- Fitment ? calling IS350 fitment guys
- Dealer Thinks I Blew The Computer
- car won't unlock driver side door with kay fob
- IS350 Wheel Spacer Key
- Help.. need part number
- rim color advice
- Lumarai kya 19"
- Go take a look and chime in
- Megan sway bar??
- new owner
- 2006 IS350 craigslist pricing question
- HID fog lights
- Orange peel in paint or clear? (touch up paint)
- Difficulty installing rear lip spoiler
- my car dont start (( HELP
- IS350 atrocious in snow. PLEASE HELP
- need help deciding on a rear lip
- p0171 p0174 advice
- aftermarket sub / amp help...
- How can I install map updates for a 2013 IS?
- Stiff steering when really cold
- 19" LFA STYLE STAGGERED wheels
- 2007 IS 250 Front Bumper vs 2009
- Instrument cluster on needles flickering
- Will the F-Sport sway bar for a GS350 AWD fit an IS250 AWD?
- Belt Noise
- stock wheels 265\40\18 ?
- rear axle noise after rear axle replaced
- 2009 is250
- Bad dealership "Love Lexus" Huntington
- Please help: Choosing between two set of rims
- Train Horn Installed...
- TPMS not updating data from sensors....wonder if all sensors are bad?
- FS and wtb belong in classifieds only please
- bumper differences
- Rep isf grill paint colour
- Water pump going bad??
- IS350 or IS350 F Sport
- Xxr 550 help!!
- 2012 IS350 rear air vents - controls?
- ★★★★★ Official RSV Forged Owners Thread ★★★★★
- First Major Problem
- 2007 IS250 oil filter wrench
- Spark Plugs
- Installing drip molding Help
- How to fix stuck CD?
- does your dealer do favors to your car when warranty is about to expire?
- IS spark plug alternatives?
- Vertex front lip... authentic or rep? need some opinions
- Question about 2010 IS250 FRESH AIR/RECIRC SERVO part number???
- ebay F-Sport Front Spoiler
- IS security light issue
- NEW ECU Swap for old paddle shifters to work?
- Anyone know what rear lip this is?
- Misaligned Trunk Help
- Eagle eye tail lights
- Thank You Club Lexus -- P0430 Trouble Code
- Wheel fitment question
- Engine Cover Push Pins
- checkout this cool video.
- Someone please elaborate for me
- Trunk Button Replacement
- 255/40/18 vs. 255/35/18
- Cusco Strut Tower Bar
- Sewellparts.com closing (merged Sewell Parts alternatives threads)
- 100,000 mile servicing ?
- 2006 IS250 start button
- Recal ELF?
- isf rear spoiler question..
- Pricing Advice 250 IS
- 2010-12 IS Fsport front lip fit a 2006-2009 front bumper?
- Caliper Color Recommendation
- IS350 - Front Wheel Bearing Replacement
- Headlights won't dim
- What's A Good Tire For Stretching. Looking For True Tire Size
- Interior swap
- Installing iVIC-DR and now my car wont start
- 2011 AWD Navi, but no LED Head Lights
- 2011 headlight LED wiering connection
- Help in is350f 2014
- TPMS Light after Sub install
- Battery Warning Light - HELP!!!
- Detroit Metro area: Any recommended shops
- Fog lights help
- Thinner Steering Wheel
- So I added a volt gauge to my car
- Installed Ap2 tips and Is F tails this weekend
- New to my IS 250 any recommendations?
- is*50 eBay rep front lips
- RocketBunny Lexus IS250 (2nd Gen)
- random long cranking when starting car
- IS 250 Driver's Door Armrest Position
- wheel spec and offset, ive searched.
- Blown oem HID ballast
- 07' is350 need mod help : Headers or a shot of NOs?
- Nav DVD eject
- Found some damage on bumper, need some advice.
- I want hids
- Ipod / XM / Nav Question 2008 IS350
- the drop difference between awd & rwd
- ride quality is250
- harness bar
- Transmission?
- some of you run spacers to clear calipers?
- Opinions on Joe Cells and our IS's
- Low Oil Level warning light on IS350....trigger?
- Buying a 2006 Lexus IS250 with new transmission. Help
- New 250 owner with question
- 3IS front bumper conversion
- fs and wtb go in classified forums only please
- Changing the ground wire?
- Finally My 06' Runs Into A Major Problem... Navigation Unit!
- size of stuck lugz
- can you remove the underpanels of a car?
- Alternative f sport rear sway bar?
- sway bar end link question
- Enkei OEM isx50 wheels
- front diff oil change questions
- jdm window visors, nigel-jdm coupon code?
- Staggered fitment question
- Would you buy an 07 IS250 w/ 80k miles for 15k or an 08 250 with 60k miles for 17k?
- Tail light Help!!!
- Are you a butter face?
- 07 is350 sluggish
- Bluetooth audio troubles
- Starting issues with my IS250 after being rear ended
- Airbag light on and is at the dealer
- IS 250 2009 Dup Key
- Shark fin?? WHERE??
- Car hit by bus--- new rear bumper ideas? :)
- 08 IS250: Location of Engine Coolant Temperature Sensor?
- What kind of strut bar should I get for my 2006 Is350?
- Trans Question
- F sport lower box
- IS350 - CEL P0158 related Questions
- Factory HID wiring diagram
- Looking at a 250. Does this info from Lexus site mean the Carbon recall was done?
- Tire Balancing beads?
- Sewell Headlamps Kit
- what air freshener do you guys use??
- Oil residue near sensor/plug?
- Ticking noise after start up
- Train horns in an IS - where to run the air line?
- oil pan issue
- Shark fin antenna!
- 2010 IS350 Clunking Noise
- sound system
- Hey guys, New owner - IS250 F sport
- What's up guys? New member in denver
- VIN Decoder
- IS250 (2008 fully loaded) - How long can music play without killing battery?
- Thanks to all! New owner
- Seems my heater has a mind of its own.
- Dice Media Bridge Firmware request
- Stiff Brake Pedal
- is300 2007 gulf space 2jz vvti swap project
- Need help to diagnose car please!!!
- my WORK in progress
- Vouch anyone?
- Heater blowing cold air while stopped
- Any cool alternatives to black headlight bezels?
- RC 350 Fsport wheels
- Unknown Grease issue
- LED Foglights
- 10,000 mile oil changes. i found an indy
- Help finding Gorilla lug nuts key
- Do you think this is repairable?
- 07 IS 350 with 80k miles without Nav, or 08 IS 250 with 57k miles with Nav
- advice on replacing Transmission
- Lexus ISx50 Laser Lights?
- Possible to make the steering wheel come out even further?
- buying a 06 IS250 AWD 170k mile lexus tonight.
- ? About Stock 18" Wheels on AWD?
- From Halogen to Hid
- 2012 IS250 Headlight LED Strip Went Out
- Just happen last friday
- Got my sticky dash recall letter !!
- so i had to replace my battery, now only the
- Yes another oil Topic but with good questions. (penzoil 0w-40)
- splash guard help!
- Would I run into any problems running 245/40/18 on my 250AWD
- Can someone tell me what in the world happened!?
- Goodbye for now
- Looking at an IS 250, looks like the carbon recall was done, does this look good?
- Is 250 headers?
- Reliability of AWD IS 250 / 2006 model year
- Rims and tires to buy
- washer fluid warning light
- RS Fortin and Audiovox
- Fuel Pump Help Please
- Cree LED 5500k headlight kit-- DRL pics?
- Suspension Issues IS250
- Avoid seller sunnycity2008 on ebay!!!
- I know that tire wear is an issue with the 350, same problem with the 250?
- f-sport steering wheel
- Is250 Workshop Manual
- Car Making Weird Noise on Cold Start!
- Looking at an 09 IS250 that hasnt had the carbon recall done. Is it easy to do?
- driver side condensation =T
- [Need Expert Advice] Do these tires work on these wheels?
- windshield trim replacement?
- Stock Cat-back - 2 pieces?
- Please identify this front lip
- RPM Drops on IS250
- factory Ipod adapter question
- Opinion on IS F tail lights with stock inners
- IS350 revs high
- how many of you are waiting for the '16 IS200T?
- 07 IS350 being recalled by dealer over Potentially botched Valve Spring Job
- 2007 IS250 rear ended and idles rough now
- rattles, squeaks and chirping on '09 IS350
- Navigation problem
- 2006 IS250 strange jerk/judder
- cd player problem
- I want to know wiring circiut audio for lexus is250 2006
- Another LED puddle light review
- F-Sport Shift Knob Stuck
- New IS owner, Magical power steering.....
- iPod Integration - Bluetooh Adapter
- WTB: 2006 IS250 wheel
- Uh.. High Idle when turning on A/C with warm engine?
- After purchasing a certify pre-own lexus
- Headlight Mod
- Need help with wheels ASAP
- Shaved Fenders
- who has third brake light flasher, is it legal?
- Hear low pop sound
- Help - rear diffuser
- Timken or Sewell Lexus wheel bearing
- Does anyone run a catch can? - GDI Carbon Fix?
- Vin number info.
- Cloth Lexus Poster?
- Xenon bulbs
- Scratched my car, need help
- Anyone tried running 18" front and 19" in the rear???
- How do you replace the roof molding?
- rear camber install??DIY??need help.
- Slow pulsating humming sound with slight vibration
- do i have to roll fenders ???
- How to Program Radio Stations!?
- Lowering 2010 IS250 AWD
- Considering a trade: 2011 IS250 F Sport for a 2015 NX 200t F Sport AWD
- Bolt-In Style roll cage?
- If you squeeze the TPMS it registers pressure pretty easily. Anyone use this method?
- Question about 2008 IS 350 w/Sport Package
- Refreshing my 2007 IS250
- LEDs inside flicker when dimming on and off?
- Side mirrors/basic warranty questions
- In need of wiring color diagram for drivers mirror.
- Temp gauge drops!
