View Full Version : Maintenance
- Map update.
- 2002 RX300-Storage for 3 years-Maintenance Question
- 50k Service
- ES300 key replacement
- Lexus LS 430 mirror question
- Speedometer after tranny swap
- 1998 Lexus GS400 P0172, P0130, P0133, P0150, P0153
- lexus es250 troubleshooting trouble
- this is very interesting
- SR20 swap write up
- 1990 ls400 hardtime starting. wont start sometimes
- Cam to Cam Gears
- Smell of gas when changing oil
- RX450h suspension noises...that disappear after a carwash?
- IS300 buzzing noise when started
- 94 lexus es300 big problem
- Engine bay without engine cleaning suggestions
- Do it myself service?
- Broken bumper please help
- Extended warranty pricing?
- Rear camera glitches on my 2007 IS350! Any idea what this might be?
- 1994 SC400: Slow starter and "jumpy" between 40-50 mph
- lights on, on dash
- Replacing water pump for my GS 300
- Pls help P0756 06 gs430
- 1997 ES 300 Codes P0420 and P0410
- What's a Fair Price for OEM Quality Pads & Rotors Installed?
- Scrapping/rubbing sound in 4th gear mostly...carrier or dust shield?
- Selecting the correct car in Techstream.
- 97 LS400 ac blower problem
- 2002 RX300 Increased RPM, No Codes
- Any Techs here familiar with this forum?
- Help with my 2011 lexus ES nav unit
- 500 miles out of CPO warranty engine needs replacing... advice?
- Side Mirror Lowering in Reverse
- Running Out of Gas with 5 Gallons in the Tank
- PCode help...please... :(
- 2004 RX330 clunk when downshifting
- Otherwise enjoy dealing with this dealership, but this one thing makes me angry!
- engine oil in 2010 lexus ES 350
- Brake Bleeding - clear line size
- Having issue with the rear windows ..
- Service for Lexus in Racine?
- weird but curious. Differential or ?
- A/t temperature
- broken plastic tab on sensor plug
- Looking for 1998 Lexus LS400 gearbox
- EFI Fuse
- Rotora Replacement Rotors
- Lexus TPMS Tire Pressure Sensors light on
- check engine on and off
- Pre Purchase Inspection in Los Angeles
- Valve Intake Cleaner
- is250 help
- Door gap
- Power steering return line ( Low Pressure)
- Brake Pad Install Question
- ES330 2006 32,000 miles- timing belt replacement based on age?
- 2004 RX Check Engine, VSC, Trac Off lights
- Luxcare / 3 For 1 / Maintenance Plan, Worth It?
- GS 300 OCV valve
- 2000 Gs 300 Serpentine Belt help
- 2002 IS300 hesitation / shutter issue
- 93 gs300
- 1998 Lexus GS400 - P0172 - Runs Rich
- is300 Throttle Body Replacement
- 4pot rotora bbk rotor discounted???
- looking at an OLD RX.....
- 2010 RX350 Rear Wiper Change
- 1998 GS400 Crank/No Start
- Where to go for service in DMV?
- Needle-type & click-type torque wrench accuracy
- 1UZFE VVTi gear oring writeup
- Clutch Synchronizer?
- Need to replace starter
- 2006 GS300 purring sound when accelerating
- Is250 HELP!!
- 1994 GS300 Transmission Not Shifting and Codes 21, 25
- Best way to get rid of current rust under the car.
- CHECK ENGINE LIGHT..now you see now you don't.
- LS430 sometimes doesn't start
- Window Issue
- 01 gs300 knock sensor location ????
- Tire place rip off
- 01 gs300 backfire ?
- Warranty vs PPI question
- Burning Oil - Piston Issue
- Door Actuator
- Timing chain Oil leak
- Oil Change
- What is this diff off??
- Where do I find parts diagrams?
- 2001 Lexus es300 making whining noise from transmission
- IS300 valve cover gasket change
- Weird battery(?) Problem
- Please help. Control arm issues.
- Backup Camera not working
- Where do you guys get your cars serviced?
- Car making clicking noises when accelerating (during gear changes???)
- Help my car is stuck in drive way and won't start
- IS250 oil change
- Battery Load Tester Recommendation Wanted
- BG MOA on my 2013 GS 350?
- Oil filter housing stuck!
- Help with surging problem please
- No codes are coming up??? But something is def wrong!
- 2,000 miles overdue for oil change, should i be concerned?
- popping noise
- Help!!!
- Oil Consumption
- Full Synthetic or Synthetic Blend ?
- Lexus 27 point inspection checklist?
- Engine code
- Wiper Repair
- father/son build - help would be appreciated.
- problems with abs lights
- RX 300 would not start after parked 24 hours
- 2000 RX300 Start problems after long-term storage
- Charcoal Canister help
- wont rev over 4rpm????
- Access to 02 and 05 Sequoia wiring schematics?
- who
- Fitting Ford Taurus seat in Lexus sc400
- How often to go for service, when car is not driven much?
- 98 GS400 transmission
- 2005 RX330 maintenance questions
- Cold air
- Best Timing Components/Water Pump Aside From Dealer
- Creaking brakes doing my nut!
- SC400 code 21
- Lexus RX350
- loss of throttle power
- LX470 Vibration Trouble...Help!
- Help, 01 is300 doesn't start, touched +/- wires together while changing side marker
- 98 GS400 turns over but wont start!! Help
- LS400 rear carrier bushing help please
- Bad Water Pump?
- Timing belt kit from local auto parts
- Squirting water
- Transmission
- IS250 wheel bearings possible need replacement, cost?
- IS Rear Brakes
- service reporting for carfax public records
- LS430 and RX330 oil capacity
- 92 LS400 Accelerator cable
- The Scent of Transmission fluid
- Service in Las Vegas
- About to Hang Myself
- starting problems
- 90k service
- Replace brake pads???
- great...I stripped my rear caliper's hole. what's my option to fix it...
- Code P0606?
- Most likely cause of this squeak (brakes on LS460)
- help / replacement spark plug & wire on 1jz
- GS430 Hands Free Steering Wheel Control
- Car Will Not Idle. Need HELP!!
- Turquoise transmission: is it rebuilt?
- 2002 es300 (trouble code problem)p1436
- Used from a 3rd party - will Lexus still honor warranty?
- First Oil Change
- No Fire To Cylinders After Changing Starter
- What is this stuff -Headgaskets, Cylinder heads...
- Coil Ohms
- GMB waterpump?
- Fuel pump problem SC 400 codes 13, 21, 78
- SC 430 Code P0440 and P0446
- JiffyLube knuckleheads
- New Pistons
- Any promotions on Lexus oil & filter service?
- Wix 51515 on 1UZ-FE?
- PO330 Knock sensor 2 circuit malfunctions rx 300 2000
- DIY Engine Light Codes?
- WS Fluid Change & Color at 102400 miles
- IS300 security light
- need detailed parts diagram - GS400
- GS400 master window switch - electronic board
- Maybe dumb question on service advisors
- ATF Castrol Transmax ATF substitution for Toyota T-IV
- GS300 Power Steering Squeal
- help with dealership
- Help!
- fuel guage does not work 1992 sc400
- Thread size ?
- Car won't start
- best oil for high mileage ls400??
- CHECK PULLEY & RPLC PULLEY - what does it mean?
- Got Error Code P0430, What To Do?
- Parts cross-reference ???
- 1997 es300 sensor inquiry
- Lexus sc300 running rich
- P2238 and P2241 codes, '02 ES300
- Austin, TX (Bluebonnet Lexus Specialist)
- G-oil
- Mobil 1 or Toyota 0W-20 Oil
- Bad voltage problem
- Need help - engine won't start with AC on
- Shock replacement?
- PPI mechanic near Lexus of Route 10 Whippany, NJ?
- Starter/Battery Connection Problem
- Oil filter part - quick question
- synthetic oil question
- Would I be able to paint leather steering Wheel?
- Where does everyone get their maintenance done?
- is Eneos oil good?
- Any good Service Shop/ Mechanic in Central NJ
- Big problem when Idling
- Oil Control Screen
- 2000 Lexus GS400 Ignition Problem
- 1JZGTE issues
- Clunking
- why different mpgs...
- DIY 2jz-ge channel
- SC300 OBD1 Check Engine Issues
- Clamp request
- duplicating remote key
- 2nd gen Gs300 clicking sound
- suspension helps
- 1st Gen GS, Steering wheel shakes when braking.
- stupid 90s tilt steering wheel!!!!!
- Refrigerant charge in 1999 gs400
- How often to change oil in 2011 IS F??
- Maintenance Description Deciphering
- A/C smells funky on my 30k mile IS350
- Loyalty Discount on Service
- Driver brake pads wearing faster than my passenger
- Brakes
- need help with 2000 lexus gs400
- 2002 LS430 noise is driving me nuts
- Auto Mechanic learning material
- bought a CPO IS350 have question about fuel injection service
- K&N Cartridge Filter - RX350 application could it
- danger: something is wrong here... please share info
- Thoughts on this.
- 1999 gs300 radiator leak and overheating
- SC300 fan clutch
- Please Help with spark plugs
- Question about how adding A/C refrigerant!
- PLease Help with Timing Belt & Water Pump
- new with IS300
- Injector or oil tick?
- Turn Signals on GX 460
- Cross post on broken glass
- Tips for dealing with Lexus service and warranty claims
- Help with an overheating LX470
- OEM Parts
- 65k service but im at 70k.
- Throttle Body Problem
- rattling / ticking noise ..here is a video of it..
- Messed up exhaust stud removal?
