- Door lock actuator or...?
- Gt styling window visor
- Need help!!! Possible ignition?
- Never going back to the dealer.
- Which year transmissions will fit my 96 LS400?
- Code Reader / Scanner
- Tach needle
- heater doesnt work
- Steering wheel is cocked to the left
- Ugggghh! Just messed up my own car
- Knock Sensor Replacement
- Will be coming back to an LS after my 2002 ES300 fiasco
- Oil Leaks: Is the Dealer Screwing Me?
- Wheel spacers and ramblings
- Need advice on struts
- 99 LS400 ECT and Hight level boton problem
- Fairly new to the ls vip scene...
- third center cat/resonator
- Driver Door window tricky
- Swapping faceplates on a nakamichi head, 95-97?
- Just did my own alignment, 1990 LS400
- 98 LS400 no start
- headache.Valve cover gasket
- key problems !!
- EBC Red Pads install question
- LS400 : SSR Agle Strusse x Clifford Sutrisno
- Console bezel
- Would 96 LS400 OEM 16 inch rims fit a 92 LS400?
- ucf10 body kit
- 2jz swap
- More help needed with 1st and 2nd gen repair instructions compatability
- What are these lights?
- ZR1 corvete wheels.
- ls400 1989 airbag suspension problems. please help
- 99 ls-400 instrument cluster removel
- trac light fix
- 96 LS ecu gone bad
- High Speed Shimmy and Bushings
- 1997 transmission question
- rear brake pad replacement
- Soon to be owner of an 1993 LS400?
- Paint help
- Things to look at while buying an LS
- New 1-LS Owner
- Selling my 1994 LS400
- 95 LS400 rear wheel bearing
- Throwing in the towel...
- LCD clock weird problem....needs advice
- Will 98 seats fit a 95
- Engine did not turn over after recharging dead battery
- Engine undercover
- Converting Power Antenna to Hidden Antenna
- 1ls spark plug gap
- New- How goes it?
- performance chip?
- 95 spring and shock replacement question
- Sideskirt + lip options for 89-92 UCF10s
- Ls400 on Varrstoen Es 1.1.2 picture request!
- Air ride advice?
- stiff gas pedal.
- 5.3 lexus ls400
- My wrecked 99 LS400 :(
- Part number needed!
- Hoping to find a fix for "bubbles" under shifter bezel
- Proud new 90' ls owner!! Advice welcome!
- engine misfire
- Need Advice on Car Purchase
- Magnefine 1/2" Inline Magnetic Trans Or Power Steering Filter
- New here.
- Will 2k LS400 fit wheels on 92 LS?
- 1994 Lexus LS400 Radiator Replacement ?
- tie rods question
- aftermarket steering wheel in 93?
- Car will not shift into certain gears (the gearshift wont)
- air suspension conversion
- 1998 LS400 steering rack leaking
- specific misfiring problem
- hid help 95 ls 400
- my 1996 LS400 is SLOW like a Yugo, why?
- Missing exterior trim piece 1992 LS400
- 1996 LS400 wheel spacer: advantages n dis-advantages
- power steering maintenance schedule
- ucf20 strut rod bushing where to buy?
- Dealer quoted me $703 for p/s pump reseal
- Thumping sound when turning left
- Harbor Freight tool for lower ball joints
- Studio 2.1 Camber Adapters Installed
- Help with coilovers??
- horn not working
- Drivers door seal broke?
- New member intro?
- my new 95 ls400
- O.G(ee),,,,,it has finally happened!! Sold my 92
- Just purchased a 1999 LS400 lolfp Car
- TRAC light on; Transmission won't kick down.
- Wheel Hub Question
- Anybody know where Lextreme gets their upper control arm bushings?
- good website for oem parts???
- [92 LS fitment question]
- LEXUS vanity plates
- having problem with tension pulley....
- Can you suggest an ideal rim size?
- Video tutorials, anyone?
- LS400 caliper clearance vs Supra TT ??
- Which water outlet (coolant bypass) gasket and knock sensor?
- vibration
- Good buy or what???
- UFC10 coilovers for performance and comfort
- P0325 Knock Circuit malfunction, loss of coolant. Best deal on a knock sensor?
- LS400 1997 Suspension Diagram
- Driver door rattle & Armrest renewd (with photos)
- First lexus please comment
- 99 Camshaft timing tube leak
- 90 LS400 Cooling System Upgrade
- Power window master switch simple repair DIY
- Purchase Advice???
- lack of power
- Electrical issue
- Should I buy a high mileage 1995 or low mileage 1990?
- Rotor Question
- '93 LS400 Lack of power and negative rpm gauge under load
- New to this..
- Head light assembly
- Replacing side mirror glass
- 1995 ls400.Will sometimes start and then shutt off
- Changing out tensioner pulley
- Water pump/timing belt
- Sticky Gear Selector
- Transmission Help
- UCF1X camshaft pulley removal
- 1998 LS400 won´t start - immobilizer problem?
- Is it hard to find a mint LS400?
- 1996 LS400 keyless remote
- Stupid Question about Cooling Fan (Noise)
- Will these Rims Clear the Front Caliper??
- Question about tire size... LS430 rims on 1998 LS400 *with pics*
- transmission buzz
- 1993 LS 400 Coolant Issue
- Driver door gets stuck when its cold
- Curious on what my 1994 LS400, with 250k, is worth to people like us?
- recent problems
- acceleration issues with my 1990 ls400
- infant seat anchors
- cost of maintenance and common repairs
- help code 63 car wont star
- help its cold and raining! lcd fine, cig lighter fine, unit still off?
- needing help to find key fobs
- we have classifieds
- removing the auto level motor?
- Parking Lights
- 98 LS400 w/ 140K miles
- Update on my 96 LS
- Need Valve cover gasket..anything else?
- Looking at an LS400 need help
- Megan EZ cut coil over body
- fog light problem
- Picking up a 98 ls400 with 178k (used to own a 91!)
- 1997 Vacuum/Coolant line diagrams/pics?
- Whirring noise??
- Clunk in steering column
- ECM Eater
- 95 LS 400 - Power Windows Issue Just Developed
- Loud squealing and battery light on...
- Value of LS Seats??
- oil light
- Advice needed decoding the Lexus dealer service recommendations
- Raising Re Sell Price Of LS's
- Leak!!!! Please help!
- 1995 LS400 with a 1999 LS400 Frontend
- Rising cost of insurance in the UK
- (may consider selling?)
- My 97'
- CD-Rs don't play in CD Changer 2k LS400 HELP!!
- Need help removing license plate lamp covers
- What do y'all think about this item?
- 1997 LS400 Rear Window Question
- Has anyone experienced this before(pic inside)
- Please help-hi rev sound in 1st??
- Climate Control - Clock Lights up Blank, No Climate Control
- Looking for 99 Billet Grille
- RPM Sensor
- Why My LS400 Is A Keeper...?
- Remove and replace instrument panel, 1998-2000 LS
- hey fellas found a 95 ls400 for a steal what should i look for?
- Extended wheel studs?
- Watch LIVE: Starter Replacement on a 97.
- Fuel pump getting weak, how hard to change?
- WTF!!! Brand new pads and rotors CAUGHT ON FIRE!!!
- Engine Check Light not working - How to pull codes?
- Picked up my UCF21 Grey/Grey
- Dreaming of the ultimate mod....
- Euro front lip
- LS400 owners help please (Bracket ID/location)
- Where is the ECU fuse located?
- I have the baddest plugs made for the LS400, but will Seafoam hurt em?
- New Lexus owner....hope I got fair deal
- 92 ls400 cel
- UCF1x Brakes on UCF2x
- Urgent - how to remove UCF20 rear rotors?
- Hope to be picking up my first UCF20 Tomorrow!
- Radiator Temperature Sensor
- 97 rear coilover installation
- Exhaust leak 1995 LS 400
- Bad O2 sensor
- New to the forum
- Noise within engine area,
- My new UCF20 and an intro.
- Car Randomly Took a Crap on Me Today
- Lexus ls 400 help ('93)
- Climate Control LCD replacement question
- Lots of noise and vibration
- suspension help for noob!!! popping from rear
- Backlight for '97's Pioneer head unit
- should I replace my tie rods?
- a/c or heater doesnt blow hard
- Wekfest 2012 sf
- Battery cable corrosion
- Last Minute Timing Belt Questions
- cam and crank seals for 1LS
- Speedometer works intermttently
- Mitsubishi TB190M timing belt, BANDO drive belt, AISIN TKT-010
- LS400 won't shift out of first. Reverse light stays on.
- How well does your a/c recirculate perform?
- marker lights ???????
- should i be running this tire size?
- Need help ASAP to pass smog :(
- 1993 ls400 EGR pipe cracked ;(
- going from a 91 to a 98 ls! What differences will I notice?
- Source of engine oil leaks
- Passenger side view mirror question
- Steering Problem
- Where can I get brake disc centering screws.
- Antenna for '94 LS400
- Yet another power steering question.
- voltage problem. could there be a short or bad grounding?
- 1994 lexus ls400 dashboard
- Will 16" '05 GS Wheels Fit a '99 LS400?
- 1996 front door speaker grill removal
- Climate control LED size?
- Key won't unlock/lock door
- Fuel Injectors
- Has anyone bought their kit from duraflex?
- help...bought a set of 19x10.5 +5/19x11.5 +10
- suspension dilemma
- Wheel Stud Replacement
- choise of 19s
- Overnight, my car won't start, turns over fine, just will not start
- Lowering Driver side front seat in 99 LS?
- Idler problem
- Can you recommend a pair of mufflers?
