- 2007 IS350- AC blow cold only on max- HOT after 65??
- Need help "low tire" light on.... its annoying!!
- is350 running lean ?
- Jacking Points for Oil Change
- Cluster bezel removal
- What tire size for my 19"
- My vinyl wrapped car :)
- My blacked out 08' IS250
- Taillight upgrade
- Which bulb to buy?
- IS250 OEM Chrome wheels flaking/corrosion problem
- My New Wheels: 19" Forgestar CF5 Piano Black
- Lexus IS250 on 16" wheels
- navigation not recognizing voice
- ISF Gauge cluster in ISx50 - M mode shifting gear display
- Successfully Chipped My IS
- 06-08 Lexus ISx250 Headlight fitment Question
- Quick question about wiring + lighting
- carfax
- Headlamp bulb HID okay to use?
- how to leave lights on while motor is off?
- My iPhone Setup
- 0W-20 Synthetic Oil = Extra Power?
- chrome wheels or black wheels
- New-ish Memeber from the U.K
- 2012 Headlights - LED strip as a blinker?
- Best looking wheels on SGM?
- navigation v12.1
- Wheel resurfacing
- Why is the Lexus/Toyota Navagation so pathetic?
- ordered an f sport exhaust need opinion
- Buzzing Noise When Driving
- squeaky drivers seat ?
- Removing rear window tint = Defroster & GPS malfunction?
- outside window trim peice removal
- Electrical Problem...HELP!!!
- Powder Coating LFA Wheels, What color?
- What body piece is this?
- need some rim advice for is250
- 2007 IS250 AWD Vibration while in "Parked"
- Anybody else with bad rear door locks?
- Proper hight for 19 vossens
- hood wrap ???? suggestions? questions
- Auto light feature problem
- hi new to the forum with a question
- dangy's last set up, TE37s! Farewell
- Grip-Set feature VIP Lexus IS250 AWD
- Audio problems
- Audio problems
- Rock chip repair question
- DRL lights on 2006 model?
- 2008 is 250 awd
- 2011 IS250 and iPhone5 issues? / new Firmware?
- Another new guy
- fender liner vibration
- Toyota Techstream and Cable for $35.(sorry no pirated software discussions allowed)
- Help!!! Display says trac off and the check engine light is on!!!!!!!!
- price high or ok for 2007 IS250 56K $20K?
- Help - Are there any DIYs on how to remove the F-Sport spoiler?
- Need Help! [slow cranking]
- whoo hoooo...jdm fogs
- Aux & USB Cable Fix
- Great News***
- Did I miss out on a good IS350 deal?
- Question about bluetooth and navigation in 2009 is250 AWD I just bought
- What u guys think?
- Traded in my 2009 IS 250 for an Audi A6
- Air suspension/electrical help needed
- Remote Start 2006 IS350
- Brake pedal vibration
- Find me some wheels, and i will paypal you $1000!!
- Looking to Buy Used IS350
- Apexi throttle controller blinking help?
- Need advice from you pros on lowering is350 on 20s
- Efficient ventilation mode settings. Defogger.
- Wheel Guru's Please Help! Front and rear fender help
- CEL P0335 code?
- Linea Corse Rims
- Newbie needs help-
- car revs up when braking
- IJDMtoys perfect fit interior LED who has them
- Wheel Rash Repair Phoenix Area?
- Door handle rattle
- Question About Frame Damage
- How often do I HAVE to replace oil filter?
- 2009 IS250 downgrade 18" to 17" set?
- New to CL: Picked up 2012 IS 250
- NEED HELP with lug nuts
- Time to call ebay again....
- 08 is350 hid bulb finally out ;(
- low tire pruess light on
- rock chips
- Stock 09 IS250 "Photoshoot" after a good Detailing
- new is250 owner, first mod
- 08 and 09 same headlights?
- new to club lexus
- powder coat
- For winter, do I need new tires?
- He finnally came after me DASH RATTLE!!!
- Does anyone know the part number for the illuminated door sills?
- does this startup seem normal to you
- So winter + IS = ?
- Injen Sp Cold Air intake
- 2011 LED headlight wiring
- Problem with aux port
- Photoshoot with Hoovey2411 with Vossens
- Tires for 07 AWD IS250
- IS 2014 picture
- Lowered on 19's? Need your opinion...
- 2007 Lexus IS250 AWD salvage vehicle - need help sourcing parts
- some fun with CF wrap
- Strange "Check VSC" message during start.
- 06 is250 !!! new to CL
- HELP with cleaning the intake valves myself.
- Steering Feel Issue - 08 IS350
- Paint Experts Please Help !
- cyberscorpi0 & d2fresh Photoshoot
- Looking for Tire Wheel Expert for simple question
- car shaking between 75-85 MPH!!
- ECU is not reading my TPMS Sensor!?
- 2010 ISF Replica Wheels
- Help! Which Springs?!
- new member *** need more idea****
- 2013 Build Your IS
- Lexus IS350 Maintenance question
- New IS owner!
- Wekfest Texas Pictures
- post body work advice - should I take it back?
- ISF tailsss
- 2006 Lexus IS350 Rear Sunshade Wiring Help..
- Some picture whoring from wek'fest!
- 255-40R18 Special Deal $135/tire only
- Is this normal or do I have a transmission problem?
- PoorForm IS350 - Mini Video
- Quick detail this weekend
- Got bumped today...
- push starting the car problems
- In regards to painting bodykit
- Thinking about just getting a Front lip
- Poor Tire Life?
- ClearCoat
- Rear Lip Help
- "Check system" and TPS
- Driver side HID turns on then shuts off?
- 19"vossen wheel and tire price
- Wheel tire offset and lowering question...
- oil change at 10,000 miles????
- is250 awd turbo kit & ecu reflash needs to come !
- Head Unit/HVAC issue
- is 414/month too much for a 2010 is250 lease?
- Is my payment worth keeping my car?
- New member with a bad MOD BUG
- balding tires, should I be concerned?
- Shop to Install new Clutch?
- Need Help With Recommendations for Replacing Front Tires!
- Found a 2011 IS250 with hail damage
- IS250 Hks Hi Power + X Pipe
- 06-08 compared to 09-10 lips
- Wheel Suggestions?
- A little headlight advice....
- Just picked up an IS... coming from a FX
- Alias's Photoshoot Thread
- TR-1 vs 3m carbon fibre vinyl
- For those with INGS kit, how much you pay?
- Should I consider this IS250?
- Toms Rear Lip, Need help please
- Winter Driving
- Phone charger that fits
- REVIEW: iJDMTOY 7.5W High Power 921 LED Reverse Light
- safe way of removing trunk spoiler held by 3m trap?
- Lexus IS350 Starfire Pearl - Ecru or black leather
- Headlight washers
- Help: Jerk Did Some Damage. Pic.
- Oem spoiler swap
- Anyone have Fierce Instinct Tires?
- New into this forum
- Opinions please! CF grille surround- yay or nay?
- what size stock exhaust?
- Linea Corse LC818
- Short Shifter
- 15,000 mile service costs $270.00?
- Need help! Need new passenger side headlight unit
- Battery dying, need quick answers...
- New Lexus owner - 06 IS 350
- Warped Plastic on IS 350c
- rock chips on front lip
- Finally Got one! 2012 Lexus IS 350 F SPORT PACKAGE
- Confirmed Concept for Next Year’s IS Coupe
- Need help finding this part
- 09 IS 250 Navi problem
- New member! IS250
- For those who have the INGS lip refitted on a 2009+ model
- Rotor replace Question
- Need inner and outer rear cv boots AWD
- New Member - cr0w21 - IS250 F-Sport Starfire Pearl
- Extended studs
- Anyone bought from iJDMtoy.com?
- Dash warning lights help.
- New Wheels New Stance - SF S5 CF
- Aftermarket Soundsystem help
- Update: iPhone 5, Lightning Cable and 2012 IS350
- New member, New Car
- iPod nav connection - automatically goes to same song when plugged in
- black top
- extended lug nuts for is350
- Will a 8x10 rug fit in my is250?
- 2012 lexus is 350 f sport pkg
- Latest Recall: Engine Misfire 2006-certain 2010 IS250/IS250C
- Front Defroster light blinks
- Goodbye Club Lexus
- 2012 350 f sport HID's?
- 09 is250 had this happen to any of you
- Rubbing Issue IS250 AWD, Genesis Track Wheels
- 2011 rear bumper on a 07
- What color this looks like
- Headlight Cuts Out When Turing Car On Only
- 2012 (v12.1) Nav Maps Available Soon
- need help cel an vsc on
- highbeam problem help
- rear license plate screws
- FS and WTB posts go in the classified forums only please
- Need help fighting a radar speeding ticket.
- Few mods done!
- Roof Spoiler
- Flyer in door
- Anyone have this problem when do carbon wrap center piece interior
- Now or Later?
- Just joined the Lexus Family
- Proper DIY tire rotation??
- Nav unit does not dim at night
- Rear Sunshade Help
- Block heaters.. necessary?
- Need help diagnosing weird noise
- Trunk Latch
- Question about Vaistech iVIC programming
- Plastic over P R N D next to gear shift is peeling
- Any NEGATIVES to an 07-08 IS 250?
- FlyAudio and iPhone 5...
- How to lock your car while running to warm it up during the winter.
- iPhone 5 Lightning Cable Compatible?
- 2006 HID Headlight out...help!
- Recent Crash Tests IS Doesn't do well?
- Let me Introduce myself
- Will they consider this salvage
- SRS Light On
- Is250 w/19x11 Meisters
- Anyone know what this is? (underbody)
- Replace engine room no. 2 r/b (front controller)
- Radiator flush?
- Installation of Wald Spoiler
