- Jerky in certain conditions
- Looking at buying a '12 IS350 F-Sport w/ 106k miles for $15k. Bad idea?
- Disk changer
- IS250 Noises
- IS350 E85 custom tune result!
- Sweet looking bumper on this 2IS!
- Piano black interior
- Aftermarket parking sensors on factory harness
- Fidanza flywheel with Clutchmaster FX250 clutch..Impressions
- rear view camera replacement
- EMERGENCY.. need engine help, ASAP!!!
- Gasket
- is250 AC problem
- F-Sport Intake Part Number
- Rough idle at start with codes
- 07 IS350 K&N Air Intake
- Code P0420 - Catalytic Converter
- Can/Should I go lower?
- 07 IS350 Front Lights
- Will these TPMS work
- Ac blows cold air on one side and hot air on the other
- Steering slightly resists sometimes at high speeds
- Ebay cheap headers question
- Does anyone have instructions on how to install the damper door assembly?
- Winter tires
- Is oil burn normal?
- 2nd airbag recall?
- Removing quarter panel carpet.
- Is220d 2008 power loss
- Blinking front defroster light
- IS250 Drainage problem
- Aftermarket fiberglass sideskirt question.
- driver side door lock
- Non ML amp bypass
- 06 IS250 RWD exhaust leak
- Upgrading to 2012-2013 headlights, question on what is needed
- Who serviced your car
- Looking to replace my headlights, what do you guys recommend?
- Replacement fog light electrical connector and pigtail
- My rear diff has the worst rust you've seen. Prove me wrong.
- Help cars leaking fuel
- Electronic Conversion Kit for 2007 lexus is350?
- 2IS 5W30 vs 5W40?
- Airbag recall service
- Check engine and traction button lighning
- 2ad-fhv Ac compressor
- a/c outside and inside circulation buttons
- Burning Smell Car Wont Start Anymore
- Quick Question 2IS Grill Fitment
- Need help on deciding which exhaust to buy.
- Switching instrument cluster
- IS250 AWD Weird Trans/Electrical Issue
- 06 IS250 Rear Bumper Question
- Is350 rear seats removed, slower 1/4 time???
- Rear diffuser
- Traction control and Engine light on
- need help with code. P0174
- Is250 AWD with rims & springs upgrade
- Boosted 2007 IS350 Turns Heads
- P/S problems help please?
- Anyone got a European or Australian IS?
- Driver side window doesn’t work
- Steering wheel stitch-on perforated leather & F emblem
- Lexus IS250 All windows and door locks
- Thinking about getting the E85 tune
- Should I trust "Pre Wired" 2011+ Headlights from Ebay to install on My 2010
- Please help! Battling CEL '06 IS250
- Lexus IS 350C part ID
- Considering a performance exhaust, muffler/resonator delete? Read this
- 2007 IS250 Radio Sound is Weird
- part number
- Wheel Bearing kit lexus is 250 2007
- Slap Chopped
- OEM Replica Nav Unit
- Rear sway
- Car acting up with no codes
- 2 maintenance items I performed on my IS 350 that made a noticeable difference
- Build ideas? Lexus is250 2006 rwd
- 2008 Is250 Not shifting under load
- 2008 IS 250 Headlight replacement
- P0031 and P0051 IS250
- LED on speedo needles doesnt work
- Underbody cover DIY
- Pleased with walnut shells results
- Adding OEM backup camera - need help with wiring
- Tire pressure sensor question
- Does anyone know if broken cabin air filter door effects all controle of fhe front ve
- Twins again!
- Steering wheel stopped tilting in and out after shop worked on my car....
- 2006 IS350 - How to turn on heating??
- CV axle help
- My 06 awd
- PPE Headers / High Flow Cat
- Light bulb E=MC2
- What do you guys recommend using for the interior & leather on your IS?
- INGS Front Lip Replicas?
- Clutch pedal feels notchy/bumpy when releasing
- Is it possible to replace just one of the bottons on the rear view mirror?
- Interior leather wrap
- Michelin Pilot SPT AS 3+ tires
- Where to get genuine parts?
- Just introducing myself- 2010 IS 350 Sport
- IS250 Not Cranking
- Alternative fix for sticky/melting dash- Coverlay Manufacturing
- 2IS with PPE + HFC + Megan Racing Midpipe & Tanabe Axle Back
- Turn Signal Out??
- Horn Is Dying
- Stock Exhaust Drone?
- Quick Question about suspension
- 2006 IS250 Engine Temp goes down then back to normal when accelerating
- Led strips on fog lights what do you think?
- 08 IS250 hood replacement
- Check headlight system warning on...
- Voltage Signal when you lock the car
- LSD question
- Using an amplifier from GS350
- AP2 S2000 Exhaust Tips
- 2006 is250 awd cel
- GM8157ZT wire diagram and schematic
- oversized oil filter & housing for 2007 is250 RWD
- Dieting Gone Right or Wrong: IS350 Under Pressure
- Cold Air Help?????
- Part Replacement Name
- Is this the rarest Lexus IS?
- help, headlight out
- F Sport Intake Question
- Super sick Lexus IS!
- A/C condensation drain outlet
- 08 is250 awd not working
- Rear clunking noise under acceleration
- Stock HID Ballast brand and model
- HELP PLEASE! Cabin filter door linkage missing
- Aluminium sports pedal
- Anyone help identify this leak? pics
- Picked up an 08 IS350
- Navigation,Climate control,Radio and buttons not working
- 2IS Volt Gauge
- 2006 IS250 Radio Replacement
- Desperate,need advice on what can be wrong with a 2006 Lexus is350
- Lease is up in December - Looking to buy a 2nd Gen IS350
- P0500 IS220d
- Bad universal joint question
- Permanent +12v in Front Door
- Transmission fluid and gear oil fluid
- IS250 intake duct on IS350
- Vossen CVT
- How do you know when alternator is going bad ?
- Another ashtray phone holder mount DIY in a 2IS
- Clunking noise when putting car in drive
- 07 is250 rear sway bar Location
- Best parts stores anyone?!
- Exhaust info needed
- Bumper and bumper supports (HELP PLEASE!!!)
- SRS airbag light of death (B1000) - Help!
- 2009 is250 transmission
- help please
- Please help
- Crank no start, once.
- 2009 is250 AFS HID housings- High beam LEDs
- Weekend toy?
- Dreaded transmission Codes
- Rear license plate LED lights
- Radio turns off
- Caliper covers
- Coin under cup holder
- Fuel Injector location on 4GR-FSE?
- 06 IS350 shut off while driving (Help)
- What does this grouping of Codes mean?
- Noise when driving
- What material is the steering wheel made from
- Warning to all: Burtman Industries (carbon fiber products)
- 2010 will not start after changing alternator
- My vents and air controle does not work can someone tell me how to adjust my vents
- Warning light
- What is this part called?
- Question about high beam cap
- Has anyone installed kahtec?
- NEED HELP wheels won't stay balanced
- Look!!! What is car recording and storing? Yota tech wanted....
- 2007 intermittent not turning over - help!
- 2006 IS350: Won't start or even attempt to crank when hot unless jumped
- Brake pads and rotor recommendations
- Do I have a carbon build up issue ??
- best intake for is250
- blinking third light 2is
- My 2006 is250 still needs jumps....😢
- Bluetooth AVRCP version
- Backup Camera ideas
- Shift boot
- Clicking noise from behind the front wheels when making U turn...
- Oil leak from head gasket?
- 2009 is250 auto transmission
- 2007 IS 350 TPMS replacement
- Cigarette Lighter No Bueno Anymore
- Replacing stolen passenger side rear view mirror
- Is 13.4 too low for voltage at idle
- 2011 is350 check headlights on
- Help please
- Where are the grounded locations?
- Keyless entry locking intermittently does not lock
- IS250 - license plate moulding panel removal
- Fuse Box clarification - clear plastic cover
- Door lock & Rear curtain not working
- Interior window peeling away
- Dasaita 10.2" Android Head Unit
- lights
- Constant beeping after opening door and car off. Please help!
- 09 lexus reading codes P0172/P0175 after putting new intake?
- Steer Arm Broken! How does this happen?!
- Ac connection points
- Do anyone know where these are located? (Pics)
- 2008 Lexus IS 350 Katana Shift Knob
- Is250/350 inevitable door lock problem
- IS350 random theft alarm
- Help with finding part number for 2006 350is alt fuse bank
- My gasoline is literally boiling.
- Spoiler install
- 2010 IS250 Steering Wheel Lock While Driving
- Need HELP! AIR BAG LIGHT after installing Chinese Android stereo unit.
- Alibaba Nav Unit
- Signs of oil within spark plug tubes again
- Please help identify. 18"
- Vacuum on A/C & let it sit overnight with no loss in pressure. AC warm again
- Invidia mid pipe with muffler delete question
- My IS suck and I can find the problem 😵🔫
- Thinking about buying a 06 IS250 please help!!
- Ported lower intake manifold installed!
- Is it worth it?
- 07 IS250 weird click in the rear End
- Help with cross thread bolt
- 2007 lexus is250 awd transmission fluid
- Any idea if this is oxidation vs clear coat issue?
- Who still loves the 2nd Gen Lexus?
- Car Just Turned Over 200K Miles!
- 2006 Lexus IS 350 no start
- Transmission mount
- What’s that noise? Do you know?
- How Do You Replace Window Glass (Front Driver Side)?
- Brake Job help!
- 08 is350 all passenger door lock issues
- Car won't start
- 3rd transmission?! Is that possible??
- '12 IS350 New Owner Sounds/Observations & CL MemberFeedback
- Odd feeling about new wheel hub bearing
- How Do You Remove Rear Rotor Lexus IS350?
- Time for upgrades....
- Help Identifying Lip
- Ticking, tapping sound while accelerating in Drive
- Car won’t start. Brakes won’t depress
- Any help with these OBD scanner test results?
