View Full Version : IS F (2008-2014)
- Radiator fitting for pressure test on ISF
- Headlight compatibility
- P0138 O2 Sensor High Voltage
- OBD2 Bluetooth to record a/f data live?
- ELATE MFG ISF Supercharger
- Custom Exhaust quad tip style
- PSA: Cabin Air Filter 87139-50100
- Need help - stumbling and lack of acceleration
- Intermittent CEL w/ codes P0420 and P013A from exhaust leak - damaging engine?
- ATF oil temperature light
- Transmission Mount Recommendations
- Windshield Replacement - OEM or Aftermarket?
- Rough idle at 500rpm
- Tire sizes
- New tires/coilovers
- IS-F Advice
- fuel smell underhood and hard to start after valley plate fix
- Advice on Purchasing a Lexus ISF
- Ticking idle low 500rpm
- Look for sticker "my other car is an IS-F"
- Airbag light on
- Are these Denso FK20HBR11 fake?
- My isF
- Bad idea to buy a cheap ISF..?
- Header Install Labor
- York PA
- Hooker Electric Exhaust Cutouts
- ISF Weird Noise
- Resistor for seat Airbags (ISF, IS)
- F runs terrible after an oil change, everytime
- Stalling once at temp - P0171, P0174, P1170
- So I did this today...
- Smogging Rule Changes? -CA
- Wideband?
- Weird exhaust sound following axleback install
- Brake Caliper banjo bolt and washer
- Did anyone just trade in a 99k 2008 ISF?
- Audio turns off randomly, power knob won't respond
- ISF Production Number
- GS-F seats in the IS-F - (HELP?)
- Quad exhaust for ISF
- Coolant and oil leak after oil change
- Chilton DIY Online is No More
- No accessories mode or ignition after accident
- IS F Paddle Shifters not working
- front bearing hub issue
- Should I keep my LS430 or get IS as a daily driver?
- Isf ecu swap
- Broken Headlight bracket causing leak?
- Tire size 2013 ISF
- Oil Filter Wrench from the Heavens
- Troubleshooting some codes (solved) P1170, etc
- Custom airbag cover swap
- 2014 LED Fog Lights - Functionality vs Halogen
- Stock ISF dyno vs FBO dyno sheet comparison
- EFI explained.
- 2009 ISF TCM & ECM replacement due to Code U0101
- San diego reliable shops?
- Direct Injector Markings
- IS F 2013 Rattle to Clunk Noise
- Air bag control module
- Automatic Light Control
- Brake pads for your ISF
- Can someone help me value this IS-F?
- San Diego Copart 2013 IS-F
- Looking to Purchase an ISF. Any advice?
- Looking for a front lip
- Good shops in Northern California for ISF?
- 2012 IS F Deck Lid Not Latching & Solution
- Long Lost Returning ISF Member
- anyone have an RR racing coupon code?
- Magnaflow carb legal manifold
- ISF aftermarket exhaust availability
- Stereo system for ISF
- P0193 Code
- IS-F Real Power Chip - The Real One
- Electrical trouble (possible poltergeist)
- Electric load signal (ELS) - want to disable idle up with lights on
- car alarm with remote start
- U0101: Lost Communication with TCM on ISF
- Finally picked up an ISF..2013
- Steering wheel issue
- KEIN motor mounts.
- Isf value in todays market
- Clock and hazard button
- New Member - New Wheels
- Question about IS350 differential
- ISF Yellow Fog Lights
- C1511 - Steering ecu calibration
- Joe z exhaust
- Help getting an ISF in EU
- Questions on forced induction: boost levels and fuel
- Whose ISF is at the track in this video?
- 2011 ISF - Ripped front suspension rubber "boot"
- What are your thoughts on this build/buy?
- Trouble starting car in cold weather
- Vacuum lines
- Crashed 08 - looking for the owner
- IS F Nürburgring!
- LCA bushings to correct right pull?
- Converting supercharged isf to is250. Sleeper build.
- Trusted Las Vegas mechanic for the ISF
- Does 255/40/19 fit in rear?
- Front windshield washer fluid motor...
- Which headers do I have?
- Cluster display not working
- ISF exhaust tip fell off, what are my options?
- Buying a 08 ISF, any parts/upgrades I should look into for Black Friday?
- Wheel fitment question (19x10 in the front)
- 2011 Lexus ISF limp mode
- Is600 f
- I’m New and Need Help. Front Bumper is Shot.
- Check Headlight System after LED headlight install
- Potential Buyer: 2008 ISF with 33K miles value?
- Transmission failure?
- Oil drain won't seal?
- GSF Wheels & scrubbing
- ISF Caliper Thoughts
- Just Purchased a 2011 Lexus IS F
- Lexus IS F won't turn On
- Blank Navigation Unit + Center Console
- 19 inch tire/wheels, tire size?
- where did you get your new front bumper?
- 08 -> 14 OEM Suspension Upgrade
- Thinking of going to an ISF!!
- Supercharged ISF modifications
- IS-F fuel consumption (need data logging info)
- How do IS-F brakes compare to the Gen 2 F-sport Brake Kit?
- The perfect drive
- HELP! WHAT IS THIS ether net cable? 12' isf
- Most all motor Whp?
- GS F, IS F, RC F Brake Caliper/Rotor all the Same?
- Help (Car Audio)
- Out with old in with new
- New Lightweight Crank Pulley for the 2UR-GSE!!
- RC F manifold
- Help me, between two ISF.
- Upgraded Brembo Brakes Part# Confusion
- Valley Plate Seal Repair shops? - San Diego
- Aftermarket cats
- Defoulers Needed
- Fender rubbing
- Leather Seat Cover
- Work Meister S1 3 Piece help
- Lexus isf CCSR second intake cover
- Oil level low after sitting for three days
- 2012 isf
- How do I remove the third brake light?
- Faulty Radio / Stereo replacement with ISX?
- Alignment with aftermarket caster bushings
- HKS SSM axleback + Meisterschaft mid pipe?
- Chasing a creak/pop noise
- Another Transmission Thread: Replaced transmission and still in Limp
- PPE headers with stock motor mounts
- How to install the used cam timing motor?
- Stock wheel color 2012+ (powder paint)
- 2008 ISF 89,000m Value (NOT FOR SALE)
- ISF in NE Florida
- IS-F and other F car pricing
- Hard to shift out of manual mode
- Megan Racing control arm quality/long term review
- Can u mirror OBD Fusion to Grom?
- 2012 Lexus ISF best launching tips and roll racing?
- Anybody have a pinout diagram of ISF2011+cluster?
- Ticking sound resolved
- Iso IS F door panels
- Weird shifting
- Plastic piece fell into ISF center vents and now rattles when playing music.
- New 08 IS F, Air constantly coming out of vents and foam coming from vents
- Audio: AmpPRO 4 Amplifier Integration Interface
- 2012 lexus ISF with 75k code p1170
- Instrument cluster adhesive?
- Door panels
- Help pls. (Audio won't turn on after battery died)
- Toyota Techstream app
- Anyone using motec?
- OBD Fusion Question
- Spark Plugs FK20HBR11 (90919-01249) vs IKBH20TT
- LSD Diff required - ISF
- The 700hp ISF Club!
- AGM Battery Charging Voltage
- Front Sway Bar Bushing size
- 2010 rear springs
- One More Reason to love the IS F!
- 2014 IS F PPE UEL and GReddy Titanum video
- The meaning of replacing the water pump (2012, 50,000 miles)
- ISF Valve cover/Spark plug gaskets
- Aftermarket F emblem for front Fenders/Trunk
- Upgrading internals to maximize N/A HP
- Black plastic under engine cover?
- Driver side mirror part number for covers
- RUMOR: New Lexus IS F Coming Later This Year
- Rear bumper clips and bolts
- elastic coupling…..
- Engine cuts out between 3000 and 3500 RPM
- Square setup with OEM 19" X 9.5" wheels on front
- radiator failure = transmission failure. Transmission swap problems
- Grom VLINE2 for 2008 Lexus IS F
- Would these PPE Catted headers allow me to pass emissions
- Wheel fitment help
- Has anyone tried these - ELITE SERIES FOG LAMPS
- 08-09 isf and 3g “sunset shutdown” affect me.
- Finally picking up a ISF
- 2011 IS F wallet/credit card key
- Possibly Purchasing a 2012 ISF
- Auto parking brake?
- tapping/creaking noise from the front is driving me nuts
- Koyo radiator without transmission cooler?
- Will these F-Sport wheels fit the F?
- ISF * Inlet Manifold Removal * Port and Polish
- IS F direct injectors
- Where does front parking sensors conect
- First gear clunk
- Isf nav upgrade.
- Rear diffuser from shine auto project
- 2010 IS F In Chicago FS
- Navi screen out
- Exhaust
- Looking for OEM part
- AA80E Swap and Control
- Maximum Safe Piston Speed Redline
- Transmission grinding noise after transmission fluid change
- tire size
- sikky driveshaft bolts loosen
- Installing aftermarket steering wheel HELP!!!
- How much would you pay for this 2008
- Power Stop Track Day Pad PST-1365
- What's it Worth? Rebuilt title isF
- I am about to give up on my ISF
- 2008 lexus isf
- 2012 ISF Rebuilt title
- Ticking noise from under car
- Alignment doesn't feel right
- Steering wheel vibrates (like a playstation or xbox controller) at 75mph +
- Pre/Post Track Day rituals
- New dyno #'s for ISF FBO N/A and Supercharged
- 423k mile isf
- APR CF Mirrors
- Market price for a Matador Red ISF
- Anyone have pictures of Bank 1 Sensor 1 replacement?
- Seat Belt Bolt Torque Values
- Ideas and Guidance for improving suspension feel and performance
- Non-Navigation ISF
- HC Motion Aftermarket Headlight (21+ IS style)
- Clunking noise when breaking to full lock. Sometimes when turning at slow speeds.
- Tire setting Question(245/275 Setup)
- Recent valley plate cost?
- Low coolant?
- PCV valve hose
- Infotainment inoperable
