- question about lowering
- How to remove drive shafts from differential is250
- check sonar flashing signal on dashboard?
- Front Mesh Upper Grille 2009-2010
- Swapping Alternators (2007 vs 2010, etc.)
- 3IS Style eBay VLAND All LED Tail Light DIY Install
- Projector lights issue/ IS350 2012
- P0660 code, after replacing oil pump in IS250 2007
- ML subwoofer issues
- brake pad caliper bolt is sticking out!
- how to reset abs lights on 2009 is220
- extra filter inside air box.....
- Suspension, Wheel, Tire Fitment Questions
- Way back Wednesday!
- Front suspension bushings?
- Front Dash part numbers Guide....Replacement
- Timing chain tensioner
- Transmission fluid change
- Gain 2MPG by a simple mass flow sensor clean!
- Black Screen Navigation system/ climate control issues
- Another car starts, dies, then refuses to start
- Swapping 2nd gen rims with 3rd gen rims
- Should I switch to 10w30?
- Best struts?
- door panel
- Blinkers not working after battery swap.
- Just bought a 2010 IS250 - odd clicking and rattling noise. Any ideas?
- 08 Lexus IS250
- Cleaning the Throttle Body
- Need help with fitment and wheels
- question on Rims
- Help!!! Airbag light!
- questions on the carbon build problem
- is250 2006 camber kit questions
- Rear Bumper Cover
- 2012 is250 steering wheel not center..
- help and referral on smoke test and tires
- Thoughts/Concern on purchasing 2011 F-Sport
- 06 IS Cluster Re-calibration HELP!!
- Leather Steering Wheel Cover
- Clunking noise when turning the steering wheel (parked/stopped)
- IS250 Won't Start - Stutters
- Building wheels for the 1st time need expert advice
- Can I program an IS F key for my IS 350?
- Replacing one nav unit with another
- Will Techron or Seafoam buy me some time?
- 2013 IS250 C iPod connection problem
- 2009 IS250 won’t start complete shutdown except for radio
- Made some lexus is250 boot (Trunk) interior ceiling hooks
- New Lexus F Sport Wheels selling for $70!?
- Greatest car I have ever owned.
- 2012 IS250 Pioneer Amp Question
- New here and picking up my IS250 looking for some true advise from real IS250 owners
- New here and looking for some exhaust info and help thanks
- Headlight Problem
- Fuel door not opening
- LED Headlight bubbling - how to open headlight up
- Bluetooth Auto Connect and Play Solution
- Question about wheel spacers
- Where the heck is the fuel filter?
- DLG Recall - Gaskets
- Lexus IS250 Rear Tire Size
- RR Racing Steering Wheel
- 2007 IS 250 AWD - Electrical & Dash Warning Lights Issues
- Tein S Techs for AWD 2IS
- Where can I get this front lip?
- Upgrade Ideas
- Rotted Windshield Cowl Trim
- Metallic Rattling Noise. Loose Heat Shield?
- Car not starting
- IS250 2008 evap valve
- 2011 mirrors on a 2006
- What the hell, right exhaust fell off
- 2010-12 mirrors: Base vs. F sport
- IS250 Blower Motor replacement
- Xenondepot Bulbs Question
- Ikon Motorsports
- 06-13 IS350 Exhaust Setup
- Gas in Engine Oil (2006 IS250)
- Interested in a car out of state. Lexus inspection good enough?
- Weak key fob remote range, 2IS
- Looking for dash harness
- Battery & Alternator FAILED — ideas?
- Thumping like a flat tire
- New Lower control arm and bushings but I hear creaking noises
- Lexus IS showcased at Tuner Evo!!
- Lexus is250/350 OEM is-F STYLE grill replacement
- Halogen headlight with AFS
- New here
- Conversion from nav to non-nav
- IS F (partial) Interior Swap
- IS250 wining from engine bay
- Has anybody ever installed "flashing brake lights"?
- Looking For Somebody with stock rear camera pictures 2011 is250
- what happens when you change solenoid, but get check engine light comes on
- Anyone know what this button does
- How to get bluetooth in a 2009 IS 250 AWD Navigation With Mark Levinson
- Vibrating
- lexus IS sitting pretty at Tuner Evo Daytona!!
- Replacing Struts
- FM Radio Stopped Working Suddenly
- Best Exhaust for a is350
- Isf bumper swap with no fenders
- RWD Axle question....
- TPMS Code ID2
- Engine replacement in IS350 to purchase or not?
- Steering wheel problem
- Startup glitch with key fob
- Anyone Ever Install A Racing Seat?
- Wheel Shop Wrecked TE37... now in wheel hell... Help!
- Does the exhaust need to be removed to replace extension housing seal?
- Is there a DIY on replacing rear drive shaft on '08 IS250 RWD
- 2016 is350 seats in a 2008 is350
- trying to fix dent
- Trunk Color
- Cylinder misfire, codes: P0304, P0354
- Switch, Stop Light - Replace? *CHECK ENGINE LIGHT CAUSE*
- Is220d wont start, no light on start button, battery ok
- Flashback Friday!
- IS250 6MT Feature
- Purchasing question
- Rust on Body Panels?
- My car isn’t responding to the key
- Enkie wheels offset
- Which stretchy tires to buy for 19x10?
- Spare tire IS 250 2007
- Help!! I have a 2008 lexus is 350 [steering acting up]
- Black screen 2009 IS 250
- RPM climbs to redline while stopped (unintended acceleration)?
- Which of these bushings are the rear?
- Toyota dealer- oil filter question
- Needing a little help with error codes please
- Navigation Security Code?
- Oil level on dipstick WAY over normal level when cold
- 255 tyre on 8J wheel
- IS 2008 Steering Wheel Issue
- Hit a deer with my 07 IS350
- ***2010 is 250 no sound***
- '06 IS350 Dash Replacement Help Needed
- 2006 IS350 Throttle Body Cleaning Part 2
- USB/Ipod Issue
- Wheel question
- 2006 IS 350 - Wheel Rim Size
- Which tpms sensor?
- Product Inquiry: Replacing Front LCAs
- Glasspack Mufflers
- Anyone have an eBay discount???
- Battle Damage (Rear Bumper + Rear Passenger Molding)
- XM sat radio kit for 2008 IS 250
- License Plate Lights Dim ('07 IS250)
- Lexus 2IS posted up at Cars and Coffee!
- Engine Knock 2006 IS250 AWD 169K Miles
- Can't find these 2 part numbers :(
- Navigation and buttons around it dont work?
- Wheel Questions
- Gps touch screen not working!!
- LEAST favorite feature of the 2is
- 2006 IS250 battery casing "sensor"?
- ? Custom PID for TPMS Read out on Torque Pro App with OBDII EML 327 reader
- 2009 IS250 navigation question
- Annoying rattle from sunroof area upon road bumps
- 2006 Lexus IS 250 Engine Swaps
- Drl
- 2008 is250 and 2011 is250
- 2006 IS 250 Smoke in Engine Bay & No Electrical Power
- IS250 starting issue
- Carbon Fiber Wrap
- Please help! Buttons on CD changer unit not working!
- 2nd Gen. is250 2006 AWD Clanking sounds coming rear differential area
- Brakes help please.
- Powdercoated 18" F-Sport Wheels
- 2012 is250 vs 2012 isf headlight
- 2007 Is350 Loud Gas Smell Driver Side
- 2012 base vs. F
- IS250 RWD Automatic Transmission interchangeability/compatibility A960E
- Navigation Screen Flickered?
- Thinking of getting 2012 IS350 F Sport
- is250/350 trunk part number
- Headlight rebuilt
- 07 is 350 need help. My IS doesn't start
- Having some problems with '06 IS 350
- IS250 - Can I deal with the carbon build up with only Seafoam?
- Offset fitments
- stock front bumper question
- Where to find Rear Bumper?
- Normal coolant level
- Is 250 2009
- Installing a USB port closest to 2010+ functionality on a 2008
- Cheap Imitation Spindle Grill on 2IS?
- Replaced Factory Amplifier Still no sound
- eBay Carbon Fiber IS-F style spoiler
- IS250 spark plug replacement
- IS250 AWD transmission
- 2006 IS 350 - trunk latch actuator makes sound, but doesn't open trunk.
- 18x9.5s all around - 275/35 rears; needs suggestions for fronts
- Adding amplifier, what’s needed
- 2007 IS250 Passenger lowbeam not working after car washes
- Fog Light Aim
- 2IS NHTSA Recall # 16V-340, 17V-006, 18V-024: Pass Zone A
- Please help, radio/navigation issue
- start/stop switch problem (or not?)
- In Car Digital TV like JDM?
- Compressor issue on my is350
- Camshaft positioning sensor
- Vinyl wrap chrome window trim
- State Referee Ticket - Need help
- 2008 IS 250 RWD Oil Filter
- What's your favorite IS feature?
- Tire size
- Rear door / quarter panel gap
- Tire size fitment (235/45 and 245/45 and 255/45)
- Rear Roof Installation mounting question
- So boys..new too forum..Not too lexus..im bodyguy..but mechanical..advice from techs
- Relay part number
- IS 350 Transmission Fluid Change
- My is Lexus simple and clean
- Timing Chain Issue 2006 is350
- 3mm Spacers - spacer uses help me out!
- Overfilled oil IS350
- Bough this a few weeks ago...
- Can't open the window for Lexusis250
- Wheel fitment question
- Will a 2011 IS F Sport front bumper fit on a 2007 regular IS250
- Injector Driver Pin Out
- LCD screen and buttons have no power
- YA Brake Thread (Specs, brands and vendors)
- Help [seeking performance and exhaust advice for '08 IS250]
- 2012 LED headlight conversion
- no start
- AC acting up
- philips ultinon d4s legit?
- No check engine light, engine won’t turn over...
- 2006 Lexus IS 250
- 2012 headlight parts number
- Mark Levinson problem
- Looking into buying an IS
- Help with part number
- Car Alarm Ajar goes off when turning left ??HELP!!
- This IS 350 Underwent a Tremendous Weight Loss
- 2012 IS 350 What to look for?
- 06-07 IS 250 Worth Buying Now in 2018?
- Need help identify 2nd IS250 (2011) NAV connections
- Passenger and rear window don't work.
- Rx300
- recommendation on water pump 09 250
- Buying used 2007 IS350, lots of questions
- Rear spoiler tape
- Anyone here change their own oil?
- Whats this car's worth?
