Oil change before track?
Old Jul 25, 2017 | 02:27 PM
almsdriver's Avatar
almsdriver
Default Oil change before track?
Planning on doing a 1-day track event this Friday. I did my last oil change about 1,700 miles and two months ago, did one track day and curious if I need another oil change for another 1-day track event?
I usually take it to the dealer for oil changes, about $120 worth the piece of mind ?
I plan on flushing brake fluid regardless. $100 fair price?
Thanks in advance
Old Jul 26, 2017 | 02:04 AM
isfvss's Avatar
isfvss
Don't bother with the oil just hit the track brake fluid that depend when it was last changed and with what fluid enjoy.
Old Jul 26, 2017 | 01:20 PM
jdmSW20's Avatar
jdmSW20
Im no track junky but I wouldn't bother with an oil change just for a track event. I would just go regular intervals like usual
Old Jul 27, 2017 | 06:43 AM
newgsman's Avatar
newgsman
In making a decision here I would also consider your oil temps the last time you went to the track. I know that one time when I went to the track, the oil temps started creeping up, not into the danger zone, but significantly higher than normal. If I am expecting to do a full day at a track where I go on every half hour I might think about putting fresh high quality oil. I do my own oil changes so not as big a financial burden, but then again, going to the track can easily run you several hundred dollars in terms of fees, gas, wear and tear. On a really good day you can go through a significant amount of brake pad wear and tire wear, so $120 for oil is almost a pittance.
Dnfwm
IS F (2008-2014)
20
Nov 14, 2019 03:12 PM
lilativan
IS - 1st Gen (2001-2005)
Jan 22, 2019 10:14 PM
O1GS43O
IS F (2008-2014)
25
Jul 15, 2015 06:57 AM
Phresh2010
May 28, 2010 12:32 PM
claymax
Aug 7, 2001 10:13 PM
