PDA
View Full Version : IS - 2nd Gen (2006-2013)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 [25] 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233
  1. Replacement headlight housing and front grill
  2. Tighten your coin tray!
  3. IS250 Recommendation
  4. VSC, ABS, BRAKE, TRAC Warnings On, Speedo not reading!
  5. Lexus IS 350 Issue.
  6. Need help with injectors
  7. Crashed is350, need opinions
  8. Fsport big brakes on is350 question
  9. DIY paint lip or send to shop?
  10. 3IS Steering wheel on 2IS?
  11. Fuel Leak Help
  12. Panel lights on, no A/C no PS
  13. Stop engine keep radio on?
  14. Review: IS250 IS350 Amazon/eBay pre-painted bumper
  15. Performance Mods
  16. Extremely Bad Gas Mileage
  17. Is the IS350 the right car for me?
  18. Battery and brake pads replacement question
  19. Lock car while running?
  20. So Cal local looking for 3is bumper install.
  21. My midpipe leaks
  22. lexus IS 250 Exhaust
  23. "11 IS350 fuel rail recall...make CEL turn on?
  24. Air inlet fasteners?
  25. Troubleshooting (2008 Lexus is250) car wont start
  26. Radiator Cap Broke. Piece fell into housing
  27. IS250 Carbon Build Up Issue
  28. 06 Lexus IS350 code p2714
  29. Headlight Problems
  30. Card holder
  31. new to the is world looking for audio system upgrade info
  32. 2006 IS250 112K Miles
  33. P0430 and pending P0420
  34. Strut removal issues.
  35. Code P0606?
  36. 2IS 18" F-Sport Wheel Lug Nuts
  37. Headlights fluttering
  38. Toyota coolant and prestone ?
  39. Inner Fender Well
  40. 2IS battery failure warning signs, before it fails (15mo battery)
  41. Buying my first Lexus IS 250
  42. Hood struct/shock leaking
  43. 2008 IS 350 high idle, power windows, memory seat malfunctions
  44. New battery install review
  45. rear parking sensor sound signal activation
  46. Trunk back seat door
  47. My custom Vland Headlights build
  48. Visual Engine differences between IS250-IS350 (06-13)
  49. 07 IS250 Walnut Sand Blasting
  50. Locking center differential
  51. 2008 IS250 Non Nav Parking Brake Wire?
  52. Dead Board or just a great Car?
  53. Questions on upgrading premium stereo audio on a budget
  54. IS250 AWD 2012 changing miles to km
  55. 08 Lexus IS 250 awd rim and tire specs
  56. Looking for a diffuser
  57. Aftermarket 17" wheels on a 2IS
  58. Is250 sr what does the sr mean?
  59. 07 skid ecu in 2006 is250(an info i cant find out)
  60. Cosworth Panel Air Filter 68% OFF
  61. 2007 is250 p0016-19
  62. Lexus IS250 AWD 2006 Bank 2 sensor 2
  63. IS 250 Does the intake manifold cold start injector clean valves?
  64. P1072 p0175
  65. 2007 IS350 Code P0017, Crank/Cam Position Correlation
  66. WA JDM LED HID Fog lights for 2006 Lexus is350
  67. Leather Vinyl wrap sticky dashboard on 2IS?
  68. 2008 Lexus IS250 Awd rear axle vibration?
  69. Air conditioner amplifier replacement
  70. Heater blower not working as it did yesterday
  71. How to adhere something to dash without damaging it?
  72. rear fog lights diy?
  73. buying a 2006 is250 with 200k
  74. Looking at new to me IS 350c....service history and questions
  75. OEM remote starter for IS 2012 AWD
  76. 2006 IS250 RWD engine tries to turn over but won't start
  77. Any good window visors?
  78. Intake filter help
  79. swapping f sport springs out for oem
  80. How to disconnect subwoofer in IS250?
  81. Push Button Replacement/Issue
  82. build to get going
  83. Bad alternator or bad serpentine/drive belt?
  84. I have a 08 IS250, Can I replace the radio & cd changer with a OEM nav?
  85. Wheel Fitment Question
  86. Any AWD IS 250 is non snow/ice areas?
  87. 2019 IS-300 Navi/Radio Info/computer randomly reboots
  88. 2006 Lexus IS250 Transmission Shift Solenoids
  89. 2006 is350 RWD [what is best way to remove engine?]
  90. 2IS IS350 Aluminum Radiator
  91. Reverse camera black screen
  92. 2012 IS250 F-Sport Headlight bulbs LED ? (6k temp color)
  93. Bought a 07 IS250
  94. Lexus IS350 2nd Gen Transmission adventure
  95. 08 is250 radio & climate not working
  96. Code from obd c1241
  97. Check System—TPMS
  98. IS250 Year 2007 USING ADVICS CALIPER FOR IS350
  99. Need help! [what is smallest spacer that works for volk ce28’s?]
  100. Kazz Sports Grill
  101. Have some doubts, about getting used IS350
  102. 2IS trunk with Uppababy Vista stroller?
  103. my window is off track, any ideas?
  104. AC Compressor locked
  105. 2008 IS 250 Trying to Program 2nd Smart Key
  106. Tranny replacement or Selenoid replacement
  107. 2IS MOSTPLUS Tailights = Vland for $230 with Amazon Prime
  108. I'm at a crossroads with my 2IS350 :/
  109. cleaning dashboard 2006 IS 350
  110. 2011 is250 center console
  111. Brand new battery is dead.
  112. Navigation screen making funny lines, and goes black sometimes
  113. Upsized wheels - next step?
  114. Black Trim Piece in the bottom of the Glove Box coming off
  115. VLAND Headlights fuze
  116. Help: How to Reset CHECK VSC LIGHT ON A 2006 IS250
  117. Do I need new tires? What is the best tire choice for 2007 lexus is250?
  118. 2012 Swapping 18" to 17" help
  119. 18" Wheel Offset
  120. All-season Tire recommendations for IS350.
  121. Back Bolt on Intake Manifold
  122. I need help on servos
  123. 2011 IS350c map dvd replacement
  124. Help please!!! 02 sensor pigtail
  125. A-Pillar Airbag Clip (Part #)
  126. IS250 on standing mile
  127. oil leak from oil pan
  128. Painted ebay bumper? Anyone tried them?
  129. High pitch noise engine bay
  130. Strange Headlight Issue
  131. 06 IS250 Wont Crank
  132. Heater blowing cold
  133. Car is blowing cold air when idle but operates normally when accelerating.
  134. Need help Transmission filter and gasket
  135. Just put on Michelin Pilot AS 3's
  136. 2006 IS250 Dead Amp
  137. Disable TPMS? 07 IS250
  138. Chemical Guys - Best Car Wash Bucket Kit - Best price I've found!
  139. Looking for a 2nd or 3rd Gen IS350
  140. Keyfob not required for Homelink to work??
  141. What packages do I have?
  142. Do all 2IS have auto tilt wheel?
  143. Steering Rack
  144. Has my alternator failed?
  145. A/f sensor bank 1 sensor 1 and 2 help!
  146. Glossy Black OEM Wheels or Keep Them As Is
  147. Rattling noise inside cabin
  148. Thinking of selling
  149. Please Help! ABS, Brake Light, VSC, P/S lights on.
  150. 07 Lexus IS250 wont start. Help please.
  151. ETC switch not working - 2006 is 250
  152. 2006 is350 oil leak between engine and transmission
  153. 07 is350 rear diff
  154. passenger map/visor light not working
  155. Factory hid headlight problem
  156. 4 Gallon tank for air ride?
  157. 2008 IS 250 AWD turned 11 years and 101K miles
  158. Differential , Need help , grease ? or oil leak ? Don’t know
  159. High mileage 2nd gen '06+ IS350 worth it?
  160. Meatiest Tires on Stock Wheels
  161. 2011 IS250 AWD abnormal tire wear
  162. Temporarily lost power to interior?
  163. No Audio at Ignition only !
  164. Headlights for base model is250 2010
  165. Carbon buildup issue?
  166. Clunking noise from rear pass tire under acceleration
  167. Clutch kit Options & Flywheel Thoughts
  168. Slow Acceleration After losing control of Car
  169. Any 2009-2013 owners have sticky dash/door panels
  170. 2011 nav headunit work with an 06
  171. CEL not working
  172. 06 Is220d Radio losing signal.
  173. Lowering the IS350 and BC BR Coilovers
  174. Wheel fitment!
  175. Fuel Pump for Lexus IS250 2009 $1200 OEM legit?
  176. Transmission problems, any advice is appreciated
  177. Buying 07 IS250 76k Miles Good?
  178. IS 2nd Gen Alternator Bolt Torques
  179. 2006 IS 350 I'm looking at shows oil consumption...
  180. DIY repair info site, ALLDATADIY.COM $13, 12mo
  181. IS300 (06/2013) Roof Rack Recommendation
  182. A great way to greet the new year!!
  183. New battery new alternator- no power no start
  184. Matching Color to IS350 Nav Dashboard?
  185. Someone got into my car
  186. Teach me how to fish....
  187. 07 IS 350 Loud Brake Squeaking
  188. Weatherstrip for camera hole on trunk garnish
  189. Lexus is250 rattling sound
  190. Black F-Sport seats on fleabay if anyone is interested
  191. Replacing license tag assembly with reverse camera IS 250 07
  192. 07' IS350 p1072 p0175 running rich bank 1 and 2
  193. 2011 IS250 Common Problems
  194. Does Facelifts matter?
  195. CR2P wheel setup
  196. Third gear and reverse lost on same day, 06 IS350
  197. Navigation and buttons around it dont work? Black screen
  198. Check vsc light on - no check engine or traction light on either! PLEASE HELP!
  199. Battery and alternator change car won’t start
  200. Cylinder 1 2008 is250
  201. Scosche ITCLS01B on 2011
  202. LED Fog Lights From Amazon
  203. 06 is250 ECU pin out/diagram
  204. How Late is too Late
  205. Temp gauge position during cold weather driving
  206. Please help IS250 startinfg problems
  207. Engine undercover (aka splashguard) picture request
  208. Torque specs, Intake manifold?
  209. 2008 Lexus ISF - No Sound From Radio
  210. Does your IS350 sound louder on cold acceleration?
  211. Steering Rack Bushings?
  212. New IS350C owner
  213. Replacement side mirror glass - missing part?
  214. jerky up shift at low speed (10~15), is it time to change transmission fluid?
  215. Recommendations for budget bucket seats?
  216. Front Bumper Question
  217. Best Way to Replace a OEM Subwoofer for a 2007 IS250
  218. Magnaflow Exhaust reps?
  219. P0761 fault....car drives normal
  220. Front end noise
  221. D4S HID Bulb Help
  222. +30 offset
  223. IS250 navigation not coming on and windows won’t roll down.
  224. Cheap OEM Fix for Auxillary (AUX) Port
  225. Navigation off by 50+miles
  226. Battery light ON after ALT replacement IS250 07
  227. Serpentine belt replacement for IS 250 2006
  228. loud noises from evap preceeded CEl
  229. IS350 ABS Pump/ Brake actuator location
  230. ECT Power Mode Trans Didnt Shift
  231. Muffler delete question
  232. U0105 2007 is250 awd no start or crank
  233. 06 is250 interchangeable body
  234. Rims
  235. 2007 Lexus is250 SERVO MOTOR
  236. Display/ navi screen potential new upgrade?
  237. IS250/350 navi/cluster cross-compatibility
  238. Difference between IS250 2009 and 2013 Model
  239. Bought a car that burns oil and puffs out blue smoke, need advice
  240. Weird Ignition Problem (08 is250) HELP!
  241. Do you have to drop the subframe to change engine/motor mount on IS250 with MTM?
  242. Passengers side headlight issue with aftermarket conversion
  243. Its been great CL.
  244. 1st to second shift
  245. Headlight experts HID to LED for 2010 IS250
  246. 2007 TPMS light coming on
  247. Intermediate shaft on AWD
  248. Wondering if it is possible
  249. Is250 console swap
  250. Front Blinker issue
