Fuel Gauge not Responding to Full
Subscribe
Sep 2, 2017 | 11:28 AM
Hey everyone,
So this week I ran the fuel down to the light then refueled approx. 12 gals this morning (probably a total of 3 miles driven after the light went on). The fuel gauge stayed where it was at about 1/10th of a tank and appears to continue going down after further driving.
Items to note:
  • The gauge still lights up and "swoops" to the mark it believes to be accurate.
  • I stopped at another station & hit it with more gas and can confirm it's full.
  • I re-secured the gas cap 3-4 times - no change.
  • Before I left to gas up this am, I was in the trunk installing new trunk lift struts. Didn't run into any issues with this install but figured it's worth mentioning.
A search yields a few of the vague usual suspects (floater, fuel pump) on different cars.
Anyone have any thoughts?
Reply 0
Sep 2, 2017 | 08:25 PM
Took the car out tonight and once it hit nothing voila, right in front of my eyes it bounced back to normal. I'll update this thread if anything changes.
Reply 0
Sep 3, 2017 | 07:14 PM
Is your battery dying at all?
Reply 1
Sep 4, 2017 | 06:51 AM
Quote: Is your battery dying at all?
Very good call & I didn't think of it. Lots of posts about gauges acting funny due to batteries on here. I will keep an eye on it and update the thread if it is.
Reply 0
Sep 5, 2017 | 10:24 AM
seems like this is a same problem which has happened to me many years ago (which I posted it here.)
Service record indicated this:
SERVICE: REPAIRED ENGINE WIRE HARNESS.
DESCRIPTION: REPAIRED ENGINE WIRE HARNESS. ~ ~C/S: OIL TEMPERATURE GAUGE IS FLASHING ~ ~WIRE HARNESS LOOSE AND NEEDED REPAIRED. ~ ~47118 FOUND THE DRIVE CHEWED OFF CAUSING THE CONNECTOR TO GET UNPLUG AND BREKING THE WIRE, REPAIR THE CONNEDT AND PLUG IT BACK AND PUT A NEW DRIVE BELT ON, EVERYTHING WORKING GOOD AFTER REPAIR
This was also when my fuel gauge was not responding immediately.
Hope you get this sorted out.
Reply 1
Sep 6, 2017 | 01:45 PM
Quote: seems like this is a same problem which has happened to me many years ago (which I posted it here.)
Thanks stvincent, this too could save the day if it happens again.
Reply 0
Sep 9, 2017 | 11:22 AM
Less than a week after this these symptoms popped up.
  • Door chime got extremely quiet but was still there
  • All interior lighting & mirror button garage door opener died
Today I did a simple multi-meter test with the battery. It dipped just below 10 volts for a millisecond upon startup, but everything else appeared normal. Alternator had the battery at ~14 volts in idle & the batt had a solid 12.35 volts while off.
Checked the dome light fuse in the box next to the battery & it was blown. I replaced this & all symptoms have been fixed. I suspect it blew due to a flickering I have in my interior LED lights (the ones on roof in the front) which I'm going to tend to now. Anything else happens I'll update this thread.
Reply 0
Subscribe
