Oil Consumption
Old Feb 9, 2013 | 05:46 AM
ThumperPup's Avatar
ThumperPup
Default Oil Consumption
Just wondering in the 2007 Lexus ES350
what would be a normal oil consumption i read somewhere 800 miles but that can't be right its not like we are talking about some big V8 like the northsar i used to have in my old cadillac that got 800 miles to a Qt
should i be able to get 5000 mile oil changes and never have to add a qt of oil and be safe ?
or should i get 2000 miles between qts ?
thank you
Old Feb 9, 2013 | 10:09 AM
slideland's Avatar
slideland
thank you
depending on your mileage of your es its suppose to be around 1 quart every 2k AT WORST CONDITION. if you have a low mileage car there might be an issue else where.
Old Feb 9, 2013 | 01:00 PM
ThumperPup's Avatar
ThumperPup
Ok cool thanks yeah no issues noticed so far only Ave 500 miles on here since I purchased she has 45k on her I was just curiouse thank you
Old Feb 9, 2013 | 04:55 PM
LexBob2's Avatar
LexBob2
thank you
I had two ES350's. A 2007 and a 2010 and never added any oil between service intervals.
Old Feb 9, 2013 | 05:38 PM
SChema's Avatar
SChema
Engine oil is vital, it something that should be checked at least every other week. Oil consumption can come in the form of internal leaks that will burn and exit the exhaust or external leaks you will see in your driveway or parking spot. In other words, consumption is not identical from car to car.
Old Feb 9, 2013 | 06:23 PM
ThumperPup's Avatar
ThumperPup
I do check all the time for leaks when moving just call me a but peranoid at times
But I also check oil level every otyer tanks of fuel l I'm always ontop if makeing sure oil is and other fluids are at good levels
I just wanted to know if there are no visable leaks
And it seems oil is being consumed or lost more wanted to know what would be ok
ajay60610
Jun 5, 2022 02:08 PM
atullathia
Jun 5, 2017 04:23 AM
chrisexv6
12
Oct 1, 2015 03:48 PM
Technique
May 6, 2010 05:37 PM
818sc400
May 21, 2008 07:51 PM
