- Replace Engine Coolant?
- Wheel Finish is Peeling
- Need a New Key for IS250 2006
- Sewell orders issues... anyone else have issues?
- TSB on my 07?
- Matte Black or Matte Graphite?
- 2006 IS250 Replacement Rear View Mirror?
- 06 headlight choices?
- Newish Oil Wrench Tool
- Second set of TPMS for winter tires
- Amp is shot
- WTT - goes in the classifieds, not here
- Different Side Mirror Dimensions
- Rear Bumper Protector
- Oild Filter Question
- Clear Plastic Scuff Guard
- Traction control = code P0172 and P175??
- IS350 OEM wheels on IS250 AWD
- Brake Fluid
- Headlight help
- Need help with my current Tire setup
- some front lip help.
- 275/35/19 will fit in the rear?
- New Lexus Owner, seeking advice!
- What type of grill is this?
- HID Looking Halogen Replacements
- Starting issue With new clutch
- Power steering failure
- Thoughs on how to make exhuast louder. Resonator delete?
- Rough Idle at Stop After DLG Actuator Gear Recall
- Car alarm goes off when reconnecting the battery HELP!!
- sticky dash and now this..
- IS lost some zip?
- What would you pay for this IS350? Need your Expert input!
- 08 to 12 f sport conversion question
- Rather Purchase IS250 with 95k miles for 13k, 110k miles for 12k or 125k miles 10.5k?
- Another TPMS issue (Already Searched..)
- Stylish Chrome LED Tail Lights from Spec-D
- Some stupid questions about (2011?) 2012+ Headlight conversion...
- Vacuum noise when idling.
- Fsport or Injen
- Buying an is350
- another navigation problem. *with PIC*
- Doing the 2014 front bumper
- Cloudy Headlights and Fogs
- CPO warranty
- need your advice please code p0430 catalytic convertor
- IS300 vs IS250 Resale Value
- 2006 IS350 Navigation cannot connect to external link
- Is this a good deal on IS250 07?
- State referee ticket
- Alignment and a control arm?
- 2is dash removal and instalation
- Intermittent Headlight Problem
- Buying a 100k+ 2006 IS350
- Replaced "bad" alternator to fix loss of power steering but P/S is still out .
- Melting
- CEL P0051 code
- fart smell accelerating with ac off, but not when ac on
- Ever played around with Plasti Dip?
- spray paint
- hands free no GPS
- Good deal on 2008 IS250?
- Is this a good deal guys, need your prompt input!
- Potential IS250 buyer-How common is the carbon buildup?
- possibly lost key fob
- Power steering failure. Need to replace alternator. How?
- Need your feedback for purchase please
- Mirrors stopped tilting down!
- Pitted M2 Exhaust tips
- CP0 vs non-CPO IS 350
- Cost to replace new front bumper
- *** CEL (p0420) after ZLA recall? ***
- Engine Sputtering/almost stalling Experience
- Oil Maintenance Reqd Warning Light
- Key Fob Issue/Not Starting
- Moving to CO, need advise
- IS300 rims on IS250
- Catalytic Converter p0420
- Osram Xenarc CBI vs Philips Ultinon bulbs
- Should I purchase this High Mileage is250?
- fight red light ticket?
- Water Pump / Valve Cover Gasket R&R
- Would you guys trade rims for free?
- Dumb question maybe you can answer?
- 2012 Headlights, Pre-Pinned or Buy Factory Pinned
- $10 Exhaust? Ayyye...
- Two "Must-Do's"
- 2011 Lexus IS 250 OEM Battery warranty
- Yellow Fog Lights
- 2007 IS250 AWD (142 miles) for 10k, worth it ?
- Are these Volk te37 or te37sl?
- Three Gens of IS here in our meet in the Phils
- IS250 on Poorboy's World Site
- IS350 Engine Cam-Gear problem finaly Fixed pt2
- Custom Audio Install (price check)
- Alignment
- Changing 07 Staggered Wheels to 09 Wheels - TPMS?
- Paint Code
- IS 250 Brake Pads and Rotors?
- F sport gille question
- Help! Power Steering doesn't work after doing the IS-F Steering ECU mod
- Help....Odd vibration/shimmy
- 2014 LED Foglights for 11-13s on Sewell?
- 20 inch rim tire recommendation
- Pioneer AVIC 8000nex
- Coolant flow
- Strange Rumble/Hum
- Brightest HID Conversion Kit - Suggestions?
- Inspecting high mileage IS350s
- Anyone with experience with Duraflex body kits?
- Stainless Steal Shift Knob Mod
- IS250 long term reliability and miles report
- Down here in New Zealand
- Car Audio and Tablet Install in a 2008 IS250
- Is this a good deal for stock 18's?
- Red LED bulbs for puddle lights
- Rock gaurds?
- Location of oil pressure switch? (2006 IS350)
- So I took my car in for a smog check and......
- Borla, magnaflow, or flowmaster straight pipe exhaust?
- Dual Cup Holder
- pictures finally please tell me what you think
- PLEASE HELP - Did I get taken by the dealer
- Tpms saved me from a flat!
- 2007 options, color codes, etc.
- Tan to Black Interior Swap
- Bellhousing issue - please help
- Need Help With A Part #
- Would you buy this? Custom IS250
- Satellite Radio
- Choosing the right IS350
- 2007 IS250 Engine Rattle/Tick
- is revving an Is350 to 6.5k rpm bad?
- What Color is my Interior?
- lexus is cd changer question
- Rear end clicking under hard acceleration
- Roadrover CL8018 8" Navigation IMPORTANT INFO
- AWD air suspension questions
- Said I wasn't going to mod, but...
- 2007 Lexus IS 250 won't start after rotating tires
- Replaced HID bulbs... weird streaks! Help!
- ML unit or not?
- where to buy is radio 1809
- smells like gas - please help
- looking for hub centric wheels
- Will these tires work on my 2008 Lexus is250
- Front end lips
- Rear brakes squeaking
- Okay to install brace/rear sway with just wheel ramps?
- Took Some Photos Today
- Suspension Question
- License Plate Flipper!
- Overheating IS250
- where I can buy lime-green brake caliper spray??
- 2006 IS250 awd loud ticking
- would you do this?
- Myride Diffuser
- F Sport Mesh Grille
- OEM TPMS Sensor and Black Valve Stems
- Lexus Is250 navigation flex cable issue
- Alignment Spec is wrong ?
- Help needed! Please! Car battery replacement...
- HELP NEEDED! Bought an IS350 from the Lexus Dealer with 2mm rear brakes left!!!!!!
- Im late!
- Lexus IS250 and IS350 Dashboard Defect Possible Lawsuit
- Fender problems when you're lowered
- Cheaper alternative to newer 2012 LED look?
- Tom's ecu
- What Volk wheel is this?
- Does your car do that?
- Pics of Blue Onyx Pearl ISs
- Issues with driver side when going over bumps
- How to put plastic panel under glove compartment back
- Tein s-tech springs
- New here !
- +20 offset question
- Aftermarket touchscreen HVAC issue may be resolved
- Ipod integration.But is there other options?
- Can you get tire PSI readings from your IS?
- Thoughts - Meisterschaft SUS Exhaust or F-Sport
- what do i need to do to make this fit?
- I need help!
- 2011 is250 FlyAudio
- NextMod Vertex rep lip
- She needs a name b/c she GROWLS!!!
- IS350 Limited Slip Diff Options
- Lowering 07 IS250 AWD
- Is the IS350 quiet and rattle free?
- Bumper Plugs... Yay or nay?
- looking for one stop shop in Atlanta area for upgrades
- Why is IS350 AWD so rare?
- Front strut dust boots and CPO
- So I took my 350 on a canyon-type road today
- Air Conditioner Problem.... Passanger side has warm air
- VHT nightshades RED
- 275/30/19 tire on 19x8.5 (35 offset) wheel?
- Is350c or sc430 ?
- LED Light Bar In Lower Bumper
- Lexus IS350 2014 really that much better?
- 2011 is250
- Link to recall for is350 2006?
- Summer tires in rear and all season in front
- Can Lexus dealership refuse performing recall service?
- Door Locks (ALL) don't work: Body ECU? Help!
- How long will a IS 250 last?
- Luxury package?
- Rear View Mirrors
- Amazing tire deal
- Water Pump and Pulley replacement costs.
- roof racks
- Push start and non-working door locks
- Issues with Navi screen
- A/C Not Working?
- Squeaking when I turn my tire
- Is Glacier Frost Mica "white" or "silver?"
- gopro hero 3+ with microphone good locations?
- FS and WTB threads go in the classifieds
- Side Window Vinyl Removal, Repair, or Replacement
- 3M clear bra for entire car
- If you had to... (Aftermarket 17" Wheels)
- Lexus dealership good with lowered cars?
- Need your opinions!
- temporary knocking noise immediately after engine start - IS250
- Are the is350 headlights glass or plastic?
- OEM 2012 Headlights
- Protecting Headlights
- Intermittent Start
- Blue-tooth question for '06/'07 IS 350
- IS250 PreOwned Certified 45k service @ Lexus or Toyota?
- affordable is250 carbon fiber roof spoiler
- 2006 is 250
- IS350 fuel trim problem-Update
- '06 IS350 Auto Headlamp question
- Mark Levison speakers on stock unit good?
- advice from IS owners
- Where is the air conditioning low pressure recharge port on a 06 IS250?
- Just purchased IS350 '06
- Weird comment about Hankook Ventus V12 from a reputable tire center
- IS-C fender fit 06 IS250/350?
- Lost my keys along with key fob.
- Aftermarket Parking Sensors - Reverse Light Tap Location
- IS350 30,000 mile service coming up, what to do?
- Ebay Sport Pedals
- Engine Bay Covers
- Only Lexus Dealer Can Do Alignment?
- Transformer sticker on your IS?
- Question about changing the oxygen sensor
- Hooking up subs with my factory head unit
- Clear coat on factory rim or color?
