PDA
View Full Version : IS - 3rd Gen (2014-present)
Pages : 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69
  1. Hard wiring Dash cam?
  2. Dead Headunit
  3. Audio upgrade on "F-Sport Edition" model
  4. Speaker issues
  5. do you know what IS stands for??
  6. F Sport Bumper Conversion Bumper Assembly
  7. Lexus is250 problems 2014
  8. Recirculation mode
  9. Can someone help me figure out what this noise is?
  10. HVAC Temp Control "Sliders"
  11. 2022 IS350 wet passenger side carpets
  12. Faster Deceleration
  13. Transmission Fluid Change
  14. Niche wheel wanted
  15. Engine Oil
  16. 2021 IS300 AWD F sport winter wheels
  17. 2021 is 350 awd making wind like noises
  18. Touch Up Paint
  19. Exhaust Setup IS350 F Sport RWD
  20. Muffler + Resonator Delete
  21. IS 300F Armrest Replacement
  22. F Sport to "New" F Sport Conversion
  23. Buying A New IS350 F Sport - BYE BYE German Cars
  24. Sd navigation card
  25. How far have you driven your 18-20 Lexus IS300?
  26. IS 500 extreme rear tire wear, inside of tire, both sides the same. Front is ok
  27. Daily-Road Warriors
  28. 2014 Lexus IS250 - Is it a nice looking color, or should I have choose white or black
  29. AC and sunroof drain maintenance
  30. Car pulled to the right several times in the highway?
  31. OEM Red Courtesy Lamps
  32. 3IS - 2021 Front Bumper Conversion
  33. What else should I do to my 3IS
  34. Which 0W-20 Synthetic Oil Does Everyone Use?
  35. 2023 IS350 - Window Tint
  36. Swap to latest Gauge cluster
  37. Limited Service Campaign - water/mold in trunk
  38. Engine Covers
  39. 23 IS 350 Spoiler Problem!
  40. help asap please !! wheel fitment question.
  41. Water Outlet Filler Hole
  42. Interior Side Panel
  43. Lexus is 200t weird sound need help
  44. Key programming help
  45. 2023 F-Sport fuel economy update...
  46. F-Sport dash "squeaks" when going through animation start-up. What the heck?
  47. IS200t/IS300 F-Sport ride comfort
  48. 23 is350 rear dashcam with sunshade?
  49. Tire Replacement
  50. Lexus IS350 Bluetooth is working, but my LCD and audio steering controls are not conn
  51. Borla Axleback compatible with Apexi Midpipe?
  52. Cigarette Lighter Not Powering External Screen
  53. Lexion update
  54. IS 300 AWD tire size
  55. 2023 Lexus IS350 rear tweeter install
  56. Fender Liner Mounting Hardware
  57. Best year/model for value?
  58. Install New Backup Camera - 2014 Lexus IS 350 AWD F Sport
  59. Dealer Repair Cost
  60. Does the Mark Levinson have any sort of heat protection where it will be quieter?
  61. 2015 IS350 F-Sport Battery Replacment
  62. F-blue powdercoating
  63. 2016 IS 300 Brakes
  64. ABS warning Left Front Open/Short
  65. Are these usb boxes identical
  66. Tanso Werks (Road top) Carplay/Android Auto
  67. IS 200t low rpm rattle
  68. Brakes squeaking - cheapest way to fix
  69. Triple led upgrade issue
  70. Anyone know how to remove the 12v socket
  71. Does the 2014 IS350, being a first Model Year car, have noticeably worse reliability?
  72. 2015 trunk questions
  73. 2015 is350 awd f sport CEL and limp mode
  74. Just how good is the Mark Levinson stereo in the 2014-2016 IS350?
  75. Tire and wheel coverage
  76. IS 300h Driver"s seat unconfortable
  77. Rear cross traffic false positive in heavy rain
  78. Wheel Offset - +22 vs 38
  79. Wheel Fitment
  80. What is this key fob?
  81. I drove 100,000+ miles with the RR Racing Tune
  82. A/c making hissing gurgling noise
  83. Weird Start Up Issue and Parking Assist Unavailable - 2021 LEXUS IS350
  84. Engine shuts off when driving
  85. Are these normal or do these have wheel spacers
  86. 2015 IS350 with 3 owners & maintenance history gaps on Carfax/Lexus.com. Please help
  87. I screwed something up and now my steering rack makes awful noises.
  88. Creep groan
  89. Help - 2016 Lexus IS 200t Overheating
  90. Lexus IS Trunk Alignment Adjustment
  91. Changing bushings
  92. 2016 350 - Laggy, Low power
  93. Traction control light stays on
  94. USDM 2014+ IS350 / IS300 Headlight Amber Reflector Removal?
  95. Sunroof rattles
  96. lost keyfob, any alternatives to replace?
  97. Thanks for the add
  98. Is200t 2016 dyno test ,is my car allright?
  99. is300h ABS Fluttering
  100. Ark Grip Catback Exhaust for IS300 3.5L V6
  101. Extended cranking issue - IS300 2019
  102. Rotor diameter?
  103. can i use parts for 2020 is350 on my 2021 is350
  104. IS500 Exhaust on IS350
  105. IS300H 2016 Fl - pulls to the right, no more ideas or hope
  106. RC-F Bushings vs. LCA Stock Bushings
  107. 2016 IS350 AWD O2 bank 1 sensor 2 replace
  108. Place to repair Mark Levinson amp near Quebec-Montreal?
  109. !!!help!!! 2015 is250 - voltage abnormality issue
  110. Lexus IS200T - trying to figure out what is happening.
  111. Help 2016 Lexus IS200t engine weird noise
  112. Turn signals won’t work
  113. Lexus IS300h Exhaust.
  114. 2015 IS250 Ignition On But No Crank
  115. Lowering springs
  116. Is 2014 350 RWD rare in Canada?
  117. IS350 water pump knocking
  118. 24 is 350
  119. Transmissions
  120. Does anyone else have these ugly pads where there rear plate goes?
  121. Looking for name/part number of underside deflectors
  122. Front Door Rubber Seals 2023 IS
  123. Rattle in gear change in Normal Drive and Eco Mode
  124. 2023 IS350 transmission hick-up....
  125. Cost of dent and paint job of 2017 IS300?
  126. Adding heated/ventilated seats 2016 Lexus IS200t
  127. Unsure of Suspension/Alignment Issue
  128. How to Open Fuel Door with Dead Battery
  129. Performance issues after work at dealership ('14 is350)
  130. IS200t cluster not working
  131. Spark Plugs
  132. 2023 IS350 fake exhaust noise... irregularities?
  133. What brake pads are in my IS300 F Sport?
  134. The electric motor from the panoramic sunroof does not work
  135. I'm really worried my new wheels wont work fit
  136. Trackpad part number?
  137. is300 no drone exhaust options
  138. 2020 IS 350 F Sport Premium Sound Question
  139. Alignment Specs
  140. Panoramic parking camera setup
  141. 2016 IS200t head light flickering.
  142. Is this a good deal? 2015 is250 F Sport
  143. Steering wheel stiffness
  144. IS 350 Question
  145. 2020 Fsport Carbon Fiber Radiator Grill Garnish
  146. Trying to Frankenstein an exhaust from another car
  147. 2014 IS350 Trunk Filled With Water and Now Amp Is Dead
  148. Max tire diameter difference on AWD
  149. Budget roof rack system?
  150. 2023 IS 350 Window Tint and UV glass?
  151. 3IS Single Exit
  152. Transmission Cooler, help!
  153. Driven Lambos Ferraris Rollies but the Lexus IS has the best
  154. Electric power tailgate retrofitted on 3IS
  155. Increased tire pressure to 40 PSI on all 4
  156. IS300h - C1259 HV System Regenerative Malfunction
  157. Fitting a 2017+ apexi exhaust on a 2021+
  158. Not bad for a 5 liter V8
  159. Steering wheel bezel (21+ IS)
  160. No Audio
  161. Has anyone replaced the factory subwoofer on the 2021-2023 IS?
  162. Engine Oil Cooler
  163. 2023 IS350 four month update and mini review...
  164. lexus is 2016 backup camera problem
  165. IS350 Wheels Specs
  166. CAI Hose Coupler Ripping
  167. 2021+ Triple Beam LED Headlight Height Adjustment
  168. 2021 IS350 Shifting Concern
  169. Non F-sport Grille Swap?
  170. Hood strut recommendations?
  171. 2021+ IS350 F Sport Performance Exhaust Hanging Low
  172. Best exhaust setup for an is350?
  173. Lexus 3is tape over trunk valves. (AMP moisture fix?)
  174. Oem F sport shock absorbers
  175. SRS Knee Airbag failure
  176. Rim shrank and couldnt fit hubcap
  177. Torque Values for Suspension Components
  178. Can we still drive on worn tires with chords and wiring showing
  179. New IS
  180. Polishing gloss black side skirts?
  181. Illuminated Door Sills question
  182. Need help identifying a sensor
  183. 2023 IS350 wheel spacers
  184. What owners of IS think of UX?
  185. Adding superglue or tape to tires to reduce front shoulder wear on IS
  186. 2016 IS300 intermittent P2200 code
  187. Can an IS make it onto a beach?
  188. Lexus 3rd gen is350 f sport AWD front differential leak
  189. Wait for 2024 IS350 or snag a 2023 at a discount?
  190. 2015 is250 AWD rear axle shaft noise?
  191. F Sport seats
  192. "Mod" for 3IS Interiors
  193. Top speed of 2020 Lexus IS300 AWD
  194. Nav headunit to non nav
  195. 2015 IS350 AWD OEM Carpet Floor Mats
  196. Question: 2017 IS 350 Muffler Delete w/ Welded Stock Exhaust & Tip
  197. Headunit Install Question: got a new one
  198. NGK Ignition Coils
  199. 2021 IS350 F Sport Sly Brackets
  200. Deactivate or reprogram car keys
  201. Bought a aftermarket steering wheel
  202. Will the 2022+ 3rd Gen IS Hybrid ever come to North America
  203. Android auto into 2020 IS 350
  204. Where do you get your alignment done?
  205. Clock Doesn't Keep Correct Time
  206. Beware of Paintless Dent Repair on Door Dent!Door Panel Damage!
  207. Cat-back with valve exhaust system
  208. Head Light Bulb Problem (3rd Gen IS 250) 2015
  209. 2023 IS 500 F Sport Performance - Molten Pearl
  210. My 2014 is250 won’t start
  211. Replaced Smart Key Module cant program key now.
  212. 2021 IS350 AWD OBD2 Port location:
  213. Lexus IS300H 12V battery drain
  214. Interior foot lighting
  215. 2021+ F-Sport Exterior Conversion
  216. Just bought a 2021 IS300,
  217. What to use to polish/restore lower trim piece on front bumper (see picture)
  218. Metal clicking when opening passenger door
  219. Pinch weld lift adapters
  220. 2021+ IS stud conversion reviews or complaints?
  221. Rear bumper reflector
  222. 2021 IS350 AWD Springs or coilovers?
  223. Amp dead please help
  224. 2023 F Sport Performance Exhaust Compatibility
  225. Coil recommendation for daily driving
  226. 2023 IS 350 Carbon Fiber Interior Upgrades
  227. Scratch on the Gloss Black Spoiler - 2022 IS350
  228. New Car 2014 Lexus IS250
  229. springs + shocks or coilovers?
  230. Door Panel Noises
  231. Request - location for 2021+ F Sport fender badge
  232. Lost all keys - dealer says $7300 AUD to replace the lot
  233. 2015 IS250 - Front Blinkers Not Working
  234. 2021 IS300 (Daily)
  235. 2023 IS350 weak air conditioning in very hot weather?
  236. Help Pigtail Camshaft Position Sensor A Bank 2
  237. HELP! I jumped wrong my 2014 is250 f sport
  238. Can a bad alternator be 1 of the causes of the head unit rebooting?
  239. NYC Area Lexus Meet-Up
  240. Hood Latch warning 2015 IS350
  241. Manual Door Lock Not Working
  242. Base to f sport grille on 2019 is300
  243. Still waiting for spare key
  244. AC Not Blowing in ‘14 IS250
  245. 2014 Lexus Is350 Awd - Does anyone know what this noise is?
  246. Exhaust
  247. Buy IS250 F-Sport 2014 in 2023?
  248. Exhaust question
  249. 14 IS350 trim piece removal
  250. Whats the role of the quarter vent ducts?
