- Gfx kit
- Meet Hunki and His Lexus IS Drift Missile
- Replace Headlight or Fix Tabs
- Oil Leak (pics) Help!
- Will a 3IS (2014) alternator work in a 2IS (2007) in spite of different part numbers?
- Unplugged Battery now check VSC
- Used Navi Unit or Specialty Repair Shop?
- Wife drove over a small pothole and the damage was $10,153. Lexus IS 250 please look
- How long does fuel pressure sensor recall take?
- Random question
- 2007 is250 headlight wiring issue
- Tough sell
- 2008 is250 ac issue
- Disappointed
- Turn signal relay
- Hello-can someone post the schematics to the
- Front and rear lip kits and side skirts
- Are the two pulleys the same?
- Error codes P2238 & P2241
- Speedometer/RPM needles not working.
- How Much $$ for an F Sport steering wheel? Anyone know what a good price is for one?
- 2007 IS250 RWD - rear links for Stabilizer Bar
- Aimgain spoiler
- my nav screen wont turn on
- Recall: On fuel leak ?
- How to replace CV shaft on my 2006 IS250?
- Parts help
- IS 250 AWD Axle (CV Halfshafts) - rear
- Where to buy side skirts
- Video! New style led tail lights
- Who's is250/350 is this?
- IS350 P0031 Code Help
- Custom VIP Interiors?
- IS 250 Oil leak
- 2014 3IS F-Sport Bumper Conversion
- 2011 IS 250 - Can the seat belt chime be disabled?
- difference in 4GR-FSE - '05-'10 vs '11>
- anyone rubbing with linea corse lc818??
- changing interior colos
- DRL Slim Decoder 06 IS350
- Metal polisher help.
- AC light
- 2009 is250 startup rattle
- intermittent vibrations
- Oil change every 5K miles or every 10K?
- Question Lowering AWD IS250 = Any lights on the dash???
- IS250 | IS350 Spec SSR TF1 in Titan Silver *BEAUTIFUL!
- sc300 200k miles
- Rear bumper metal tab shaving
- Need help with low offset rims!!
- Steering wheel question HELP!
- Photoshop this rims.
- Is this HID kit plug and play?
- Can anyone identify this front oem arm
- New Member, New to Lexus!
- how do I remove exhaust o2 sensors
- Pcv valve glad I changed!
- interior front door handel light mod
- Finally liking my Lexus..
- Back up camera - 2010 is350
- Keyless entry remote draining battery
- My new to me 2011 IS250 RWD 6MT W/ISF 19"wheels
- Lexus IS models Washer Fluid Leakage
- vertex rear lip in canada
- Stereo help please?
- Major roblem with Kuni Lexus
- Help please... Urgent.
- accident yesterday.... is this totaled
- anyone have these install? jdm fog light with led?
- Starting again:)
- Removing plasti dip, is thinner safe for the rim?
- S2k AP2 exhaust tip
- smog check question on IS350
- Aftermarket or retrofit headlight?
- carrier bushing/bearing
- How much bigger is the 350 chassis as opposed to the 250?
- First post! Slammed 2is
- 2006 IS205 Auto error code confusion
- DIY: Figs Engineering Front Lower Arm Rear Mount #2
- Brake Light Issues
- Rear Sway Swap--- ISF to Awd IS250
- Seeking Rim Opinions for my 2008 IS250 AWD
- Covert from Factory HID to aftermarket??
- Wiper Arm Identification
- Anyone install figs front lower rear mount #2???
- Continuously warping rotors!?
- Caliper color for DSM
- From Factory HIDs to Aftermarket HIDs????
- Hitting Rev limiter in Auto mode.
- changing gear ratios
- HID or halogen Bulb
- My First Post - Is it Worth Waiting??
- Navigation unit color code
- The tire stretch comparison thread
- Driver Rearview Mirror
- does AWD aftermarket shocks come with front C clamps attached?
- Torn between the IS and GS.
- Which exhaust gasket is the toward the front of car, biginning of pipe?
- How Much Do You Pay for Oil Change?
- Dash lighting
- Any Lexus engineers here? (cutting & welding gear selector to shorten it)
- Video input non ML nav system
- 09 IS 250 only starts when it's sunny
- Kazz with black vinyl surround?
- Help me diagnose this annoying sound!!
- 2009-10 bumper on 2008
- LEXUS RC350 F wheels on my IS350??
- Interior Panel?
- Axle-back Exhaust Leak?
- Pet seat cover recomendations
- My opinion on the G37
- how many resonators does a is350 have?
- FS and WTB threads go in the classifieds
- Slight Vibrations at HWY speeds
- EBay 2012 Headlight Upgrade??
- 2011-2013 is350 pros and cons
- New car shopping, need advise
- In need of some fast help!!
- how many cats does a 2006 is350 have?
- Is350 in the making
- Saw RC350 on the Road for the First Time, Not Impressed
- Getting a Lexus IS350, first car (maybe second)
- Black chrome grille surround?
- Roof rack options
- Slight Vibration on Coasting
- Rear Tire Mud Flap/Plastic Piece
- Popping noise on bumps
- Buying a Lexus IS250 100k+ miles. Opinions?
- chirping coming from glove box
- is this a decent deal on a is350?
- Engine Mounts needed - advice welcomed
- Fsport replica grill installed
- How can people afford all their mods?
- 2007 IS350 SGM Engine Cleaning/Tune
- Need Help With GFX Side Skirts
- Rattling/Grinding noise when car is on
- LMS intake in CA/smog test
- Lexus or Toyota for Service?
- Headlight Issue Please Help!
- Corrosion question
- Seeking source for exhaust gaskets and related
- 2011 is350F Seat Height/Headroom - Lowering Brackets?
- Bought a Used 2008 IS 350
- Suspension issues updated pictures.
- 1g1 paint code members please help
- is this a decent deal on 07 is250?
- Navigation System stuck
- check engine problem
- DAI Autobahn Wheels Tight Fit
- Camber Tire Wear
- Root beer brown Aimgain IS!!!!
- HID/AFS Help...
- bad Experience with L tuned parts
- Appraisal value for 06 is350
- Weeird noise coming from engine after its off
- New to Lexus Maybe IS350 AWD
- Timing Cover Leak, Gurus and Techs Please Chime in
- oil?
- Suspension still Messed
- Rear GFX lip install
- Will these LEDs fit as a trunk light replacement?
- VaderIS250's Progress Thread
- Hid bulbs
- ANOTHER LED headlight replica....
- Frozen nylon license plate screws
- Opinions on Spyder foglights
- Anyone running 19" 30 series tires on their setups
- Defeated.. Can't change passenger DRL
- Headunit install?
- Need some opinions on this 2008 is250
- Wheel Fitment
- Just got my black top done!!!!
- key fob don't work after replacing valve cover gasket
- What's your worst MPG/city mileage
- Steering wheel problem
- where is the fuse for vsc / traction ?
- thread pitch on the 2008 is250 shift knob
- Trunk light assembly PN?
- Does anybody know if the Windshield wiper supposed to be like this? How to fix?
- new is250 owner.(pause in acceleration)
- usb plug in place of standard headphone aux plug
- Pulley or belt sound
- Another Check VSC warning light question
- will my 2is pass inspection/emission with invidia midpipe
- Tire help!
- FlyAudio (2nd Gen) with Vaistech iVIC-5DR?
- telescoping steering not working
- Decided to keep my IS350
- How to link note 3 with pandora to car bluetooth?
- Best vendor 4 brakes, filters, spark plus tune up etc
- Any thoughts or suggestions about NICHE VERONA Sport Series wheels!?
- How many manual transmission have been produced for the 2nd gen is250?
- 328 --> is350?
- ECU swap '06 is350
- Search Front Bumper ( Picture )
- Anyone lowered on 2009 OEM wheels ?
- Undercarriage Damage
- 2IS new edition aftermarket tail lights??
- Turn signal bulb replacement
- Is this is good deal?
- Lexus meet in Richmond, VA or NOVA
- 2009 is350 front LIP
- Recommended Lowering Springs
- Been gone from the forums awhile, wondering if we had some solutions for a few issues
- Tire Question
- Grille changes
- First Demon-Eyed IS250!
- Replacing Michelin Pilot Sport PS2 - Suggestions
- New 2010 IS 250 problems
- F sport exhaust and torque loss
- carbon build up recall
- is250 AWD 19X9.5 all 4 what size tire i need to use ?
- help me :( [VSC and traction control lights on after installing new steering wheel]
- help! grinding down wheel offsets!
- Actuator part number needed
- Engine wash a IS350
- invidiaa 60/70mm
- 235/35s and 275/30s
- New and looking for some help
- 20mm spacers on OEM front 18 rim?
- yellow(not oem) city lights
- Can i run these on my 08 is250 awd
- Recalls?
- HID headlights
- Jack points bent to hell. Jack points alternative?
- 07 IS350 Dirty Oil change w/ Full Synthetic
- Squirrelly handling and steering...
- Wheel bearing issue
- Question on headlights and parking lights/DRL
- Anyone going to Cars and Coffee in Cool Springs, TN this weekend?
- Cabin Fuses for Dash Cam Hard Wire
- Ideas about buying/building is250
- First post on CL
- IS350 headlight bulb issue high beam on low beam off
- Lexus Door Logo Projector Lights
- 06 Lexus is250 good deal?
- said 'goodbye' to 06 IS350 today..
- 2007 IS350 Question
- Fabulous front lip
- paint problems on the is?
- 2008 IS250 ECU - Used replacement
- Megan UCA or SPC ball joints??
- CEL on for Evap issue
- FS and WTB threads go in the classifieds please
- Prepainted rear lip
- Can You (IS) C How Customized This Lexus Is?
- Headlight Level Sensor... Has this ever happened to anyone?
- 2nd gen. IS vs 07+ gs350 headers
- Newcomer, need pointers and ideas!
- 18" Volk Rays Kuwagata F-zero's
