Swapping TPMS to after market wheels
Old Dec 9, 2017 | 05:06 PM
nathantse's Avatar
nathantse
Default Swapping TPMS to after market wheels
Hey guys,
Kind of a stupid questions, but if I were to reuse my OEM TPMS, do I need to do the swap prior to mounting tires on new aftermarket rims of does it not matter?
Debating if I should buy wheel/tire package (tires are pre mounted/balanced) or buy them each separately.
Thanks !
Old Dec 10, 2017 | 10:13 AM
davyjordi's Avatar
davyjordi
it doesn't matter but if you don't replace before then you'll get a dash light pop on.
Old Dec 10, 2017 | 11:01 AM
nathantse's Avatar
nathantse
So it's best to swap the OEM TPMS into the new rims BEFORE mounting/balancing tires.
Old Dec 10, 2017 | 12:41 PM
ClubLUser's Avatar
ClubLUser
Yes, because the sensors are installed on the inside of the rim that protrudes outward and you would have to mount and balance your new wheels twice. Just a note, aftermarket TPMS clones are not overly expensive, if you're doing a two wheel set (winter wheels).
Old Dec 10, 2017 | 03:03 PM
nathantse's Avatar
nathantse
I only need one set of TPMS, cause California. =]
Im gonna end up doing this at the dealership, I'm sure they will know how to do it. But, I'll make sure they do the swap prior to mounting/balancing tires.
Old Dec 10, 2017 | 05:04 PM
Ciggy's Avatar
Ciggy
Can you recommend which ones I should pick up?
Lex_Giorgio
Jan 20, 2014 12:49 PM
johnnunez2
Mar 24, 2012 03:13 PM
ThermonMer
Nov 11, 2011 03:00 PM
hanzie411
Mar 21, 2010 08:43 PM
NYC ES3
Wheels, Tires & Brakes Forum
Dec 13, 2008 11:42 AM
