2015 Lexus IS 250 f sport TPMS
I recently got new set of rims and tires for winter here in Canada. There's no problem on the dashboard about my missing TPMS but I just don't see the tire pressures for my new tires same time I'd like to have tpms for my winter tires. Now a friend of mine said the car should be able to learn 2 sets of tpms sensor one for summer and other winter. I asked the dealership and they said I'd have to get them reprogram each time I switch mean while Jspec said my car can learn two sets of tpms. So if I were to swap them back to summer tires after I get the winters programmed will it be able to relearn itself after a few miles of running ? (Friend said his mustang relearns the tpms). Tried searching for this specific topic on the is 250 2015 didn't seem to find it sorry if his topic was cleared out before. Cheers for the help guys.
thanks for the info! If I don't attach a tpms sensor to my winters will the dash give me an error eventually? Cause at the moment it's just showing blank for the tire pressures.
It'll show error after about 45min to an hour drive after the car is far away from the TMPS set of wheels.
If your drive is short every time, you may never see the error because it will "see" the TMPS of the wheels near the car the next time you are in the garage again.
If your "Summer" wheels with the TMPS programmed are nearby in the garage you won't show error right away.
My summer tires are in the garage 2-3 feet away from my car which I park outside. But other than that I go to work which is 17km away and I'm here about 8 hrs. I still haven't seen the indicator come up. I'm reading about this tool Ateq quickset tpms reset tool. Which holds summer and winter tpms codes in itself would this be a possible solution when I switch from winter to summer ?
The Ateq quickset tool is what we use and it works well. I think there was a thread about sensors that you can clone to your OEM sensors so you could avoid having to reprogram them each time. I didn't look into it since I already had what I have. Might be worth some research, though.
I just read the DENSO 5500105 tpms sensor from rockauto saying it doesn't need to be programmed or cloned before installation they're built to the specified vehicle right out of the box. Saying their sensors relearn just like an OE part. Is this true ?
I've bought multiple of these "cheap" cables.
You punch in the new TPMS codes and hit the save button and nothing happens.
These cables are missing logic chips or something to go into deep programming settings such as ECU and TMPS stuff.
These replica Cables is only good for reading outputs and changing Personalized settings only really.
online
NX - 1st Gen (2015-2021)
11-10-17 07:26 PM
