is250 help
Old Jul 17, 2013 | 12:06 PM
bigolilmar's Avatar
bigolilmar
Default is250 help
Okay I took out a subwoofer two days ago and now my car is showing a check engine light and a vsc light. Im guessing that the vsc is from the check engine light being on. But while i drive it im getting other light to come on light passenger seat belt light ac going out and power steering. Come to find out that the alternator was not charging the battery and the battery keeps dying. Couple things, I have checked all the small fuses in the car none are blown to what I can see, and when We were changing out the power cored of the speaker we lost the nut that holds down the alternator cable to the the hot side of the battery so we changed out the bolt and nut. My question is can that bolt be playing a part or how what should i check. I need some direction because i suck at electrical stuff and I dont want to have to replace the alternator if it is something else.
Old Jul 19, 2013 | 12:05 AM
mitsuguy's Avatar
mitsuguy
Maintenance Moderator
simple as this, have the system checked - many places will do it for free...
the bolt / nut will not cause any issues so long as it is all metal touching metal, is a good clean connection and is tight
Old Jul 20, 2013 | 02:48 AM
kauaian's Avatar
kauaian
If your getting a CEL pull the codes. The CEL will not come on for a failing alternator. If you don't have a OBDII reader go to autozone or any other auto parts store and they will read the codes for you for free. This is where you start with the trouble shoot. Good luck
54321IS250
Jan 8, 2022 06:29 PM
heyseeoh
Dec 30, 2016 11:13 AM
stvnmj
Jan 30, 2012 07:32 PM
taliz29
GS - 1st Gen (1993-1997)
Jul 26, 2007 04:59 PM
MeehSoFly
Dec 2, 2006 07:44 AM
