- VSA light and misfire codes
- Brake pads! What y'all using!!
- Is350 turned off wont start back up
- Term (2IS)
- Lexus is replacing my IS350's Dashboard
- 2006 IS250 transmission problem.
- Need YOUR expert opinion
- Will these rims fit my is350?
- 2007 IS350 150000 hard to start but starts
- has anybody tried the Sony XAV-AX8000
- Power and Ignition supply for instrument cluster
- First NORCAL Lexus Meet of the YEAR!
- LED Conversion Kit (Lexus IS 250, Year 2008)
- 2IS Help Me Decipher Whats Happening With My Engine!!
- 2IS Hidden Wiper Interval Features? Yes!
- Tesla style radio for 06 is350 with nav
- HKS HiperMax GT IV
- My IS250 is jerking and not sustaining it's motion
- Help Deciding Between 2 Used IS 350's
- Let’s See Lexus Wheels
- 2013 lexus is350 VLAND OR STOCK
- Lexus advises to uses 5W30 instead of 0w20 in 2nd gen IS
- Suspicious Service from Lexus Dealer
- Paddle Shifters
- Good Car Battery Dies Very Quick!
- Another Tesla Style Nav Unit - With OEM Style Buttons!
- Car turns off when shifting
- OBD Apps | Torque Pro & OBD Fusion with PID pack
- Stupid (Mustang) Wheel Question.
- bought used 19in f sport wheels
- Canada spec radio??
- VLand vs OEM output
- Amsoil Oil Filter for 250
- General Information Request
- Kali Maa shakti de
- 2006 Lexus IS250 Dead after Battery swap
- For Sale, Want to Buy/Trade threads go in the marketplace only
- Navigation Connector Conversion?
- Short shifter project for 2IS complete and a success
- Part name?
- p0172 is back!
- Alternator Interchangeable with Toyota cars?
- Power button question
- Radio and amplifier pinout diagram
- Service/Shop Manual (not Owners’ Manual)
- ABS and Brake lamps but no code?
- Trac light and check engine light
- 2010 IS250 with 45k miles - looks pristine - should I?
- 2008 IS250 Repairs help!!
- 2009 IS250 DRLs
- Is250 p/s light
- Rwd boys! Hows driving in the snow?
- For-sale items go in marketplace - not here
- 17" MSW wheels on an IS350
- Tires! Staggered or square?
- Is350 Wont start (won’t turn over really) battery good
- RR Racing tune for IS350
- Contest, who has the highest mileage IS250 ?
- Navigation system and display system not working
- Looking at a high milage 06 IS350
- Losing break fluid
- Replacing mid-exhaust
- IS250 2007 Aux/Bluetooth/Carplay Options
- Own a 2008 LS - want a 250 "real" manual trans car
- Considering a High Mileage 2006 IS 350 RWD
- RPF1 on tungsten pearl?
- 2008 Lexus IS250 doesn’t start
- Need Guidence (IS-300) 2008 Mark Levinson SUBWOOFER
- 2008 is250 all warning lights up
- Carbon build up engine replaced but check VSC light still on
- Running out of ideas with this code.
- Nav back connections diagram?
- Resistor and capacitor on secondary wideband o2 sensors
- Tach needle not working when cold
- High Mileage Transmission Fluid Change
- Headlight Shuts Off Intermittently
- 2006 IS350 androids head unit installed
- Genesis track 19 wheels on 2nd gen ISx50
- Anyone doing long distance driving?
- Symptoms of bad alternator
- Crankshaft Sensor - 2008 ISF
- Anyone have a good trans pan gasket part #?
- Sold my IS250 about a year ago and bought a 19' RDX
- High Mileage Car Check-Up
- Used Buying Guide
- 2006 IS350 wont crank. New battery
- Opinions and advice on Idle
- Question on tire sizes
- Impressions of the IS350 after almost 4 months of ownership
- tire sensors
- Downstream denso sensor for RWD
- Front seat bolt thread pitch
- 2009 is 250
- 07 is250 with problems
- How does a slipping auto transmission feel
- 2007 Is350 tranny code P0986
- Climate and radio dead
- New 19" ebay wheels
- IS250 Coolant Change
- 2008 IS250 Electrical Problem
- No Sound Amp
- What makes up F Sport besides appearance?
- Bluetooth Issue
- I need help finding Parts for a 2012 Lexus is250
- Can't Communicate with IS 250 OBD
- help: code B1795 occupant detection ECU corrupted software
- Question on installing LED Bulbs
- Front bumper scrape bottom of the car is damaged.
- What is this sound inside the car coming from my AC system?
- Help with my A/C
- BC Racing replacement parts
- How can I get to subwoofer?
- Opinions on a used IS F steering ECU
- Lexus is250 wont start No brake lights...
- WInter time block heater
- 2008 IS350 Headlight cracked, bulb out
- Vland headlight aim adjustment
- Opinion on Price of 2007 IS350
- Oil and Oil Filter Recommendations
- Replacement Navigation Solutions
- New Owner 07 IS250 AWD
- Black screen 06 IS250
- IS250 AWD rear end help needed
- ISF Rims on IS250
- 2009 is250
- 87 for a month instead of 91 *RESULTS*
- Help on wheels size
- Boys I need your story on MAINTENANCE
- Tranny Problem that NOBODY can solve!?
- Wheel pattern
- 2008 IS250 Display is dead. No lights and buttons work
- No sound after sub/amp install
- 06 IS350 Cuts power under full throttle
- Year to year differences/looking to buy
- spark plugs
- My IS250 won't start
- 2is Amp dead again any options?
- Smart key card on 2007 is250
- IS250 Limp Mode CEL 3 codes disappeared after restart
- New noise & unknown part on 2006 IS250
- 07 is250 went to limp mode and 3 Errors and back to normal
- Screws/Fastens for Radiator Support Assembly?
- Manual Transmission RA63 VS RA62
- No more red triangle!
- Clunking sound when backing out of drive away and going over bumps
- Temp gauge shows lower after long drive
- Clunking nose when turning wheel. Ball Joint?
- AC Compressor Replacement 2006 Lexus IS 250 AWC
- Driving without instrument cluster
- help needed to identify engine tapping noise on is250
- car pulls all over road
- possible IS purchase..some questions...
- VSC Check with trac off light
- HELP!!!! Trying to program my old 2Is keys to my replacement ECU
- Wrecked IS250: Parts Fitment Questions
- Removing Rear Muffler section of exhaust IS250
- Driver window rattle help.
- IS350 Code P0020 - Camshaft sensor problem
- Pre-facelift vs facelift models
- Questions about replacing rear axles.
- Time to change IS350
- Melting Dashboard -- out of warranty
- Who knew.... 2013 recall for stickies
- Anyone replace a rear CV axle on 2011+ 350awd before?
- Cabin Temperature Sensor
- Red SOS Light On All The Time?
- 12000 for a 2006 IS350 w/ 45k
- MPX Override for Fog lights when running lights are on? Help
- P0172 & P0175 on 2006 RWD IS250
- P0051 IS250 Manual RWD
- HID to Halogen headlights
- IS350 AWD Fitment
- Power Steering Blues
- Sunroof jammed on right side
- 2008 Lexus IS250 Outside Mirror Glass Replacement
- Help: bumper cost and touch screen problem
- 2008 IS220d Sensor Problem
- Rough and low idle and O2 and MAF codes
- M2/manzo exhaust any good??
- Best exhaust under 400$?
- Should I SWAP my '08 IS350 for an '08 IS250 6MT???
- 2006 is250 awd Driver side rear wheel isn't moving
- Weak battery or dying alternator?
- IS 250 2nd Gen Hood Hinge DIY Installation?
- Lexus IS250 2007 electric seat stuck in back tilted position - help!
- Lexus IS250 2007 automatic seat won’t tilt back or forward
- Throttle controller no lag extra quick???
- LEXUS IS 250 steering wheel is stiff and stuck in a locked position
- Lexus IS250 Code P2118
- Time for a new IS
- Awd engine drop into manual rwd car swap
- Need help. URGENT (should I buy an IS with engine codes)
- Cold start isn't loud?
- INCREASE gas mileage? APEXI throttle controller? DOES IT WORK?
- How to out car in neutral with a dead battery
- Replacing bank 1 sensor 2 02 sensor?
- IS 250 2008, trunk actuator
- Upgrading factory Navigation IS 350
- Diag bad wheel bearing
- Fusible link white with blue line wire
- IS250 Heater Core Replacement
- AWD front axle nut removal
- How do I know if the rims fit my babe?
- IS250 Satellite Switch & Instrument Cluster
- 2007 IS 250 - Airbag light on after navigation repair.
- AWD Splash shield
- Oil catch can?
- 2006 IS350 none navigation system to aftermarket
- Headlight Identification
- IS250 Bluetooth problems
- Hello from the Netherlands & Unique iPod mod (?)
- Is350 scan codes
- Help! 2 problems with sons 2007 IS250 w/Navigation no premium sound!
- 2009 IS350 Engine test out of car
- New owner
- head unit replacement
- PCV Breathers: YES or NO
- sewell headlight set for sale
- Door Sensor Over Triggering
- A few questions on the IS 350 engine sounds
- Bolt replacement help.
- VLAND Tail Lights & Puddle Light Activated front and rear lights
- Increased wind noise/whistle from front of the windshield
- 08 IS250 with 322k miles for sale
- Has anyone tried a lightweight flywheel with SPUNG OEM clutch combo?
- DIY: Fusible Link Block Removal for 2006 Lexus IS250
- please help!! car wont start
- Sold my 08 is350
- Where should i wire my custom tweeters into?
- Need help with intake plenum questions
- Who has Radar Cruise control?
- Pls I need your help 2006 Lexus is 250 speedometer wouldn't read and my P/s light is
- Wheel hub assembly SKU
- Swapping out the main ecu
- DIY Auto-Folding Mirrors for £6.49 (GBP)
- What kind of bulbs do our fog lights use? 07 is250
- IS-350 key fob, is it illuminated?
- Battery or alternator dead?
- Lexus Smart Card Key.
- Serious question
- Outside mirror compatibility question
- Starting vehicle after 3 years
- Possible IS 250 Purchase
- Acc wire location
- How else can I get into my trunk?
- CEL Please help
- Help with Drone in Cabin
- Car won’t start
- Noisy stock exhaust
- Pin-out diagram for instrument cluster
