Is This Bad?
Old 08-11-06, 05:17 AM
NewLSlover
NewLSlover's Avatar
Default Is This Bad?
I own a 93 LS, I just noticed (because my instrumental panel is unreliable with alerts) my Overdrive has been on for the past month straight....I was wondering why my car was sluggish off the line, now that I took OD off it flys off the line like it should. Is this bad for my transmission or engine to have the OD on for so long? Any knowledge will be appreciated...Thanks in advance!
Old 08-11-06, 06:54 AM
ls400boi
ls400boi's Avatar
Will not hurt your car at all. I never turn off my OD. I figure it's only good for using when you won't be driving at higher speeds, thus not needing to cut RPMs and expand gas mileage.
But you have to manually turn off OD if you don't want to use it. I don't mess around with my OD button much because I figure the computer knows what it's doing and will shift through the ranges as it sees fit.
I say leave it on. LOL. I never knew that turning OD off would make the car faster off the line. When I want serious power, I just use POWER function near the shifter.
Old 08-11-06, 07:26 AM
NewLSlover
NewLSlover's Avatar
I see....good to hear
But, yea...My car was DEFINITELY sluggish off the line, as if it was trying to figure out how to OVERDRIVE in 1st gear, I could feel it slipping around when I first pressed the gas off the line.
Now, I don't feel anything, it just flys....it's a wonderful thing, I was about 2 days away from having a ATF drain/fill done. I still need one, just not as bad as I thought I did before...ha
passnu2
07-03-12 05:18 AM
91ls400own
08-12-09 08:01 PM
UTSC300
Performance & Maintenance
12
07-25-07 03:44 PM
LXotic
02-10-07 05:16 PM
edlexuspr
Maintenance
11-16-03 07:43 PM
Quick Reply: Is This Bad?
