- IS 220d Steering Rack
- Aux port to AUX/USB port
- Oil Change Affected Transmission?
- Airbag light on code B1650
- Good Michelin Tire Set for IS350
- Replacing AC system
- Aftermarket seat fix for passenger occupancy sensor and Light
- IS250 2010 Misfire codes Cylinders 5 and 6. Help.
- Where do i start lol check engine codes.
- Drivers side Keyless Entry not working
- 2011-13 IS 18x8.5 F-Sport Wheels Front Clearance?
- AWD 2IS owners, do your front or rear tires wear faster?
- 2011 Bumper with/without fog light lip spoilers
- Washer pump and fog lights not working
- New here, air ride input?
- help me find the part number for this dash part?
- Desparate for HELP with Loss of Power 07' IS250!
- Strange ticking sound on acceleration. Wheel bearing? (sound clip inside)
- Bumper Scar Advice
- Wix 57047xp filter looks weird?
- Is250 steering column motor question.
- These unknown parts on my HVAC system and what do they do?
- How to remover the whole dash?
- No crank when start button pushed
- VSC and Cel on P0420 code catalyst threshold
- Engine problem
- Help me name this part that broke off my HVAC..
- Mist coming out of vents when using AC
- Bird chirping noise when engine is running
- 2012 IS250 Front driver and passenger window rattle when cracked
- Help recommendation for headlights
- 2008 is350 bluetooth connection with galaxy s9 - no music
- Would you say its a bad battery?
- Dual Climate failure - Hot on Drivers side and Cold on Passenger
- Help recommend a rear bumper diffuser, many styles and vendors to choose from on eBay
- Help recommend a new front bumper lip, so many styles to chose from
- Anyone with experience putting on nia bumper to lexus is?
- check engine vsc light - can someone please help me.
- Buying is250 manual
- Drivers window won’t roll down
- All 4 TPMSs dead?
- Looking at IS350s...Timing chain/gears replaced normal?
- Unlocking of car with key fob is intermittent
- 2010 is 250 awd flooded
- HID replacement ballast
- Really bad rattle noise in right side of dashboard ( video)
- Changing water pump. Silicone sealant on gasket?
- 2008 isf diff upgrade from an is350 diff?
- What's leaking? Front differental?
- Is Lexus honor lifetime warranty tinted problem?
- NEED HELP! Transmission/Transfer case
- help me out on some bolts...
- Headlight and Foglight Issue - Randomly Turn Off
- Installing factory spoiler on boot lid
- ML Subwoofer Static/Rattle
- Fuel Pipe Recall / Leak Question
- Tungsten Pearl 2IS Wheels
- I bought my 2006 IS 250 used and don't know what pkgs it has
- 2006/2011 IS250 Buying 2nd hand
- Single Exit Exhaust DONE
- Underbody screws
- IS 350 AWD midpipe
- Serious problem with hvac , tried everything i could find on google
- Jacking from front cross member ok?
- Help recommend upgraded LED Tail lights, Brake and Reverse
- Lexus IS clubs in U.A.E.
- Car starts then dies...
- My first wreck ever, not my fault. How do I deal with Geico?
- Issue with adjusting headlights
- HELP! Passenger Destroyed and wont open
- **Fuel Leak Recall IS350**
- Trunk - 2011 IS F fit on 2006 IS350
- head gasket ?
- Headlight and Bumper Question
- During air bag recall dealer broke dash
- Looking at an 08 IS350, couple of issues
- Help figuring out what offset wheels to get.
- Tail light bulb burnt
- HID AFS to Halogen
- Any DYI on rear wheel bearing replacement?
- Should I repair and salvage title my IS350 or take the Writeoff Check?
- Power Steering Light and Thermostat Temp Rising
- Preferred year model for IS?
- 2006 IS250 Skipping
- explain audio diagram connectors?
- beatsonic SLX-140L climate control display help (no power?)
- Check Engine Vsc Light
- 2011 6mt traction control question
- Handling on my 2008 IS250 is very strange
- '11 IS350 F-Sport, $18K worth it?
- Carbon Fiber Wrap Melty Door Panels - Good Solution?
- 2009 IS 250 Purchase - ICE - New stereo needed
- replace is250 spark plugs....manifold removal mandatory?
- warp speed! no wait thats a hiccup...
- Has anybody drove on Hankook Nobel 2 or Continental DWS06
- Can car start without audio/radio/security connect?
- Warning light on instrument panel
- Misfire Recall/TSB Continuing Issue
- Invidia Midpipe sound
- 2008 is 300
- ISF replica Front End
- 2008 IS350 ticking noise in exhaust after fuel pipe recall
- 2008 OEM wheels?
- Question about splicing a LOC for aftermarket sub and amp.
- 2is Daytime running lights not working
- Question about new ballast
- 06 is250 no start, good battery
- Navigation screen black after replacing
- Carbon build up
- Heated/cooled seats not working
- Electrics in roof not working! Help?
- 2009 IS 220D windscreen washer problems
- Check 4wd
- What happened to the battery compartment here?
- Rearview Mirror Removal
- noisy pulley??
- Front led turn signals how many resistors?
- Headlight ballast replacement the easy way! DIY
- After Market Solutions to Melting Dashboard and Door Panel Problem?
- circuit diagram 2008 IS250
- 2006 Lexus IS250 Coolant Temperature Sensor Location????
- Another Tesla Radio
- PS Light is on
- Navigation Update
- P0172, p0175,.p0101
- For sale items go only in the marketplace
- Where can I buy bolts for headlight mount for IS250/IS350?
- Door Belt/Moulding. Trying to Black Everything Out
- 140k Transmission Problems, What's the Truth!?!
- Rim Size, OEM Staggered?
- Is250 angel eyes
- Hit Pothole Very Hard--Damage?
- not level HID headlights - AFS related?
- Type of Coolant--no wait, I mean refrigerant!
- Steering wheel problem
- 2011 Lexus IS250 F Sport
- VSC Codes Chart
- Did Lexus fix the 2006 IS350 oil consumption problem?
- 2006 and up IS add bluetooth music streaming for $18.80!!
- Car won't start after replacing battery
- Codes p0172 p0175
- is250 Front Splitter
- Car won't start suddenly (VSC AND CHECK ENGINE LIGHT ON)
- 2012 IS350C Head Gasket
- 2006 is250 metal rattle sound
- roasted windshield trim
- 2009 is 350 center console not working at all
- Intake manifold bolt part #
- 2006 350 won't start no dash lights
- Need help with 2006 is350 not starting
- Central locking issue (Please help)
- Brake Master/Booster Going Bad??
- 2009 IS250 All warning lights lit up like a Christmas tree!
- Headlights
- 2006 IS350 AVG mpg doesn't work after battery disconnect.
- Firm steering wheel after changing alternator
- Radio Turns off on its own
- help with splash shield assembly
- Super sweet bumper conversion!
- Lexus 2005-2013: Why is My Tire Pressure Light On?
- Replaced the digitizer, what did I do wrong?
- Hood light
- How to clean intake valves while changing spark plugs?
- laguna seca blue wrap
- 2009 Passenger Seat Occupency Sensor
- Strange problem with car starting and resetting certain car settings
- carbon buildup problem ?
- IS250 New owner
- 2007 IS350 P0137 then P0430 then P0137 again
- IS300 (2nd Gen) Engine noise
- Look for GS350 F-Sport Front Bumper to the 2IS
- Intro and possible questions
- Newbie is250 Questions
- White residue near fuel pressure sensor
- Battery light still comes on after brand new battery was installed. Altenator rebuilt
- Strange electrical issue - Need some advice
- Which offset should i choose?
- Plastidip w different caliper colors
- 2010 IS250 Bumper?
- DIY: How to Connect Your Phone to Bluetooth
- Please assist with a DIY for how to remove the stop light control switch
- Which licence plate holder is best for the front of my 2010 IS350C?
- 2007 IS 250 Check System Tire pressure red warning light on
- '08 IS250 AWD CV Boots — $1600 vs. $150?
- IS250 ('08) won't start check VSC
- Lexus dealership lying?
- Best aftermarket shocks to pair with H&R Sport lowering springs
- Just bought a 2007 is250
- Lexus IS 350 Check VSC (C1380) troubles
- Valve Cover gasket replacement cost
- F sport wheels on awd is250
- Headlight issue
- Roof Spoiler Identification Help
- It's been almost 5 years.. (2008 IS250)
- P0420 VSC Light & Wheel Speed Sensors C0200, C0205 C0215
- Tunes and Times
- Brake Override System Update
- Any DIY on cooling flush?
- Got rear ended and didnt even get a reach around
- Need help!
- iPhone will not play through aux cord!
- driver door stays unlocked on dashboard computer.
- Headlights
- staggered wheels on a awd
- Fuse Question
- Cel vcs traction control cylynder miss fire codes
- Original Brakes Lifespan
- Engine Fan Fuses
- Is250 transfer case
- OEM Nav Disk won't eject.
- Lexus IS250 IS350: How to Install OEM Navigation System
- Bad TC? Transmission problem?
- forward facing carseat for 22lb 1 yr old that will go in the middle of a 2012 is250
- oil change
- Intermittent electrical fault
- Anyone diagnose exactly what component is causing this SPECIFIC sunroof rattle?
- Disable AUTO light on Rear view mirror?
- 2007 is250 fluctuating rpms
- Carbon Build up is 250
- P0420 Code - Replacing Catalyst Converter
- lexus is250 has a problem with reversing
- New Fuel Pump - Low RPM Misfire - Codes P1277 and P0302
- Audio problem
- Best hitch for 2008 IS250
- If replacing the control module, 89952-Ow061, does the module have to be programmed t
- Where to get panels painted Glacier Frost Mica
- Carbon Build Up - Lexus Response and the non-Lexus Fix
- IS 250, Changed spark plugs? VSC light on
- Lexus IS 250 (2006) Mods Help Needed
- Lexus Is350 Volume
- Front and Rear Differential Fluids (75W85 vs. 75W90)
- Headlight assembly
- What models are not affected by Carbon buildup
- TPMS sensors
- Side mirror replacement
- Help! Cant remove rear axle
- Code P0024 came up
- Wrapping scuff plates
- Trying to figure out wheel gap
- This is not the classifieds...
- Ignition off makes a squeak
- IS250 AWD Front Axles & CV Boot Issue
- Copy of key fob and key for pushbutton
- Help [staggered fitment on AWD]
- I drive a IS250 2006 RWD
- 18” or 19”
- P0113 - Starts but won’t Fire!
- Wheel suggestions for IS350C
- need help:Is250 GPS navigation screen is not responding
- Rear emblems on Lexus is250
