danger: something is wrong here... please share info
Old Apr 22, 2012 | 11:24 PM
kevink121's Avatar
kevink121
Default danger: something is wrong here... please share info
We were doing the coil packs in the gfs carit had been shaking and won't accelerate past 35 without a whole lot of effort. Coil packs were the direction the autozone cel sensor pointed us in. I'll have to get another reading. Also the spark plug in cylinder1 I think was caked with burnt oil. I looked briefly at the grommet and it looks just as functional as the other two on the front side. So I dunno, I'm hoping this is something that has happened before around here or someone can say oh yeah, its that.... At any rate thnx in advance for any info shared.
Lexus es300, yr 2000
Old Apr 23, 2012 | 12:53 AM
RTIS250's Avatar
RTIS250
Yes. I drove the LFA.
CL Folding 500,000
Need more information... what were the exact codes stored in the system? Im assuming you replaced all the spark plugs as well? There are a number of things that can cause the symptoms the car is exhibiting... but we need more info.
Old Apr 23, 2012 | 01:49 AM
mitsuguy's Avatar
mitsuguy
Maintenance Moderator
I'm with jim, we need a lot more info. Exact codes, all of them, how long this has been happening, what the general course of problems led up to it, etc. The more info the better... being as you replaced coilpacks, going to assume misfire codes, which could mean a whole lot of issues... just gotta get us more data...
Old Apr 23, 2012 | 01:51 PM
kevink121's Avatar
kevink121
P0301
P0302
P0303
P0306
There's the codes. On top of the misfires I'm just looking at possible solutions.
Old Apr 23, 2012 | 01:53 PM
kevink121's Avatar
kevink121
P0301
P0302
P0303
P0306
There's the codes. On top of the misfires I'm looking for the reason and possible solution.
Old Apr 23, 2012 | 04:39 PM
VVT-i's Avatar
VVT-i
I agree with both RTIS250 and mitsuguy. They need more info like how many miles on your car and maintenance history. It's strange that you have 4 misfire code at the same times.Autozone code reader may not give you which cylinder actually stored the code and which one is "pending".
Did you replace the correct coil packs ? Do you know that bank 2(2,4&6) is the easiest bank to replace spark plugs or coil packs? You will see bank 2 as soon as you open the hood...lol.
Old Apr 23, 2012 | 07:10 PM
kevink121's Avatar
kevink121
Around 100k replaced all coil packs...
Old Apr 23, 2012 | 11:17 PM
GS4_Fiend's Avatar
GS4_Fiend
Oil in spark plug? That could be one of the reason. Are you sure you snap in ignition coil connector tightly?
Old Apr 24, 2012 | 07:12 PM
mitsuguy's Avatar
mitsuguy
multiple cylinder misfires, we need to find out what is common amongst those cylinders... would be handy if we could see live data and see how often each of those cylinders are misfiring... couple cheap tests include switching coil packs from one cylinder to another and seeing if the misfires follow the coil... running excessively lean or rich can cause misfires as well... could also be timing related...
lots of potential issues here, gotta start narrowing them down... not that it cant be done without a scanner, it may prove difficult...
CrystalC
Apr 4, 2018 02:36 AM
imAC
Dec 3, 2013 09:51 PM
cyberhiker
RX - 1st Gen (1999-2003)
Jan 21, 2012 12:30 PM
miickeyxd
GS - 1st Gen (1993-1997)
Dec 15, 2008 10:05 AM
Vortes
Jul 21, 2008 07:43 PM
