View Full Version : RX - First Generation
- installing a cargo net???
- Battery
- Exhaust question
- Anyone with a car starter?
- no dome light and no headlight reminder chime???
- is buying a used exhaust system a bad idea??
- Heated Seat Thermostat
- Detailed information Links regarding Transmission
- rear tire noise please help me
- tranny drain and fill issue
- 1999 RX300 Code P0171
- Smoother idle and 2 mpg loss after cleaning IACV
- Right Passenger Door Won't Open From Inside
- To keep or not to keep
- Found sludge in airboot
- Another seat problem!
- Rear collar & bearing
- Need small interior trim piece.
- RX 300 Lock Actuator and headlight issue
- Suggestions on adding USB to my '01?
- Recommendations for spring compressor tool??
- Transmission changes- 2001+
- What are the 2000 and 2001 RX300 Top Maintenance Issues
- Parasitic draw
- 2000 to 2001 tail light upgrade question
- GROM TOYA3 Issues
- how to replace engine air filter
- 99 rx300 front license plate holder issues
- Happy Holidays
- dead 99 RX300 - transmission??
- Torque Android App + ELM 327
- Transmission Problem! Will a flush fix it?
- Changing Coil Packs
- Stop working on your RX and
- Towing and the RX
- What are your tire's inflated to?
- Overfilled Tranny Fluid...Problem???
- 99 RX300 2WD "Knocking"
- Light vibration/rumble at idle
- new exhaust suggestions anybody
- ikeyless.com for replacement transponder
- Heated driver seat issue, rear tire noise
- Part number of Toyota OEM Serpentine Belt?
- HID to Halogen conversion?
- 2001 RX300 -CEL's: C1201, P1130, B2796 & Trac Control
- 99 RX running bad P0302
- 2000 rx gps navigation upgrade project
- AWD oils
- License plate screws rusted
- When Do You Turn On The Heater?
- Stuck ignition
- Mechanic in S Puget Sound (WA State)
- ongoing p0305 problems?
- Timing belt tensioner
- PCV Valve R&R whoops...
- Blacked out wheels
- Steering wheel Vibration/Wobble during braking
- Help with wiring!
- Power Steering Pump??
- Steering wheel vibration when exceed 70mph
- Need to Reset The CE Light. Which Fuse Do I Pull?
- 02 navigation in 99 model?
- Anyone with upcoming repairs they are planning to do
- Help with transmission/shifting issues
- On the fence RX300
- Will changing PCV valve help with oil consumption?
- Front Hub Assemblies
- Need advice - front/rear window washer motors
- Post pictures of your RX300 on here!
- Starting problems
- DEI Cell Saver Battery Insulation Kit
- New magnetic drain plugs for transmission + transfer case + front differential
- Can somebody please answer my question???
- RX300 - clicking noise when releasing gas pedal
- car stopped responding to keyless fob, where is the "receiver" located?
- No way to drive In 2WD
- Rear Strut Replacement
- Aftermarket ABS Speed Sensors
- Rear seat belt replacement (child got stuck / twisted it so had to cut it)
- Discount price ($74.99) on DENSO AIR FUEL RATIO SENSOR
- and the list goes on HELP!
- Is it possible to retrofit OEM navigation?
- Rear brake light dashboard indicator light
- Problem with dome light not lighting
- Need to buy rebuilt heads.
- Next project for install rear view mirror/display and backup camera
- sunroof issues ANY IDEAS
- considering a 1999 RX300 with 170,000 miles
- 2000 rx300 power steering leak maybe??
- transmission noise whine
- Problem Starting 1999 RX300 190,000
- My car won't lock.
- Curious on starter
- An Oddity Post Collision - RX300
- rear tail lights
- How Does the RX300 Measure Barometric Pressure
- Cracked key shell casing - help needed
- Error codes P0446 P0450
- New Owner
- Engine Replacement at 84k??
- 2000 RX300 Exhaust Questions
- Can EVAP system leak cause P0171?
- Great online deals at Advance Autoparts
- Great write up on P0171 and P0174
- Not trying to kick a dead horse but, P0171 /1135
- New member here saying Hi!
- P0171
- 2001 RX300 braking delay and random engine rev
- GROM USB adapter and black friday
- Window Auto Up & Down Problem
- Transmission
- High Mileage RX Owners, Speak Up!
- RX300 rear-ended, good source for body parts ?
- Please help
- Oil Leakage Problem
- AC/Heater
- Can you tell me what this is and why its wet with oil?
- P1354 problem
- Wiper insert part number
- Replacement Key Housings
- Rattling noise on my RX300 after going over a bump
- Strange Misfire / Removing Cylinder Head
- Pick up on RX300
- Mobil 1 ATF or 3309
- P/S FRONT AND BACK DOOR WON'T OPEN and LOCK
- Alarm comes on by itself
- steering noise after brake work done
- Vibration at idle
- RX300 2001 reached 150,000 miles today :)
- how to replace the headlight bulb
- how to put on headers.. 00 RX300
- Changed Valve Cover Gasket Today (at Toyata Dealer).
- does your car jerk when switching gears?
- Need some buying advice
- danged ol transmission ggrrrrr.
- integrate iphone with 2001 2002 rx300
- Rx300 suspension issues
- Periodically will not start
- Clicking noise when braking
- Vibration steering when car is cold
- Weird Vibration when Letting off Gas between 60-70 MPH
- CEL code P0440
- DIY: Lubricating the brake slide pins and replacing rubber dust boots
- VSC, Trac Off and CEL come on after Battery replacement
- Do I need to tight my drive belt?
- Got the RX back from the shop
- Just got new Lexus brand front brake pads
- It pays to drop the tranny pan
- Hot or Cold, no in between
- New SAD member...TRAC off and VSC lights
- Highest Mileage on original RX300 Transmission
- New Member and Possibly New rx300 Owner
- Engine Degreaser Suggestion
- Low RPM at cold start
- how to replace the high mount rear stop light?
- spilled on climate control and temp gauge out
- Under dash noise
- Driver Side Window Issue
- Advice on Maintenance
- Tire blow-out follow-up
- Navigation System Position changes
- what are your climate settings during the winter (snow)?
- Caling all RC fans for possible Air servo fix
- rear and front side marker lights
- 166K and going strong. Next batch of maintenance and to do's
- Can I repair my Air Servo ?
- checking transmission fluid- engine on or engine off?
- Need to replace Denso 234-9009
- overdrive
- Rattling noise when going over any types of bump
- 99 rx300
- 200,000 on the odometer '99 RX 300
- 2000 rx 300 - side parking light repacement
- Faulty ECM causing VSC + TRAC + CEL light to go on?
- Bulb questions
- new member says hi
- Additional led lights on my RX300.
- No Heat. AC Works, Seats Heat up, air is blowing from vents
- Getting new tires this Friday!
- Lock button on my remote doesn't work
- Keyless shell case broke
- 2000 RX 300 - Strut Replacement
- Two Questions
- what i did today...
- Transmission problem on RX300 ?
- Water getting into the right tail signal light!
- new member hello, and HELP
- OEM Oil Filter Numbers Question
- Rear Differential Leak
- why is my radio quality bad?
- Winter time: Do you guys warm up your engine?
- Few questions regarding the RX 300
- Hesitation When Idling?
- ONSTAR FMV Rearview mirror
- cel HELP!
- Bought an RX300
- Brake Hoses
- Replaced alternator - $$
- What's Everyone's Idle RPM in Drive?
- Question
- Strange Sound From Under Hood
- Check engine light on
- Safe to use 2004 Camry Valve Body in 2001 Rx300?
- 2001 RX300 Headlight Issue
- Automatic door lock
- Replace rear rotor DIY w/pic?
- Resurfacing Rotors?
- Please help!
- paint is coming off my 99 rx300
- Harrier License Trim Piece
- Changing ATF for first time
- Rx300 Battery Problems
- Error codes P0300, 304 & 305
- Clicking sound when starting
- VSC Light by itself, no check engine light
- 2002 rx 300 will not turn over
- A/C blowing hot air
- White smoke after changing bank 2 sensor 1
- How to copy the master key with the card key
- Rear wiper motor
- how many miles do you get on a full tank?
- door lock beep not beeping anymore
- How to buy the driverside floormat
- Changed O2 sensors, hurt fuel mileage
- my headlights are not that bright ...
- Question on the P0330 code, Knock Sensor
- robert
- chirping/noisy ac compressor/clutch
- Starting problem
- Screen not working
- 2000 RX300 Driver-Side Power Window Problem
- lamp failure sensor
- Auto shifting problems
- Headlight level change?
- Thanks for the mode servo help
- What is the O/D used for?
- How to run wire from dash to center console on floor
- One of the 10 Best Cars of the Last 10 Yrs
- Quick ?
- 99 RX300 Hesitation/Stumble out of nowhere
- 1999 RX300 Wireless Key not fully functional
- Air-mix servo motor keeps getting stuck at cold air
- Bought a 1999 RX300 @ 174,000 miles, what should I get done?
- Is driving in Power ECT mode all the time bad?
- RX 300 has rough idle
- RX300 mirror retracting in error
- Various questions
- How Do You Treat Your RX?
- Replace radiator hoses as preventive maintenance?
- What would a good headlight replacement be for my 1999 RX300?
