- 4.10 Soarer Diff Question
- vipec 88
- 1992 sc300 fuel reguation problems?
- Boost Leak, IACV and Intake Manifold
- 1jz guys, need picture of the cam sensor wiring
- Why can't I spin the tires off the line
- So my engine is cleaner than your mom, but it runs even rougher...
- sc400 4.27 diff swap
- Giving up
- Seems like loss of power under load while driving
- Will a Magnaflow 14832 fit an SC400?
- Leaking wastegate, Can't build any boost, Question
- Easiest way to get to the spark plugs/cams on an SC3?
- 1992 SC400 Possible timing issue
- Yellow low oil level warning light on?
- 2jz-ge obd1 to 2jz-ge obd2 swap alternator question.
- Straight Blade or s blade which is better
- weird engine code anyone know???
- Help lookin short shifter
- Diesel compound turbo set up?
- MAP and IAT install help needed!!!
- RPM limit issue
- Engine/main harness for 94 SC400 interchangable with 97?
- A/C Leak.. Possible O-Ring replacement?
- 1jz swap EFI Fuse poping
- throttle body swap
- Cleaned IACV, screeching sound?
- need good advice on crank dampend
- help me make it "tight"
- Need AEM EMS V2 start-up cal
- periodic issue: cel (o2 bank1+2) and brake light (under hard braking)
- O2 Sensor Issues. CEL. Simulators? Skid plate?
- 92 sc400 no start
- GTE swap, AC only blows cold when set to COLD
- AEM EMS V.2, Shuts down when I go into boost. HELP!!!!
- bogging,missing and running like crap.........sigh
- where to start
- 2JZ-GE Head Rebuild Questions
- exhaust system
- HELP! what is this ticking noise! video inside.
- Help please 93 sc400 prob
- 1995 Lexus SC400 back pressure
- What tune-up bits would be most beneficial for gas mileage?
- Weird exhaust sound? With vid!
- Engine diagram SC/LS400?
- Greddy Emanage Ultimate
- MSD Blaster coil make a difference?
- So how many of you Bought the Driftmotion AEM pnp kit for 1j's?
- Timing Belt Kit
- Fuel Pump ECU
- 1j overboosting
- 1JZGTE Heater Hose part #'s??
- anyone have sc400 turn off randomly on turn? (going slow)
- unusual sound when turning the wheel
- Engine loud ticking from valve area w/ video
- 1jz swap and air conditioning help!
- Oil soaked spark plugs!
- 98+ modded sc's!
- How do I take apart 97+ LED spoiler light?
- Help! What is this part?
- 92 sc300 jzx90 swap problems
- 2jzge sputters???
- Code 71-EGR system malfunction
- coolant for sc 400?
- problems with my fuel pump?? help!!
- Dash needle question
- looking for some headers
- Red oil light blinking
- how hard of a job is it for a exhaust shop to swap out cats?
- Supercharged vs Turbocharged
- stainless steel clutch lines
- Piggy Back Ecu help hesitatiion issue
- Cold air intake.Pros and cons
- Brass fittings/pipe seal? What do you guys do?
- Replaced engine on '97 SC300 now new engine does not have Crank Sensor ring
- Could this actually do anything?
- A Newbie's Dilemma: Fix it or get rid of it?
- Tuning for dummies???
- 1st 2JZ-GE Headgasket swap
- Auto transmission problem
- 1JZ VVTI harness & ecu compatibility HELP
- 1jz 57 trim single with lextreme converter
- My valve cover won't come off?
- FIC Fuel Kit
- 97 SC400 where does this vacuum hose go at t-body?
- Reset ECU
- 1994 SC400 Leaking green fluid anti freeze Took pics of where please help help help
- The dreaded "Click" from the starter - 1jzgte A340LE
- Help with temp gauge needle.
- Supra rad. & universal trans. cooler
- Injector compatibility?
- Busted power steering pressure hose
- Lextreme Torque Converter review
- are these the right parts?
- Getting more power out of a sc400?
- Drive shaft problem....
- Inexpensive Horsepower
- please help!!!!
- what do these go to??
- Just installed new intercooler pipe so i made a video :)
- I just received my power steering pump and new acv. Does the acv connect to the pump?
- Remus mufflers on an SC400?
- 1JZ Finally Done! Tuning Issues!
- Upper Radiator Pipe help
- Building a motor for the SC!!!
- Is there a seat memory relay?????
- vvti and non vvti compatability??
- Sachs Optional power clutch kit
- Tranny Flush???
- 93 sc300 tranny issues AGAIN
- Power steering
- acceleration problem
- oil level sensor question.
- vibration
- Repair Manual
- Help!!!!! car stopped while driving...
- Blown head gasket or something else?
- 92 sc300 AC wont fill
- Need Help!! Electrical probs.
- Rear wheel hub removal sc400
- Low RPM @ Idle
- Can someone take a look at these pictures please.
- Cruise control on a SC400/W58
- Weird metal chirping sound on acceleration, do any of you guys know what this is?
- first time running MT et streets VID
- 93 SC400 Running HOT "Please help"
- mapecu forum
- sc300: do i cap this vacuum line/ pic request
- SC400 manual swap ?? Quantum ..?
- 1jz vvti coil on plug order?
- Let the build begin.. 1jz r154 swap
- Wheel bearing and brake caliper questions.
- Why is my clutch chirping?
- Low rpm grinding/whirring noise
- mk3 supra injector resistors???
- jzz30 r154 poly transmission mount ?? WTB
- Smog test failed at low speed
- forget the 2j
- 1992 SC300 5 speed na-t build Help Needed Please!
- Please Help fuelp pump replacement
- Fuel Pump replacement
- Sc300 1jz vvti questions
- Sc400 Engine Stalls
- SC400 Hot running issue!
- LS1 SC on the dyno
- Look what 600 got me. Lol I feel like I robbed someone
- Atlanta, GA Tuners, who has the best REP?
- First SC300 Experience
- My car idles at 200rpm
- Car won't start HElp!!!!!!!!!!
- Rough idle
- Are my engine mounts shot?
- California sc400?
- Need sc300 na-t project guidance.
- Lsd question
- crank seal SC300 cost ??
- Indentifying LSD.. mk3 vs mk4
- 1jz transmission plugs
- 93 auto tranny wont downshift
- a/c only blows cold upon acceleration
- SC400 HP readings
- 2jz-ge Oil Pump life expectancy?
- canister vsv part number needed
- 93 sc300 maf problem help
- best street single set-up.....
- Lots of white smoke (pics), valve stem seals?
- 92 engine harness for SC3 in a 95 SC3 will it work?
- Overheating Problems
- TDC cam adjustment.
- Lextreme Torque Converter and WHP
- 1Jz sc300 weird problem
- YAAAY!!!! New motor!!!
- electrical question/ trouble
- exhaust help sc300
- 1jzgte high idle
- which one???
- which wideband???
- Added oil now car idles funny??
- Im about to start working on my 1993 sc300
- Starts fine one day, other days it's dead - very random
- 2jz jdm to 1uz harness??
- New aem wideband kit!!!
- Problem with power windows sc300!
- Lower oil pan.
- How much the 1995 SC300 2jz motor weight?
- 350Z trans adapter?
- BW 8374 EFR vs. Precision 6266 CEA (Jourbal & DBB) DYNO RESULTS
- 2jz na-t build help!
- 1jz dual intake question
- Evap canister line
- 1jzgte HELP !!!
- How to adjust throttle cable in 94 sc400
- My car idles SUPER low
- what would cause fast turn signal& no bad bulbs?
- Good price on an r154 w extras?
- The necessary parts for A340 to R154??
- exhaust question
- 2000 SC300 Rear Tail Lights fit 92-96 without Modification?
- which midpipe
- Even MORE transmission issue
- Unichip GS400
- Help 3 battery cables????
- Engine bay line sizes? Ps, ac, brakes..
- 1992 Lexus Sc400 Mechanical issues *Help*
- DIY Replace Fuel Filter and New Flange Nuts
- Looking for 98_00 sc400 drive line
- What fuel management??
- question about sc 400s
- Cheap fuel pump?
- 94 SC400 has no electrical power
- alternator help
- Boost gauge fluctuating on vacuum side
- Gearbox issue
- is this okay? AND what do else should i do while adjusting valve clearance?
- 98 sc400 headers are they worth it and which mods are ?
- Hypereutectic pistons?
- intermittently dies, aem?
- 99sc300 intake manifold vacuum??
- Gas Leak
- No clue - Help with diagnosis?
- power steering hose question (not high pressure)
- good deal on a 1jzgte and extras?
- yellow oil light help
- '93 SC Climate Control LED
- Thoughts on E-cut?
- Lca
- 2jzge 5spd ecu run a gs300 harness??
- hydraulic cooling fan pump vibrating
- Gaskets and RTV and FIPG
- Getting ready for the swap
- Cali Spec SC 300/400
- Clutch recommendations
- got 27mpg straight highway driving
- Question on CEL code P1700
- Help oil pan plug?
- Speedometer not working properly - all other gauges working
- Need assistance - MPG dropping quickly, need mechanical expertise
- downpipe question
- Homemade SC300 exhaust VIDEO/SOUND clip inside
- cracked radiator
- 92 sc300 1jzgte Swap Is Not Accelerating As Fast As it Should
- IACV problem?? (pics)
- How hard is an Injector Job?
- fail smog again? -_________-
- OEM radiator replacements?
- SC400: intermittent fuel smell in cabin
- sc3 na-t *help* before tune on Sat
- intake mainfolds????
- 1.5jz help max boost?
- I'm confused...modding 1jz couple ?'s
