LS430 sometimes doesn't start
Old May 8, 2013 | 09:11 AM
hulla's Avatar
hulla
Default LS430 sometimes doesn't start
My 04 LS430 sometimes doesn't start. Same problem for the past few years. Happens once every few months. What happens...
Turn to ignition and everything seems fine. Normal lights, etc.
Turn to start, but nothing happens. Engine does not turn over. I don't hear a clicking sound from the starter either.
Usually if I try it a few more times, it will start. Sometimes, after trying for 10-20 times I have to come back later and try it again and it will start fine.
Any ideas?
Old May 8, 2013 | 12:17 PM
Blanco's Avatar
Blanco
Sounds like bad starter.
Had the same problem on my GS years back. Replacing starter motor fixed it.
Old May 8, 2013 | 11:52 PM
hulla's Avatar
hulla
Thanks for the reply. Car is in the shop now. Waiting to hear back.
Old May 9, 2013 | 06:49 AM
mitsuguy's Avatar
mitsuguy
Maintenance Moderator
Definitely sucks... what really sucks is that if the shop can't reproduce the issue, all you may get will be a "best guess" diagnosis...
If it was mine, I'd probably carry my voltmeter with me so I could see if the starter is being told to start or not... the thing that makes me doubt starter (but still know its a possibility) is that it works normally all the time, except when it doesn't and then it doesn't make any noise at all - usually dying starters at least click...
the problem could also be in the ignition switch, a relay, etc, so many possibilities... It's times like this, you'd be better off if the starter just failed completely...
Old Dec 14, 2013 | 08:31 PM
quirusm's Avatar
quirusm
Did you ever find a solution?
shangsterh
Dec 21, 2013 08:42 AM
dc893
Sep 2, 2012 02:24 PM
Dr. Jekyll
Feb 16, 2010 03:48 PM
KILLERGS4
Oct 14, 2009 07:35 AM
Taka
Oct 10, 2002 02:34 PM
