LED turn signal bulbs on 08 isf?
Hey Guys,
I recently did the 2011+ LED headlight conversion on my 08 isf. I also got the new flasher relay(#81980-06020) with it. I ordered some LED turn signal bulbs from amazon, after installing them i get the hyperflash while using my turn signals. I only replaced the fronts, not the rears... Do i need to replace all 4?
Any help is greatly appreciated.
Thank you!
Thank you!
You just need a load resistor on each.
V.
V.
I would replace all turn signal lights to LED. If you didn't buy the relay specifically for LED bulbs, and just bought the OEM flasher for the newer years, you'll have hyperflashing.
