Traction Control
Old Jan 3, 2018 | 09:22 AM
ZISF's Avatar
ZISF
Default Traction Control
Does anyone know how to turn off the dynamic traction control. I'd like to have some fun in the snow. The traction control is shut off but the system still cuts the power mid drift so it makes me believe there is still some dynamic control system that's in place.
Old Jan 3, 2018 | 09:56 AM
dshu's Avatar
dshu
While at a standstill press and hold the traction control button until you see the yellow/orange traction off light to "fully" turn traction off. I don't think it completely turns it off, but definitely the majority of it.
Old Jan 3, 2018 | 11:21 AM
jkonquer's Avatar
jkonquer
Only way to completely turn it off is to pull the fuse
Also what you are feeling is the stability control, it turns on at a certain angle of the vehicle vs front wheels.
Old Jan 3, 2018 | 11:46 AM
ZISF's Avatar
ZISF
Also what you are feeling is the yaw control, it turns on at a certain angle of the vehicle vs front wheels.
Interesting! Good to know. Why must Lexus make it so difficult to have fun in the snow. I just want to do donuts in the snow, is that too much to ask for.
Old Jan 3, 2018 | 11:55 AM
BRiCCFLAiR's Avatar
BRiCCFLAiR
Came across this the other day, glad somebody else already made a post because I forgot.
Old Jan 3, 2018 | 12:42 PM
JNP1227's Avatar
JNP1227
Hold the TC button down for 5 seconds till the yellow TC indicator comes on
Old Jan 3, 2018 | 01:00 PM
arentz07's Avatar
arentz07
You can also do the pedal dance, which is what I did when I found an empty, snowy parking lot last week. Bear in mind that the stability control is also disabled, so make sure you have room to play.
For convenience:
1. With car off, engage parking brake.
2. Start the car.
3. Pump the brake pedal twice.
4. Release and re-engage the parking brake twice.
5. Pump the brake pedal three times.
That's the procedure I use. Sometimes it doesn't register, but if I repeat 4. and 5. again it will usually take.
From what I can tell, holding down the TC off button might work just as well, but then again I didn't really try anything till after I did the pedal dance.
Old Jan 3, 2018 | 01:23 PM
ZISF's Avatar
ZISF
Does this work with the 2017 model?
For convenience:
2. Start the car.
Old Jan 3, 2018 | 01:28 PM
arentz07's Avatar
arentz07
Well, I have a 2016, so I can't confirm this. However I wouldn't be surprised if it did given the minimal changes to the 2017s compared with 2016s.
Old Jan 3, 2018 | 04:06 PM
jkonquer's Avatar
jkonquer
Sorry i ment to say stability control
Old Jan 4, 2018 | 05:55 AM
Raghza's Avatar
Raghza
The pedal dance will work on most models I believe.
I can also disable everything, if I'm at standstill, the car is in Park or Neutral and I hold the TC button for a few seconds until the yellow TC indicator on the left lights up. I've heard it doesn't work on all models unfortunately.
Old Jan 4, 2018 | 08:54 AM
arentz07's Avatar
arentz07
That method does shut off traction control but not sure about stability control. If you pedal dance, you won't be able to re-enable those systems either.
In any case, be careful in the snow. It's a very educational experience. If you've never done it before, be prepared for lots of unintentional spins. You'll get the hang of it - being smooth and not over-correcting are the things I learned.
Old Jan 4, 2018 | 11:35 PM
Raghza's Avatar
Raghza
It might be different on the US models, but for my car, this also disables stability control as well.
The 3IS is very driftable and the good amount of steering angle also makes it easy to bring the car out of big angle slides
DiverseIS
Jun 30, 2019 04:36 AM
Dylan19
Mar 6, 2015 01:47 PM
F350
Oct 19, 2013 11:52 AM
SCARYTOWEL
Jan 17, 2009 07:48 PM
