Maintenance Description Deciphering
Luckily the previous owner seems to have done most of the maintenance at a Lexus dealership, so it's pretty well-logged on MyLexus login. I was searching through the service history to see if the front rotors/pads had been replaced. The only thing that seems mildly promising is a repair with a description of "F.DSC 1-SD INCL;R&R DSC PAD". Does anyone know what this means? I've been searching both on CL and on google for any sort of deciphering/clue, but I seem to have had no luck.
Any assistance would be greatly appreciated (as well as recommends for rotors/pads. I've seen centric blanks and OEM pads seem to be a popular pairing!)
:-Front Disc- 1 side-driver, included: Remove and Reinstall Disc and Pad.
Looks like for whatever reason, they removed the front brake on the drivers side, replaced the rotor and reinstalled the pads.
Could have been a warped rotor that they turned (milled out till it was smooth again) as well.
There are MANY great brake manufacturers, but if you are looking for OEM quality without OEM price, believe it or not, Duralast is a good place to start. Autozone's Duralast brand comes with a lifetime warranty. If they ever warp again, your replacements are free.
Also check on Brembo, they sell OEM replacements. EBC is also another excellent brand.
Thanks for the advice! So I started looking at Autozone's brakes and I found the Duralast rotors. Does it matter that my car is AWD and it indicated "with 2 wheel drive" on the listing? Also what about their brake pads? Recommended?
For your pads, in this particular application, I reccomend Duralast C-Max Ceramics to minimize brake dust and perform better.
Don't let anyone tell you that AZ produces inferior parts, because as long as I have been a Mechanic, I have been reccomending them and using them myself. I steer clear of some of the brands they carry, like valu-craft or other sup-par brands, but their Duralast products have proven themselves to me time and time again, and I would not hesitate to recommend them when it comes to things like brakes. I put Duralast rotors on my truck, all the way around after the factory ones warped towing my boat on a 500 mile trip. That was march of last year. They are still going strong and havent shown ANY signs of brake fade or warping, even with 7,000lbs of boat behind my 5,500lb truck.
