Need a bit of help. Got a U0105 code
Need help with my Fuel Injector Control Module 06is250
Greetings,
So Im getting the U0105 code and my car wont start. So the code is reading about the Fuel Injector Control Module. I read that i should start by checking all the fuses related to it including the ECU fuse. Does anyone know what fuses are related to the FICM that I should check. Also to check the connections on the FICM and make sure the ground connections are clean and solid. I cant find where the FICM is on my 06 is250. I read other lexus model owners say its behind the backseat driver's side panel.
I want to check those before possibly buying a used FICM incase mines is done.
The module is right behind the air box snorkel. Facing engine to your left. Follow the lower radiator hose up to the thermostat housing. It has a plastic cover so you'll have to remove it to access it.
Look at post #7 in the link.
https://www.clublexus.com/forums/is-2nd-gen-2006-2013/727925-2007-is350-dead-code-p0200-p1235-any-help.html
sam12345
32
12-29-12 07:09 AM
opsta
07-27-06 09:33 PM
