78works tail light install
Old Jun 19, 2017 | 11:27 PM
tsx2isF's Avatar
tsx2isF
Default 78works tail light install
Hi guys! So ive installed my tail light and they look great. No hyper flash but im getting the check vsa,traction control and brake light on even with the brake dis-engaged. Can someone take a picture of how its wired up?
Old Jun 20, 2017 | 04:40 AM
Vervish's Avatar
Vervish
Did you disconnect the battery before doing the work? You may have blown the brake switch relay..
edit: NM - the car would not even start if it was brake switch.
Old Jun 20, 2017 | 12:36 PM
Joker4096's Avatar
Joker4096
If no one posts up, you're going to have to test each wire one at a time to figure out the running lights, turn signals, etc. Or maybe this has something to do with a relay if it's throwing check engine lights.
Old Jun 22, 2017 | 08:46 AM
tsx2isF's Avatar
tsx2isF
I ended up contacting 78works and got it sorted out.
Old Jun 26, 2017 | 05:46 AM
DjMarkOne's Avatar
DjMarkOne
what was the issue?
Old Jun 27, 2017 | 08:12 AM
3nergiz3d's Avatar
3nergiz3d
Originally Posted by DjMarkOne
what was the issue?
The provided wire taps are very poor and do not provide a constant connection. I recommended he do it proper and solder the connections.
Old Jun 28, 2017 | 07:34 AM
Joker4096's Avatar
Joker4096
Are they not plug and play with the stock harnesses? Or at least the main bulbs?
Old Jun 28, 2017 | 11:59 AM
3nergiz3d's Avatar
3nergiz3d
They are plug and play, but they will throw codes. To rectify the codes, the provided resistor must be installed.
Imthatbyrd
Jun 6, 2016 12:05 PM
GroHZ30
Aug 6, 2014 09:00 PM
JSC4
Jun 18, 2013 05:34 AM
SethP
RX - 1st Gen (1999-2003)
Dec 20, 2009 09:04 AM
blkstealthpaid4
Oct 12, 2001 03:42 AM
