure other's have asked the same question.
Old Sep 24, 2017 | 01:31 PM
tas02's Avatar
tas02
With 18's on an Isf you really have to test fit to see if it will clear the front calipers.
Old Sep 24, 2017 | 03:21 PM
twinpuller's Avatar
twinpuller
that's what I was afraid of. I'm going to have to see if they will give me a refund if they don't fit.
Old Sep 24, 2017 | 06:07 PM
twinpuller's Avatar
twinpuller
what's the ideal offset for 18x8 rims?
Old Sep 24, 2017 | 09:29 PM
msgs350's Avatar
msgs350
in addition to offset, what's the disk spec on the rims? Most vendors won't give you a refund once you mount wheels on the car.
Old Sep 25, 2017 | 08:27 AM
twinpuller's Avatar
twinpuller
That's a new one to me. Do you know what the minimum disk spec should be?
Old Sep 25, 2017 | 04:22 PM
tas02's Avatar
tas02
Originally posted by msgs350:
"Most vendors won't give you a refund once you mount wheels on the car."
Ask 'em first. Just about any retailer says no refund once you mount the tires on the wheels.
Old Sep 25, 2017 | 04:24 PM
tas02's Avatar
tas02
Your "ideal offset" is +45 mm f & +55 mm r (i.e. stock offset).
Old Sep 25, 2017 | 05:10 PM
msgs350's Avatar
msgs350
yeah, I guess I should have put more detail into my reply. But factor in a restocking fee and shipping back for a mistake on the customer's behalf on a wheel that cost about $100 each...go ahead and return it and take that loss for not doin proper homework.
Somboa
IS F (2008-2014)
Dec 27, 2017 01:08 PM
Ltaboso
IS F (2008-2014)
Jun 11, 2015 10:13 AM
Super6
IS F (2008-2014)
18
Dec 5, 2013 10:15 AM
KillaC
IS F (2008-2014)
Apr 26, 2013 04:14 PM
zazzn
IS F (2008-2014)
15
Nov 1, 2012 06:12 PM
