- My RPM's are stuttering
- clicking noise from serpentine belt
- air assist rear shocks and how to install
- Quick answer: Brake pads sold in pairs on lexuspartsonline.com?
- 1LS with red clears only using for the outers...
- bad ecu?
- 94 Ls400 Motor/transmission Mounts ??
- 94 LS 400 Wheel Bearing Repair ???
- Toyota Celsior parts...
- Fender mods vs. rim size/width/offset
- LS400 - painting the door handle...
- Does anyone know the STEERING WHEEL dimensions???
- What type of headunit are you running??
- Driver side wiperblade.
- i got a question please helpp somone
- Sorry guys, another gas question?
- LPG retrofit - Liquid Petroleum Gas
- 94 LS 400 Starting Problem?
- Door locks- Help Diagnose
- Gas Tank Pressure
- The Next Lexus??
- What the... what is up with my tach needle?
- Thinking about selling my 00 LS400
- UCF20, 170k with no service records - what to look for?
- My 96 Lexus LS400 for those who havent seen
- 94 lexus ls400 amp location (nakamichi)?
- does everyone here lower and put bling on their LS?
- Brake Asssit.
- i just got a 2000 ls 400 ? dvd system and rims
- Dome light issue
- car struggles to start after running...
- Got my 94 cluster repaired
- Mystery oil leak...from where?
- Just wanna make sure on a strut bar
- Advice needed regarding service (Lexus dealer quote)
- has anyone taken there LS to a drag strip?
- aftermarket RR sway bar links for LS400?
- do they make carbon fiber hood for LS400?
- 96 lexus Billet Grill
- Updated pics of my 96' LS400
- Pioneer CD Changer
- 89 octane okay?
- Will 22 in Tyfuns RIMS fit on my 1992 lexus ls400
- Vibration Problem Solved!!
- Can you recommend a muffler?
- Gas guage broken
- Back passenger door lock
- Passenger seat belt- help
- Amp Wiring Question - Blue Power wire - '99 LS
- Newbie, looking to buy 99' LS
- Please HELP Difference in air struts UCF21
- Need a part name/number..Please!
- just flushed my coolent but light is on
- How can you tell ?(AC Question)
- differences between first and second gen mirrors?
- Stock fog light question.
- Seat height - 98LS
- Front jacking point on a 95-00 LS400?
- 1995 on a 1991 front end conversion - possible?
- 93' ls400 firing order
- watch my 1996 LS400 EXPLODE! W/VIDEO and PICS
- What is this piece UNDER my car leaking?
- Help! Does anyone know if there are adjustable camber plates for a 99 LS400
- It finally happened.. LS left me stranded, in a bad way.
- Will the electrochromatic mirrors still work if I get the windows tinted?
- got a dilemma!
- Need Adviced on wheel
- Looking for a 98 ls 400, front passenger side blinker.
- exhaust mod
- Steering Issues
- Looking for a regulated 12v
- GS430 wheels on my LS400 - check it out
- LS400 Print Brochure Archive
- Need advice on my bushings/other suspension on 92 LS400
- can anyone... headunit '96
- Anyone know...
- Rear Diff
- suspension question 90 LS
- Headers
- Considering '97 LS400 purchase
- Where to find carpet replacement '90-94
- ABS Speed Sensor Question
- Spring Cleaning ('95 LS400)
- 1st Gen. 10PA20C Compressor Oil capacity??
- 1UZFE Spark Plugs
- Failed smog.... '93
- 1997 LS400 headlight
- Engine and Trans Drain Plug Gaskets
- Ignition Switch Light and Door Key hole light
- green fluid
- cleanest LS ive ever seen?
- Bad Ignition Coil, clogged catalytic converter, bad cap/rotors? A DIY story..
- door "hinge" broke on driver side door 1991 LS400....
- Brake light on Dashboard, master cylinder replaced, light still on
- Who here has re-dyed their leather?
- 99 with 76k, when to change timing belt?
- Ls 400 1997 - Gold Exhaust Tips?
- Exhaust Pics! Finally! Yesss!!! :)
- 1996 Ls400 O2 sensor wiring
- Check engine light and Trac off light
- Nice size rims for my LS
- My LS...Help?
- PLS help, questions re: cluster/fuel consumption
- My UCF10 on UAS Bags
- Getting OEM struts installed on '91 LS400 - What else?
- 98 Newb question about corner lights. :)
- Rear shock replacement - my observations.
- Front suspension again
- 95 LS400 with suspension mystery
- Gas Tank Questions
- LS 400 1993 audio system (Pioneer)
- 1995 LS400 Upper Control Arms
- 1990 lexus ls400 tach and speedo problem
- no power steering
- 90 LS rear suspension issue
- back seats??
- Carbon fiber insert for Lexus L logo.
- Is my alternator going bad again?
- '93 Lexus wont start. Shifter problem??
- 91 Ls400 What Brand Coilovers Should I Get????
- 1998 LS400 spark plug: IFR6T11 or IFR6A11 ??
- Won't start: clicking noises, erratic gauges
- low windshield washer fluid light...
- LS400 Exhaust video clip
- 91 ls400 suspension help
- just some pics
- installing mast ?
- I need upper intake piping- have one or part#?
- LS400 in its new home
- Cost of gas beginning to hurt! At wat point would you give her up?
- Kool Blue air filter.
- Where is the member who had their subframe bolts tightened?
- What is the growling/moaning noise when I'm braking?
- Battery light on when engine is running '95
- Engine System Warning Light is on and the car drives fine
- How to replace low beam headlight bulb?
- HELP my 96 LS400 rear shocks are dead!
- New owner reporting in...'92 LS400 in CA
- What is the limiting factor that defines our engine's rpm redline?
- antilock trac off lights are on !
- Was in Accident LS is out of Commission. Got an Accord
- Exhaust tips
- How do you replace the Windshield washer Hose on a 98 LS400?
- LS400 Projectors
- LS400 updates...
- 95 LS400 Front and Rear brakes locking up
- What is this?
- Anybody take the back two mufflers off?
- Muffler Tip and Grille suggestions please!!!
- w000000tt!!!111 (Update pics inside)
- Car is running really BAD...need help (first gen)
- locked out
- Just Another 1st Gen....Pics!
- radiator replacement
- part number confirmation for 98 LS400
- Pneumatic Cylinder control location???
- Question About Changing Camshaft Seals During 90,000 Mile Service
- 96 Parking Brake Adjustment
- Cant find owners manual, what are the radio unlock steps?
- moonroof problems..
- Thanks : reference for a good honest independent Lexus Mechanics in Honolulu, Hawaii
- Have anyone upgraded their leather seat interiors?
- body kits
- Weird brake noise! Any help?!
- Avoid Costco for Tires-Headaches 1995 ls400
- Timing Belt Replacement
- Drivers' side seat. Guess whats in the front of it?
- Service in Orlando?
- Back from the Body Shop & in the dway with 200K
- Octane booster: when to add
- had to trade in the LS
- What brand O2 sensors?
- Car rolling slightly in park?
- Tracking maintenance through the VIN#
- My car sounds old. Is it worth keeping?
- Remove/Install P/S pump
- Junction Produce UCF10 Celsior // 56k Beware
- Brake fluid brand?
- Thinkin of getting a second gen this Weekend!!
- Was in a Wreck... Have a Few Questions
- LS400 Rotors
- Things I have to do when driving my LS400 at night.
- Wierd suspension creek
- Engine bay flasher fuse?
- Weird grinding/moaning but only on freeway?
- Test fit: 19x10 -7 AME Shallen LX
- Test fit: 19x8.5 19x9.5 Zauber Gettins *56k* beware
- I Screwed Myself
- OMG Fing top L & R turn signal lights
- Ls400 moon roof
- Is a back plate really necessary? 95 ls400
- UCF10/11 Anybody seen this? Factory in dash TV?
- Rear Sunshade Question
- new steering wheel (SC430) mounted
- ordering parts from Carson
- LS compared to newer Toyota Camry.
- How much do you owe for the LS?
- New Member, Just Bought a LS400
- 1994 LS400.....bad ECU????
- Still drive with spare tire?
- noob lexus owner saying hi, but only lasted 2 months.
- 2nd battery install......help
- Motor mounts changed
- Brake Calipers
- Some of you may have noticed my absence... (pics inside)
- 1LS brake pad compatability
- what to do first...
- diy eyelids?
- Immobilizer
- Since youve owned your LS...
- Wheel bearing issue (I think)......
- Ls 400 1997 Pre Owned, Those Interior Colors?
- Intermitten Horn
- Suspension issues?
- What to Look For
- Just purchased a 1990 Lexus LS 400 and have many Questions!
- ls 400 or RSX
- Cracked lens! 99 LS400 clear bumper light?
- Wheels and tires
- Hello everyone....
- CSV & check engine light
- Question on exhaust hardware
- Thinking about selling my LS :(
- i cant get it off!!!
- Anyone running 0W-40 oil?
- Strange 99 LS chirping noise when the AC is on
- Got bored so i took pics of the LS with a few homies
- Divine Intervention In My Ls400?
- Clicking noise under gear selector console
- Finally got it moving - Thanks guys
- Some wheel help for a new owner?
- 93-94 center caps interchangeable with 95-97?
- how many o2 sensors are on 1990 ls 400
- po135 engine check code
- Headgasket + Bars
- Question about my 93 Ls400... wierd
- Weekend Drive! 500miles. Few pics
- 93 wierd idle and studdering
- I dont want to get booted off but can we list a car here for sale?
- I have two LS400's both are 1 owner cars, need help with one
- Retrofitting onto UCF10
- Radio swap
- car shutdown on motorway
- 93 ls sunroof help!!!
- Injen Intake
- ID this part i broke.
- Throttle cut off issue...please help!
- What Goes LOW!!?? ('97 spring question)
- lightning storm under the hood
