PDA
View Full Version : IS - 2nd Gen (2006-2013)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 [30] 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234
  1. Having some problems with '06 IS 350
  2. IS250 - Can I deal with the carbon build up with only Seafoam?
  3. Offset fitments
  4. stock front bumper question
  5. Where to find Rear Bumper?
  6. Normal coolant level
  7. Is 250 2009
  8. Installing a USB port closest to 2010+ functionality on a 2008
  9. Cheap Imitation Spindle Grill on 2IS?
  10. Replaced Factory Amplifier Still no sound
  11. eBay Carbon Fiber IS-F style spoiler
  12. IS250 spark plug replacement
  13. IS250 AWD transmission
  14. 2006 IS 350 - trunk latch actuator makes sound, but doesn't open trunk.
  15. 18x9.5s all around - 275/35 rears; needs suggestions for fronts
  16. Adding amplifier, what’s needed
  17. 2007 IS250 Passenger lowbeam not working after car washes
  18. Fog Light Aim
  19. 2IS NHTSA Recall # 16V-340, 17V-006, 18V-024: Pass Zone A
  20. Please help, radio/navigation issue
  21. start/stop switch problem (or not?)
  22. In Car Digital TV like JDM?
  23. Compressor issue on my is350
  24. Camshaft positioning sensor
  25. Vinyl wrap chrome window trim
  26. State Referee Ticket - Need help
  27. 2008 IS 250 RWD Oil Filter
  28. What's your favorite IS feature?
  29. Tire size
  30. Rear door / quarter panel gap
  31. Tire size fitment (235/45 and 245/45 and 255/45)
  32. Rear Roof Installation mounting question
  33. So boys..new too forum..Not too lexus..im bodyguy..but mechanical..advice from techs
  34. Relay part number
  35. IS 350 Transmission Fluid Change
  36. My is Lexus simple and clean
  37. Timing Chain Issue 2006 is350
  38. 3mm Spacers - spacer uses help me out!
  39. Overfilled oil IS350
  40. Bough this a few weeks ago...
  41. Can't open the window for Lexusis250
  42. Wheel fitment question
  43. Will a 2011 IS F Sport front bumper fit on a 2007 regular IS250
  44. Injector Driver Pin Out
  45. LCD screen and buttons have no power
  46. YA Brake Thread (Specs, brands and vendors)
  47. Help [seeking performance and exhaust advice for '08 IS250]
  48. 2012 LED headlight conversion
  49. no start
  50. AC acting up
  51. philips ultinon d4s legit?
  52. No check engine light, engine won’t turn over...
  53. 2006 Lexus IS 250
  54. 2012 headlight parts number
  55. Mark Levinson problem
  56. Looking into buying an IS
  57. Help with part number
  58. Car Alarm Ajar goes off when turning left ??HELP!!
  59. This IS 350 Underwent a Tremendous Weight Loss
  60. 2012 IS 350 What to look for?
  61. 06-07 IS 250 Worth Buying Now in 2018?
  62. Need help identify 2nd IS250 (2011) NAV connections
  63. Passenger and rear window don't work.
  64. Rx300
  65. recommendation on water pump 09 250
  66. Buying used 2007 IS350, lots of questions
  67. Rear spoiler tape
  68. Anyone here change their own oil?
  69. Whats this car's worth?
  70. Lost mileage range and loud muffler noise on 07 is250 awd
  71. After market Tesla android NAV system
  72. P0175 - System Too Rich Bank 2 Oxygen Sensor Replacement
  73. how do i switch navigation system on or off
  74. Exhaust delete cats for 2006 IS 250 AWD
  75. 2008 IS250 AWD eBay Replacement Midpipe?
  76. Anything I should be aware before I look at this 2012 IS250??
  77. replace shift shaft seal on a 2006 lexus is 350
  78. HID bulb on then goes out!!!
  79. Lexus IS250 Ecu fault or what?
  80. Aux jack loose.
  81. RWD Staggered Fitment
  82. USRC from ISF?
  83. What is normal compression for is350?
  84. How high does IS 350 trunk pop up when using remote?
  85. Passenger power windows not working
  86. 2006 is250 park, drive, neutral all lit
  87. Fault code
  88. Clicking noise at low speeds
  89. 2006 is250
  90. Faded Lexus Radar Logo
  91. Aftermarket fender
  92. Looking for IS 250 exhaust
  93. Sticky Steering
  94. Determining my trim package
  95. Oil Looks Uneven On Dipstick
  96. Rubbing sound when going downhill
  97. Lexus is 250 headlights
  98. Lexus IS 220d egr valve change or blank plate
  99. is250 manual owners... Launching issue , clutch clunking?
  100. Questions about used IS250
  101. 11-13 headlights
  102. Check engine light on p1276
  103. Rear brake light and indicator light don’t work
  104. Headlights
  105. Turning off TC's beep sound, possible or not?
  106. IS 350 Automatic Transmission Concerns
  107. 11-13 headlight "computer"
  108. DIY coolant flush
  109. Location of OCV filter?
  110. Question about fog lights
  111. Tire wear out uneven
  112. EVAP Componenet Question
  113. fillerneck install question
  114. MyLparts OEM Wheel Question
  115. Help needed! VVT Solenoid?
  116. where do you get your OEM Lexus parts?
  117. Front LCA Bushings. What is my best option for my daily driver
  118. Where is reverse light fuse?
  119. rear strake clips
  120. Seatbelt height adjuster stuck
  121. AFS Light+ randomly working headlight
  122. Change navigation system language from Japanese to English
  123. Tire wheel protection plan for aftermarket wheels?
  124. Alignment done
  125. Need help replacing VVT solenoid
  126. Camshaft connector and a broken bolt
  127. 2007 IS250 137k miles - High Idle on Startup and other things
  128. Broken bolt + camshaft position sensor connector
  129. 2GR-FSE expert comment wanted! Knocking??!
  130. IS350 - 2008 - Intermittent Blower Fan
  131. Check Engine Light and VSC flashing
  132. Looking for a salvage project
  133. 3M Wrap engine bay covers?
  134. Testing
  135. Testing
  136. Car won't start
  137. 2007 Lexus IS250 awd/ differential or trans?
  138. is 250 convertible smart key module
  139. Rough Idle and Reduced Power?
  140. heavily rusted fuel pump
  141. Anyone running 20x9 wheels?
  142. IS250 AWD Coilover Owners: What are your spring rates?
  143. Thinking of Getting Midpipe--CA Legal?
  144. 2009 Lexus IS250 Tail Lights
  145. is250 v6
  146. Looking to get an 06+ is350...
  147. Stereo Sound Disappear
  148. For those of you that manually calculate MPG...
  149. 2006 IS250 Auto to Manual Swap (Any input appreciated)
  150. 2IS LED DRL Headlight to '06 IS350 With Factory HIDs
  151. AWD IS250 Exhaust Q
  152. Switching oil brand and weight/
  153. Quick latch question
  154. Can I use multi spark plugs in my is250?
  155. 2007 Lexus is250
  156. Yes its a repeat but dammit I need answers! [ISF conversion]
  157. techstream
  158. diamond pattern floor mats
  159. Spark Plug Replacement DIY
  160. Looking to buy first IS - 2008 IS350 High Miles/Mileage
  161. Do You Need To Replace All 4 Tires On Your AWD Vehicle?
  162. Too many lights on dash
  163. TE37SL: Real or fake?
  164. Best place to buy Exhaust?
  165. Spec-D Headlight question
  166. keyless entry driver side not working
  167. What is my car worth
  168. Is the Mark Levinson system rare in the IS250/350?
  169. My IS250 disabled by security/immobilizer system.
  170. Wheel/Tire question
  171. Courtesy Door Light Won't Work
  172. Thoughts on this Lexus IS250!
  173. Please suggestion on head lights. Thank you!
  174. OEM sub
  175. Excellent condition 2007 IS350
  176. Car Rattles Like an '87 Dodge Omni
  177. Offset help
  178. Squeaking front center vent in the heat
  179. P/s servo steering problem
  180. Replaced my Steering wheel chrome badge - worried!
  181. Light Bulb/LED replacement Guide
  182. need help with AFS won't level properly...
  183. 3rd gen f sport wheels on my 2007 2nd gen is350
  184. Should I buy this 2011 IS350?
  185. Car won't start
  186. Spare tire question
  187. HID Headlight Upgrade questions
  188. stalled while driving
  189. Official Break Water Blue IS Thread
  190. re-drill tire valve hole
  191. Help with Wheel specs and Spacers
  192. Amplifier!!!!
  193. OEM Rear Bumpers - Are they the same?
  194. Best Cruising Speeds?
  195. Biggest Wheels
  196. Car Swerving
  197. Should I change my Auto Trans Fluid again?
  198. 20" wheel question
  199. Shattered Sunroof Glass
  200. some advice on my 2006 IS250 EVAP gas leak
  201. Fuel Pressure Sensor on 2006 Lexus IS250
  202. LED recommendations for Mirror/Puddle Light replacement?
  203. Wow Want the is350 but different tire sizes is disturbing...
  204. Where is my power steering reservoir? 2012 is250
  205. 2006 is250 after lexus engine r&r
  206. Led headlights
  207. Wind Noise
  208. Remote Low Battery Warning * After Installing New Battery! *
  209. 2006 is250 growl
  210. my IS 250 couldn't start 4 hour prior to parking
  211. My dashboard is part of the recall program.
  212. Restitch Shifter knob to match New Wheel?
  213. Non nav to navigation....
  214. Modification-2008 is350
  215. IS350 Blank Screen
  216. Where to get OEM headlights?
  217. 2007 IS350 - Reverse and Auto-Title Side Mirrors
  218. 19x9.5 wheels need help!!!
  219. Lexus IS250 display, ac, audio not working
  220. check system light went on
  221. Heated/cooled passenger seat airbag light...
  222. not so new IS owner from Hawaii
  223. Headlight Washers Staying up after Use
  224. Air bag recall and heated seats not working
  225. Check VSC and limp mode after Seafoam
  226. Headlight glass
  227. Oil Filter Housing
  228. Cruise control dead. Lexus has told me the ECU for the car must be replaced.
  229. New lexus owner
  230. Swap out yellow bulbs for white
  231. 2006 IS250 AWD transmission replacement woes
  232. Catalytic Converter/Exhaust Needed ASAP
  233. 2007 radio and nav works no audio volume
  234. Recommend me an oil catch can
  235. Need help on air bag indicator light on?
  236. Rear 255/40/18 or 265/35/18?
  237. Aimgain 2008 IS250
  238. Rattle at startup, is it worth fixing myself
  239. F-Sport Intake Tube compatibility question
  240. Exhaust tailpipes and back bumper
  241. Aftermarket amplifier
  242. Why does the 2007 IS 250 AWD get better mpg than a 2010 IS 250 AWD?
  243. Tires
  244. Passenger Headlight - light goes off and on
  245. IS250 Front Noise
  246. Noise coming from engine when the humidity is high
  247. Check VCS, PCS, Brake, ABS light. No check engine light.
  248. 2006 Lexus IS250 VSC, PCS, Brake/ABS light?
  249. 2Gen Headlight Glass Repair
  250. OEM nav headunit into non-nav factory?
