PDA
View Full Version : IS - 2nd Gen (2006-2013)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 [36] 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232
  1. Lexus IS 250
  2. Front underbody panel! - Dragging
  3. New and need help with bumper and lugs!!
  4. Picked up a white 2007 IS250 RWD 6MT
  5. Ever Remove Plastic Cover Under Back Bumper?
  6. Enform
  7. Halo's for a 2013 IS250
  8. Bumper Question
  9. IS 250 - Beat-Sonic SLX-140L - Question
  10. in dash and door panels vinyl issue
  11. Trunk Lip for is350
  12. Creaking Door Seals
  13. License plate bracket
  14. Removing Window regulator help?
  15. Catch can
  16. Interior lighting question
  17. Lexus is250 Catalytic converter
  18. IS250 EBAY Rear Diffuser (RESULTS) PLEASE READ
  19. Need help
  20. 2006 IS350 purchased in 12/2011 Alternator or Battery?
  21. IS 250 door change
  22. Lug Nut Size question
  23. 2008 Lexus IS350 problems?
  24. Photoshop Request - TRD wheels
  25. Custom supercharger bracket
  26. 2007 Lexus IS250 should I buy one ?
  27. 2007 Lexus IS250 good purchase?
  28. navi screen dead
  29. CAR-DA 10.4" tesla style head unit for Lexus IS
  30. 2012+ headlights -- Projector Shroud part #
  31. Clicking sound when turning on car
  32. Should I replace Injen Intake with F-Sport Intake?
  33. led lights
  34. Next mod?
  35. Question about noise at idle
  36. Bad Rear Sway Bar End Link?
  37. Just bought a rare IS!!
  38. J2 exhaust
  39. First Lexus!!! What modifications to start with?
  40. Screech noise from driver-side wheelwell (Vid included)
  41. Steering ECU questions
  42. Anyone know where this sound is coming from?
  43. Wheel rubbing/growl
  44. HELP: Where to buy/order oem-colour vinyl wrap
  45. IS250 6M/T short shifter
  46. I need help to remove plate light is250
  47. Rear End - Whine
  48. Changing Parking Lights
  49. Considering a 2006 IS 350. Request a consult
  50. 2008 IS350 high pitch whining
  51. Possibility of carbon issues even after piston replacement?
  52. Hypermiling (IS250 6MT)
  53. Getting misfire code after changing FPS
  54. Alternate sub for 2008 IS with Mark Levinson
  55. question of carbon cleanup
  56. 2012 Lexus IS350 Rattling Noise
  57. Change all four tires at the same time?
  58. 2008 IS 350 recently hit 150k miles... Anything I should be wary of?
  59. RCF wheels on '08 IS250?
  60. Transmission flush at 75k miles?
  61. Buying a 2007 Lexus is350 with 161,000 miles need advice
  62. Anyone know what is wrong?
  63. Gunmetal OEM wheels. Photoshop request!
  64. d2 pro springs anyone have pics
  65. 2006 IS250, backup camera, no washer kit
  66. Program memory low on RR navigation
  67. Engine not responsive, check system and VSC are lit after replacing fusible link
  68. CEL and C1201 code +VSC Light
  69. Question about my sloppy/loose shifter on my manual trans
  70. Rusted out headlight bulb harness
  71. Parts!!
  72. Mobil1 oil change interval. Is 10k miles okay?
  73. How easy is it to turn back mileage?
  74. Lexus GFX Rear Lip for 2011 IS250
  75. IS350 hood trim question
  76. 2006 IS350 staggered set up 19"
  77. Replacing Fuel Pressure Sensor. What should I know?
  78. 2008 is 250 radio is on but no sound
  79. Can anyone help finding this part?
  80. Remove fusible link on 2014 Lexus 450H
  81. Does Accel Controller Work for IS350?
  82. Tire size suggestions for 09 2is awd
  83. Power loose on Lexus is220d
  84. 07 is250 no communication with ecu
  85. Lock issue after crash repair
  86. Lexus IS 250 Rear Diffuser HELP!!!
  87. 235/40/18 fronts and 265/40/18 rears
  88. Fuel level sensor going bad?
  89. System too lean error
  90. Phillips 6000k Ultinon HID headlights
  91. Water/Condensation In Drive Side Headlight
  92. Can't hear ringer/call via bluetooth 2006 IS 250
  93. Front bumper spoiler damage
  94. Strange noise coming from engine bay - 06 IS250 AWD
  95. Is 350 differential Gs350 differential
  96. Weird Ticking Noise
  97. Velgen Fitment
  98. New owner - love so far; tires, check-engine light?
  99. Hood and Trunk Support Struts
  100. Polyurethane lip paint problems
  101. Half over or half started?
  102. Looking for 2nd Gen IS250 TOM'S rear lip
  103. Slight rattle when crank up
  104. IS350 - Check engine blinking - Car Shaking
  105. 2011 IS350 HID headlight adjustments
  106. IS250 keyfob
  107. Door actuator problem
  108. HID vs Halogen wiring loom the same?
  109. Is350 engine pull/rebuild (2008)
  110. Trunk lid trim interchangeable?
  111. '06 IS250 AWD need exhaust mid-pipe?
  112. Fog light question
  113. Allen Bolt Part Number
  114. Cooled seat question
  115. Replacing water pump of a GS450h from 2008
  116. Aftermarket radio stock sub question?
  117. Led lighting upgrade IS250 2006-2013
  118. Coffee mug?
  119. 07's navigation console interchangeable with 11's
  120. Please Help with this "recall" (Sticky/cracking dash)
  121. Erase garage door memory setting
  122. Best aftermarket headlight assy option?
  123. Navigation black screen, doesnt turn on
  124. Need a bit of help. Got a U0105 code
  125. Stiff ride question
  126. 2IS' with rear lips and high placement exhaust help/opinion.
  127. Replacement of Door Panel on IS - 2006
  128. NEED HELP!!! Right turn signal staying on.
  129. IS250 Won't Start / No Codes
  130. Wheel tool
  131. IS250 keyfob
  132. 2011 Front on a 2006
  133. Lexus is 250 Front Grill swap for IS F Grill
  134. IS250 Media Art
  135. Turn signals aren't working at all but hazard lights are
  136. Saying goodbye to 2IS family
  137. Stripped Allen Bolt (Intake Manifold)
  138. 06 IS 250 M/T - No Heat & Low Coolant
  139. Only drivers side door lock is working
  140. What's this tube stuck to the backside of dash?
  141. 2011 IS trunk stuff questions
  142. Had To Drill Under Side Sills
  143. Center console wood grain doesn't match
  144. Where's our SPID label at on these cars?
  145. Weird buzzing sound upon opening door
  146. Calling all aftermarket side skirts owners
  147. 2011 IS350 radio question
  148. Is250 eps connector wiring.
  149. 2009 is250 will not start /// fuel pressure sensor
  150. HKS Hipermax LS+ Coilovers
  151. Used Lexus IS250 common issues
  152. Used 2008 IS250 issues
  153. Blown headgasket? Lots of air coming out of the coolant
  154. IS 250 KEYFOB and remote start
  155. anybody try these?? [eBay front and rear lip]
  156. 15 MPG on 2008 AWD IS250?
  157. Rear view mirror upgrade?
  158. For-sale, want-to-buy, want-to-trade go in classifeds forums, not here
  159. Is250 Maintenance Schedule
  160. Maintenance Weekend (Spark Plugs / Intake Valve Clean)
  161. 2nd Gen IS350 to 3rd Gen front bumper conversion?
  162. 2IS non-nav radio diagram?
  163. finally did it ! (Newport Lexus)
  164. Long Time Audi/Porsche Guy's First Lexus - Any Ideas?
  165. New 250AWD owner
  166. Check VSC, Check Engine, Traction control all turned on while Idle. Codes within!
  167. Fujita Intake 2008 Lexus IS250 AWD: Replacement Filter?
  168. Question for you audiophiles or quiet car fans
  169. 2009 IS350 Front Bumper
  170. Clacking sound coming from passenger side dashboard area when making turns
  171. Door Actuator...I think?
  172. High Mileage Owners
  173. Is my wheels and tyres correct?
  174. Just wanted to thank you ClubLexus
  175. Four way flasher turns on by itself randomly
  176. Clinched widebody kit
  177. Custom Front Bumper for '07 IS250
  178. IS350C untrasonic blue ?
  179. '06 IS250 won't start. Fuse help needed.
  180. Can 255/45R18 size tires fit my rear staggered 18's?
  181. For those of us with DI engines....here's a read
  182. Bay Area Lexus Dealership Costs 2017
  183. In Need of Help!!
  184. Stereo Harness
  185. OBX R headers
  186. IS350 2JZ-GTE Swap?
  187. How do i know which package i have First time owner of lexus
  188. Need wiring help for lock buzzer
  189. Bye Gen2 Forum just got Gen3 IS350AWD Fsport !
  190. Need Advice on How to Handle Issue with Starting After Body Shop Worked on Car
  191. Passenger Handle Won't Close!
  192. What loaners are featured these days?
  193. Stock rims
  194. Amplifier: IS250 (2007) 86180-53110
  195. Has anyone ever replaced the transmission pan gasket?
  196. TPMS ?'s
  197. Tire studs replacement IS250
  198. whos here still have their 2006 is250 ?
  199. Engine sounds weird? Help!
  200. Bluetooth problem
  201. Is the 2008 Lexus IS 250 still worth it?
  202. Lexus IS 250
  203. Stock exhaust - driver side exhaust tip hanging much lower than passenger side
  204. 2009 Lexus IS250 engine noise
  205. JoeZ intake
  206. Parking Lot Bumper Hit--Damaged??
  207. 2007 IS350 Code C1203
  208. IS350 video out on the standard nav
  209. Aftermarket exhaust question
  210. Just Purchased '10 IS250 AWD
  211. Paint coming off rim
  212. Radio issues (sporadically works)
  213. IS 250 Heater only hot when engine reved up
  214. New here. Shopping advice? Want IS250 w/manual, F sport?
  215. Best online shop for IS250
  216. 20's rims
  217. Code meanings and advice
  218. Need your opinions on purchasing a high mileage 2006 IS 350
  219. IS250 2010 - seeking advice for work needed on my car
  220. diagram audio / navigation for Lexus IS250 / 350 2011-13
  221. Relocating Stock AMP to inside Cabin or Replacing with Aftermarket AMP ?
  222. Performed IS250 Spark plug change.
  223. How much $ can I get selling my 2009 IS350
  224. Just got my 2011 IS350 F-Sport !!!
  225. New Side Sill Extensions!
  226. My thoughts on my IS 6MT (so far)
  227. No Sound from IS250
  228. Light Bulb under shift knob
  229. Aftermarket Steering wheel info??
  230. What wheels are these...
  231. pulling the trigger
  232. Back in another 2is
  233. Fuel injector replacement
  234. How long are you waiting for your Sticky/Cracking dash recall?
  235. Question 1: Who's replaced their low beams
  236. Intermittent vibration at idle, different to other threads
  237. PPE headers and PPE full dual exhaust
  238. Lexus IS 350 2006 Starter kit
  239. 07 is250 Head Unit Replacement
  240. New to me IS250 6MT
  241. Not UR Typical MAF problem
  242. Electric Cutout
  243. Lexus IS 250 pics | Old San Juan
  244. Finally Got My Lexus!!! <3
  245. Question about Throttle Body Removal
  246. plastic under shift knob
  247. Spacers needed with stock wheels??
  248. 2007 IS250 Rear Differential
  249. XM Radio Issue 2008 IS250
  250. Help 06 suddenly died and starting problems...
