- Signature Lexus IS abnormal extreme inner tire wear
- Sticky 5th Gear
- Traction control off and check engine light on
- New Generation IS
- Brembo Brakes?
- Wheel fitment guide, any info is appreciated!
- Gas pump keeps shutting off - '15 IS350 F Sport
- Very Dim steering wheel lights
- Help please - Venting cooling system - IS200t
- Buying Advice
- Any special deals on F-Sport Performance Exhaust?
- What wheels could i put on my is250
- 2014 or 2015 F-Sport?
- Suggestion For 2014 Is350 F sport Exhaust
- OEM stereo/factory amp wiring question
- Anyone live near Macon Georgia with an 3rd gen IS?
- Lexus Enform Guest Driver
- large hole from GrimmSpeed License Plate Relocation Kit
- seibon rear diffuser not fitting
- NEED HELP ON Exhaust
- How to increase volume of alarm chirp?
- My Lexus was Vandalized :(
- I can't see at night...
- Gearing with 6-speed
- Noise coming from rear left side of car cabin
- Alternator or Battery?
- Gauge cluster swap
- Front camera install
- For sale ads go in classifieds section, not here
- Best Tire Replacement?
- Automatic Door Unlock
- 2017 IS 200t F-Sport vs IS 300
- Fuel Efficient Problem And suggestion for best exhaust.
- Snow Chains for IS350 18" Tires?
- IS 300- Front under bumper damage
- 16-18 mpg 2015 F-sport
- NYC/NJ Meetup and Cruise?
- Issues after jump starting car
- Trd 8ar-fts (200t)
- 2017 IS 300 Wheel Bearing?
- Cabin rattle in 2017 Fsport
- Ark exhaust (or cat back exhaust) legal?
- Services Shop recommendation
- IS 200t questions
- Front Parking sensors trip off when stopped behind black cars
- Buying aftermarket Rims
- 2014 OEM Replacement Wheel
- Ordering 2018 IS 350
- 2015 IS HID bulb change
- A/C blowing hot air?
- Is anyone else getting better gas mileage in Sport mode than in Eco mode?
- Sat Nav cuts out phone
- Springs: H&R vs Tein S Tech vs RS-R (Downs)
- RC-F shifter paddles
- 3IS TRD Sideskirts question
- hood and fuel door dont close
- Anybody selling midpipes/ Axle
- ARK Solus Wide Body Kit
- cruise control help
- key fob will not work
- Invidia midpipe / Axle Questions
- Rear Emblem Delete
- Can you help me find a lexus replacement part, pretty please?
- Entertainment System Constant Reboot
- Cold air not cold
- Weak Heated seat ?
- Debadging ? - holes under side fsport badges on 2017?
- tyre reset after changing battery
- tyre pressure light and proximity sensors not working
- Traction Control
- Weather Doppler map and city
- Techron Concentrate Plus
- Rear windows frosting
- Michelin pilot sport a/s 3+
- Is350 2014 OEM fsport exhaust for luxury
- 32k Scheduled Brake Maintenance? (Canada)
- 2014 IS250 F-sport All season tire suggestions
- 2018 IS 350 Fsport oil filter part number...
- IS300 Fsport appreciation thread
- Mirror Tap into 2018 IS300 for Dashcam
- is250 15 with 33k miles - questions
- 2014 IS250 Cold start problem!!!!!
- G-Force indicator
- Gas milage, 0-60 in different IS drive modes
- Brakes
- Knob control model ES200 Android interface
- Am I crazy? Did I detect a chassis difference driving 2018 IS350-IS300 back to back?
- Looking at a new IS 300 awd. Not F sport
- Good source for tire chains for 2017 IS200t F Sport?
- Bluetooth Help Please
- 250 vs. 200t Reliability
- Going to buy in January 2018
- How many stock horns come installed
- New Member
- Fsport License plate bracket from The Lexus Collection
- Platinum Vehicle Service Agreement (Extended Warranty)
- Clunk sound from rear
- Wheel locks for aftermarket wheels
- Thoughts on 2018 Camry from IS owners?!
- Merry Christmas and a Happy New Year
- 2018 Lexus IS exterior difference compared to 2017 model
- navigation
- Navigation Issue
- 6 flats in first year of owning, any options?
- can I get parking sensor for my 17 IS350 F-Sports?
- Black Screen Radio and Navigation IS250 2015
- Safety Connect on my 2017 IS
- Good lease deal?
- Lexus is 350 tires
- HELP Car won't start - 14 is250 with 73k miles
- IS350 Speaker Sizes
- Complimentary Lexus dealer car wash: Caviar IS paint color
- Revisiting IS300 AWD vs IS350 AWD HP and Torque
- How to read the Turbo gauge in IS200T?
- Sound system
- NuLuxe Repair
- Cold Weather Brake noise
- Engine Coolant Temperature High then back to normal
- Lexon's IS350 F Sport Hugs the Ground Like Nobody's Business
- 10.5x19 will fit ? Bagged
- Apple carplay
- Lexus OEM RCF Auto Dimming rear view mirror DIY
- Question about wiring
- IS250 AWD First Snow Day
- Totaled?
- Protecting your IS wheels
- LED Foglights
- Will IS250 F-sport cluster / odometer fit my IS350awd?
- Putting weathertech mats from RWD to AWD IS350 F Sport
- running light upgrade
- Random questions regarding new IS300 Fsport
- OEM Audio System Install/Review
- Vacuum Regulator Valve 2.0t Buzzing Noise...Again
- License plate lights replacement
- 2017 Nav map update?
- IS300: aggressive use of gas pedal?
- Fog light?
- Aftermarket Wheels
- Best no drill front license plate ^_^
- Winter Wheel/Tire Fitment
- What fuse size do we have?
- Adding Mark Levinson with Navigation
- Head unit rebooted
- Turn signal socket part #
- Sensor Name
- Fuel cap holder?
- Curious about IS350 AWD Fsport availability
- Check AWD system on is350 F-Sport
- IS 350 F Sport Breakpads/Rotors
- Do I need to replace my 17 diffuser in order to add aftermarket exhaust?
- Quick Release Front Lip
- Push Button - How to shut off the engine but keep the accessories on
- 2014 lexus Is250 All wheel drive, Rear tire wear.
- Correct Tire Pressure
- Gas pump keeps stopping
- So many threads on TPMS, but no clear answers
- Post accident Check BMS, ABS, and VGRS
- RC Auto dimming rear view mirror wires
- New IS300 2017 AWD Fsport owner: performance questions
- Strange Blinking Light on Dash
- 2017 IS300 AWD Fsport in cold and snow
- Tom's power box
- Rear bumper gap?
- Swapping TPMS to after market wheels
- Tachometer Outside Temperature is Way Off from Actual & Infosystem
- 2014 IS250 f-sport brake pad-- need help
- Quad tips for 2017 IS200t f-sport
- What is that coolant pipe?
- Tommy Kaira/Rowen kit
- worth the trade to a gla45?
- Turning my F-Sport exhaust into quad tips
- Spiral cable
- Paint for 2015 IS350 F Sport Black "Craftline" Wheels
- F Sport Blak Rims restoration kit???
- Dealership unable to fix issue. TAS # issued
- Drilled slotted rotors for our cars
- Volk TE37 for the 3IS
- Leasing IS200T
- Thinking about a new 2018 IS.
- seibon carbon diffuser 2017 IS
- Used IS 300h, are they economical?
- Interior lights don’t turn on when door opens
- Jealous of you Americans
- Always on side mirror heating
- Mixing tire brands back and front
- rear seats child restraint latch cover
- Bumpy Ride
- Air Suspension Install
- How many miles on RSR downs?
- Paint code?
- 3IS Rear Exhaust Tips?
- 2009 Prius totalled - I WANT A LEXUS
- 3IS AWD in Snow?
- Steering wheel replacement cost?
- Fog Switch - Replacing Winjet Switch
- Voided warranty for non fact-remote start???
- Help Applying Sound Deadening Materials (Dynamat)
- side skirts bumper and diffuser
- Quad exhaust tips size?
- "Maintenance required soon" & yellow triangle light
- Might have issues with warranty
- Sick 2017 IS at Stance Nation with the NIA Splitter!
- Color Match Key Fob
- Require a quiet exhaust for gse31r is350
- LED turn signal for mirrors
- Silver Lining Metallic IS250
- Driver door plug?
- 2nd gen or 3rd gen?
- Best looking 3IS?
- Gas pump keeps stopping when tank not full
- Did anyone attempt tpms light disable or bypass
- Suspension noise?
- Satin Finish wrap/dip?
- Navigation Question - Volumn over Music
- SD card map update?
- Sales experience survey
- 3is burning oil?
- Midpipe for '16 IS350 AWD?
- How to tell if the shop painted the bumper properly?
- Check out this sick video!
- How to install your Lexus IS 3rd fsport gen front NIA splitter
- 2015 IS 350 Fsport Black Craftline Wheels.....where to buy?
- Rear Bumper Damaged? (Please Advise)
- Bumper change
- Looking to Purchase F Sport Axel Back
- Wheel lock
- Something I'm surprised that hasn't been made for the 3IS yet
- "LEXUS" non CDM/USDM trunk badge.
- HELP! New L/C IS350 owner, old IS350 problems
- 2017 IS200t
- 3IS Front Bumper
- Help Getting New Tires ?!
- new Rocket Bunny style Rear Spoiler?
- NIA Eyelids Now in Stock!!
- Driver seat bulged
- Newest 2017 IS Splitter
- 2014-2017 ISxxx remote start with oem remote 3click
- Removing body side mouldings, 2015 IS250F
- 2015 Lexus IS 250 f sport TPMS
- Door lock auto folding mirror system DIY(RHD)
- Window Visors
- Just installed!
- Lexus IS 2018 Refresh Lures Us In
- 275/30-19 in the rear
- Quad diagonal exhaust for Toms diffuser
- Wiper blades only work on high
- Water bottles that fit in the cup holders
- Seat Covers
- Voltage problem
